Dr PR
Everything posted by Dr PR
  1. Here is part two of the cutter build. The 2 mm MDF board contains a base for the assembly and the bulwarks. I used a hobby knife to cut the small tabs that hold the laser cut pieces in the carrier board. They came out easily. Each piece is labeled so it can be identified in the instructions. The instructions are clearly written and easy to follow. The first step is to assemble the bulkheads on the base. The bulkheads have tabs that fit snugly into holes in the base. The positions on the base are labelled with the corresponding bulkhead number. THE BULKHEADS ARE NOT GLUED INTO THE BASE. Most of the bulkhead pieces will be removed after the planking is in place so you don't want to glue them to everything! Next you must remove the keel, transom (stern bulkhead) and bulkhead C14 from the 1 mm pear sheet. I departed from the instructions a bit here. They say to put the keel in place on the bulkheads and then glue the transom onto the keel. But I could see there would be a restricted work area for gluing the transom in place if the keel was positioned on the bulkheads. I wanted to attach the transom at right angles to the keel, and the laser cut pieces fit together a bit loosely. I glued the transom onto the keel first, clamping it in place until the glue set. For this I used Duco Cement because it forms a very strong bond with wood and sets fairly quickly. I ran into the first problem when I was fitting the keel onto the bulkheads. Each bulkhead fits into a notch on the keel. The slots in the bulkheads that fit over the keel were a bit too narrow and did not want to slide into place. The MDF has very little strength and can fragment easily so I did not want to force things. The pear keel measured 1.06 mm with my calipers, and I just happened to have a small file that also measured 1.06 mm! I pushed the file edge on into the slots in the bulkheads to clear out some of the char and get the slot sides parallel (the laser cut is actually somewhat "V" shaped, and that is probably why things were a bit too tight). After a little shaping with the file the keel fit into the bulkheads slots. Things were still a bit tight but that is good. The instructions tell you that you will have to "joggle" the pieces a bit to get everything to go together. You must start at one end and fit the keel into each bulkhead one at a time. I found that rocking the bulkheads fore and aft a bit helped the keel find its place. Eventually you will get all the bulkheads in place on the keel. Each bulkhead has a rectangular cutout. The bottom of this cutout will line up with the top surface of the keel adjacent to the bulkhead (top and bottom relative to normal boat orientation when floating). Keep working the keel into the slots on the bulkheads until all of the surfaces are lined up. After the keel is in place the instructions say to paint the joints between the bulkheads and keel with glue. They recommend Titebond I or II wood glue. I have Titebond Original Wood Glue - I don't know if this is type "I" or not. I have never used Titebond before but it is the choice for many of the members of the Forum. I have been using SigBond aliphatic resin for much of the schooner build and for my MSI build. While the glue was setting I removed the two bow blocks (C11) from the MDF sheet and shaped them as shown in the instructions. Then they were glued in place at the bow. These will form a surface for the planks to glue to at the bow. These steps prepare the framework for planking. Next the bulkheads will have to be faired (shaped) to the run of the planking.
  2. I need a small boat for my Albatros topsail schooner build. I have made small boats from scratch before and it is a lot of fun. But back then it was the only alternative - there were no small boat kits. This time I decided to use one of Vanguard's small boat kits. The 18 ft cutter is the smallest they make. Rather than bury this kit build in the log for the schooner where most people would never find it, I wanted to start a log just for this kit. I asked the forum administrators where to post this build log - there is no section for general small kits like these boats and boat fittings. I was told to put it in with ship kit builds, in the appropriate period. I asked Vanguard what period this boat would have been used and it was used from about 1785 to 1815. So it could have gone into the 1751 to 1800 log. NOTE: This kit is carvel built (the hull planks fit together edge to edge), forming a smooth hull. May's The Boats of Men-of-War says the British started making boats called "cutters" in the first quarter of the 1700s. These were all clinker built (the edges of the planks overlapped), creating a lapstrake hull. In fact clinker built construction became known as cutter built, regardless of the type of boat. But between about 1800 to 1820 the Admiralty ordered all cutters to be carvel built like this kit. After that the Royal Navy went back to clinker built cutters. I have no information about what other navies or commercial vessels used for cutter hull planking. My 1815 schooner model is 1:48 scale, and I need a boat about 3 to 3 1/2 inches (76 to 89 mm) long to hang under the stern davits. The Vanguard 18 foot cutter is about 3.4 inches (86 mm) so it is the right size. At 1:48 it will be a 13.5 foot boat - think of it as a 14 foot cutter that has shrunk a bit over time. I looked in W. E. May's The Boats of Men-of-War and the basic cutter design appears to be the same for all cutters of the 14 - 18 foot length. So I don't plan to try to rescale any of the pieces. The kit comes in a small plastic bag. You have to go to the Vanguard web site to find the instructions in a PDF file. It contains a 2 mm MDF board, a 1 mm pear sheet and a 0.6 mm pear sheet. These are laser cut. A 0.36 mm brass photo etch sheet contains many small detail pieces. After reading through the instructions I decided to prepare some of the photo etch parts first. Four of the pieces are deck and gratings The instructions tell how to make simulated wood grain paint for the deck boards but I painted them with the same brown I used on the bulwarks of the schooner. Two small pieces fit together to make the boat anchor. The instructions say to glue them together but I soldered them. They make a very nice anchor! The mast bracket is a very small piece that must be bent to fit one of the thwarts. I used Birchwood Casey Brass Black to blacken the anchor and mast bracket. I will be building this a bit at a time to take a break from rigging the ratlines on the schooner.
  3. I use small spring clamps to hold blocks, hooks and lines. They are about 2 inches (50 mm) long and have rubber coated tips - you see them in a lot of builds here. I have a two-arm gadget with rotating alligator clips, and I clip an arm of a clamp in each alligator clip. This allows me to position the ends of the clamps close together the right distance. For stropping a block to the rope I first wrap the rope around the block and add a small amount of diluted white glue to glue the rope strop around the block. Then I clamp the block and rope into one of the clamps. I pull the two ends of the rope into the other clamp to hold them in place. I tie an overhand knot around the rope with small thread to pull the rope strands together tightly. Then a small drop of Duco Cement (or CA if you prefer) is worked between the rope strands with a needle point. The thread is wrapped around the rope strands for a few turns and tied off with another overhand knot to create a seizing. I usually wet the seizing coil with diluted white glue. After the glue dries I trim the loose ends of the thread and rope. To strop a hook to a block I first put the block with the rope strop around it in the clamp as before. The hook is placed in the other clamp with the eye facing the block. I pull both ends of the rope through the eye of the hook, fold them back over the clamp holding the block and tape them there. Then I make a seizing between the hook and block as described above. I make eyes in the ends of ropes the same way as I strop blocks, but without the block. NOTE: If you are using polyester rope the seizing alone will not hold the rope and prevent the end from pulling back out of the seizing. White glue or shellac will not glue the polyester rope strands together. You can use a drop of CA (cyanoacrylate) to glue the rope strands together, but it dries too quickly and creates a lumpy seizing. I prefer Duco Cement (nitrocellulose in acetone) because it cures more slowly (20-30 seconds), allowing you to wrap a tight and neat seizing.
  4. Murphy is always standing by to give us another leaning experience!
  5. Jo, You are learning! Welcome to the club!! I found it easier to install the waterways/margin boards all around and then nib each plank/margin board as it is installed. https://modelshipworld.com/topic/19611-albatros-by-dr-pr-mantua-scale-148-revenue-cutter-kitbash-about-1815/?do=findComment&comment=605072 You also need to decide what the planking pattern will be before you start planking. Planks end at frames, so you need to know the frame spacing. Then you need to decide on the planking pattern - how many planks cross the frame between the places where plank ends meet. Sorry, but this is a simple idea that is hard to explain. If you have the ends of two planks butted together at a frame, how many unbroken planks are laid down on that frame until the next two planks butt together at the frame? One in three? One in four? Nibbing is pretty easy until you get to the outer most planks - these are long and tapered between ends and require careful fitting.
  6. I started work on the ratlines, First I measured the distances and angles of the starboard forward shrouds and entered these dimensions into my CAD program. Then the pattern was printed. As you can see, I started by tying every fifth ratline. This helps keep the proper spacing between shrouds and spacing between ratlines. I am spacing the ratlines 0.25 inch (6.35 mm) - 12 inches 1:1 scale. My plan was to tie a clove hitch around the center shroud, and then use cow hitches for the ends as suggested by someone on the Forum. However, when I looked in Lever to see how to tie one there was no "cow hitch." I looked in my "knot book" (Knots & Splices, Percy Blandford, Bell Publishing Company, New York). No cow hitch! So I looked on line and discovered that a "cow hitch" is a "lark's head knot" by another name. Presumably by any name it ties just as tight. Much of our nautical terminology comes from the Royal Navy. I guess they didn't have many cows on their ships, but the sailors would have been familiar with larks. After all, Shakespeare wrote that Romeo and Juliet argued whether it was the nightingale or the lark "that pierced the fear-full hollow of thine ear." So the English knew of larks. But I can't see how the larks head knot resembles a bird's head in any way! The ratlines are Syren 0.012 inch (0.30 mm) brown polyester rope. This wasn't the best choice but it is what I have on hand. The polyester caused several problems. First, the ends unraveled quickly while I was trying to tie the knots. I had to treat every end with Duco Cement, placing a drop on the rope and twisting it between my fingers to secure the ends of the rope. That slowed things a bit. I thought I could tie them off quickly and then use shellac to hold things in place. But when I put a drop of shellac on the cow hitch knots the rope sprung open and loosened the knots. As fast as I pulled the knots tight they sprung loose again. Some sources caution against using the larks head/cow hitch because it comes loose easily. That certainly was the case here. After the shellac dried just the slightest tug on a line caused the knot to loosen again! So scratch that idea! I decided to use Duco Cement on all of the knots, placing a tiny drop in the loose turns and then drawing them tight. The cement dries in a few seconds and does keep the knots tight. It can be loosened with a drop of acetone. However, it leaves a white film on the dark rope, so I had to paint each knot with flat black paint. But the dry paint also helps hold the knots tight. I tied about half of the ratlines on the starboard forward shrouds and took a break from that frustrating effort. After the glue and paint had dried and loose ends were trimmed I installed the anchor buoy for the starboard anchor. This is a more or less "standard" way to hang the anchor buoy in preparation for deploying the anchor. The buoy rope (0.025 inch, 0.63 mm) is not a full 18 scale fathoms, and I will bunch the loops together more tightly after all the glue dries. I am not sure how I will rig the anchor buoy on the port anchor. I have the anchor rigged hanging from the fish hook, as if it has just been hauled out of the water. I suppose the anchor buoy would be hauled in and lying on deck while the anchor was being fished. So it won't be tied to the shroud, with the buoy rope neatly coiled.
  7. ANCHOR BUOY Here is a drawing of an anchor buoy and anchor from zu Mondfeld's Historic Ship Models. The buoy could be anything that floats. Some were made of layers of cork, some layers of wood, and some were made with staves like barrels. One reference said they were covered with canvas and tarred to make them watertight and resist the effects of water exposure. The length of the buoy was 1/4 to 1/3 the length of the anchor shaft. The buoys were fastened into a rope "cage" made of slings and hoops. Every reference I found showed this same arrangement with four "arms" for each sling, all gathered into an eye. However, for small boat anchors there may be only two arms for each sling. Each arm of the sling had an eye. The rope hoops passed through the eyes and the ends of the hoop were spliced together to form a circle. When the hoops were pulled tight the slings were stretched and tightened to hold the buoy securely. The upper eye on the buoy was attached to a lanyard that aided in retrieving the buoy and fastening it to the foremost shroud. The lower buoy eye was attached to the buoy rope. Several references said the buoy rope was 1/3 the diameter of the anchor cable and a minimum length of about 18 fathoms (108 feet or 33 meters). The buoy rope was tied around the anchor crown with a clove hitch. The end of the rope was laid out along the anchor shaft and tied to it with seizing. There were usually two seizings near the end of the rope, with a buoy knot at the end of the rope. Most references show another seizing around the shaft and rope close to the crown and clove hitch. The buoy rope was coiled and lashed to the forward shroud at the deadeye. For modeling purposes the rope doesn't need to be a scale 18 fathoms. Several posts on the Forum tell of clever reuse of beads, toy footballs and other similar objects for the buoy. I just carved my buoys out of a round dowel using a hand drill and files as my "lathe.". One reference gave the dimensions of a "typical" buoy, but it must have been for a "typical" ship, whatever that is. It was much too large for my 1:48 scale schooner model! I used 1/3 the length of the anchor shaft for the long axis, and that came out to be 0.572 inches (14.5 mm). The diameter is 0.318 inches (8 mm). Of course these are approximations. What I ended up with is what came from carving the buoy from a 3/8 inch (9.5 mm) dowel. I coated the buoys with shellac to seal them. When the shellac dried I painted the buoys with burnt umber (dark brown) acrylic to simulate a tar coating. The next step was to make the slings from eight lengths of 0.025 inch (0.63 mm) rope with eyes at each end. I made a tool by driving two pins into a scrap piece of wood, then cutting off the heads of the pins. The spacing between the pins was a "guestimation" based on measurements around the buoy bodies with extra rope for the eyes at the ends and an eye in the middle where the slings will come together. The only way to know for sure if the length was correct was to make one of these things - if not I get the pleasure of making more slings. I tied off the end eyes with small black thread but you could just glue the two strands together. These things are pretty small and the seizing is not that noticeable. Two of these pieces were tied together in the middle, with an eye loop in both, to form George's "4 legged spiders" or what I called "quadropuses." The next problem was to figure out how to control the eight ends of the slings while trying to wrap them around the small buoys. This looked pretty tricky and I was prepared for "the slings and arrows of outrageous fortune" (pardon the pun, with apologies to Shakespeare) to befall me. Fortunately Murphy took the day off and what I had imagined to be a trying exercise turned out to be pretty simple. I placed a small drop of Loctite CA (cyanoacrylic) gel glue at the point of the buoy, and another on the sling below the central eye. I held the sling in place until the glue set. Then the buoy was inverted the the second sling was glued to the other end. I don't like CA, primarily because I have always had bad luck with it. Every tube I have used hardened almost immediately after I first opened it, so I usually got only one use from each tube. I prefer Duco Cement (nitrocellulose dissolved in acetone) because it sets pretty quickly (20 to 30 seconds) and I have had tubes last for decades. But for this job I wanted instant gratification when I placed the slings on the buoys. As my luck would have it, the cap of the CA bottle was glued permanently in place. But the entire top of the bottle screwed off so I got a few more drops from it. I didn't have any of George's small cocktail umbrella rubber bands - actually they reminded me of the little bands dentists place on kid's braces. Instead I cut thin strips of blue painter's tape and wrapped them around the slings and buoys. This actually worked pretty well. I could reposition the ends of the slings under the tape to get fairly even spacing around the buoy. Then the hoop ropes were threaded through the eyes on the sling arms and pulled tight. Looks like I guessed correctly for the length of the sling ropes! I only wrapped the ends of the hoop ropes around each other with one turn, and no knots. I put a drop of Duco Cement on the junction and worked it in with a needle point. There should be no strain on these ropes so the simple glue joint should be strong enough! Here are a finished buoy on the left and another in progress on the right. The CA cement left a white blob at the ends of the buoys and the Duco Cement leaves a shiny film. I will need to touch up these areas with burnt umber and flat black paint. After everything is dry I may coat the entire buoy with dilute white glue to hold the slings and hoops in position. I will have to wait until I have finished the ratlines before I can tie the buoys to the fore shrouds. My anchor cables are 0.065 inch (1.65 mm) diameter. The buoy ropes should be about 1/3 as large, so I will use 0.018 inch (0.45 mm) or 0.025 inch (0.63 mm) diameter tan rope.
  8. George, Thanks for the information. The file about anchors is well done. I have found most of the information, in bits and pieces, in several of the books I have. I was wondering how to tame all those loose ends and your idea of using a (very) small rubber band is good. I don't think I have any here, or if I do I don't know where to find them! I will try a thin strip of painter's tape. But I expect Murphy to be right there to "help" me!
  9. Dowmer, Thanks for the link for the flag. I don't know if my printer (Brother LED printer) will print on paper that thin. It is a laser-like printer with a very hot fuser, and I can't run anything through it that might melt (would destroy the fuser). That rules out taping the tissue to a heavier sheet of paper. I'll try hand feeding the tissue paper - the worst that can happen is a paper jam. Farther down in Chuck's post he shows how he makes the anchor buoys. The longboat buoys are a bit simpler than what all the books show.
  10. I have been doing a bit of calculations for the anchor buoy and ratlines. ANCHOR BUOY Marquardt (p 192) says a "normal" anchor buoy was 54 x 30 feet (1.37 x 0.67 meters). At 1:48 scale this is 1.125 x 0.625 inches (28.6 x 17 mm). This is almost as long as the shank of the anchor on my model! Marquardt does say smaller anchors had smaller buoys. I looked for photos of models showing the anchors and anchor buoys. I found four. A = length of anchor shaft (head to crown) B = length of anchor buoy Photo A B A:B 1 0.938 0.3215 3.00 2 0.319 0.109 2.93 3 2.78 0.922 3.02 4 0.328 0.147 2.23 So actual anchor buoy length is about 1/4 to 1/3 the anchor shaft length. Since my model's anchor is very close to actual scale for a schooner of the model's size, and the anchor shaft length is 1.716 inches (45.2 mm), the anchor buoy should be about 0.57 inches (14.5 mm) long, and (using Marquardt's proportions) about 0.318 inches (8.0 mm) wide. RAT LINES (Ratlings) Lever (p 25) says ratlines were spaced 12 inches (305 mm). Marquardt (p 172) says 12 to 16 inches (305 to 406 mm), with 13 inches (330 mm) most common. Lees (p 44) says 13 to 15 inches (330 to 381 mm). Mondfeld (p 288) says 15 to 16 inches (381 to 406 mm). Chapell (Fishing Schooners p 586) says 16 to 16.5 inches (406 to 419 mm). So there you have it. Ratlines were definitely spaced just about any distance you want! For my model, an American schooner, I will go with Lever, Marquardt and Lees 12-13 inches, or about 0.25 inches (6.4 mm) at 1:48 scale. I would rather use Chapelle's 16 inches because I would have to tie a lot fewer knots!
  11. I have printed the flag, and the flag halliard is already in position. I am trying to figure out how to fold the flag so it hangs "naturally." I need to print it on lighter weight paper. I never visited the NROTC building at OSU. It used to be a Quonset hut down by the railroad tracks. I don't know where it is today.
  12. I have had the same problem with some of my CAD designed parts when it came time to actually make them I'm afraid the computer design is more accurate than I am when I start cutting pieces. I always make parts a bit oversized. It is a lot easier to remove a bit than it is adding it back!
  13. I just realized that I need to add the anchor buoys and rigging to the anchors. And I probably should put foot ropes (horses) on the bowsprit and jib boom. Wonder what else I will think of before this is done. Any suggestions?
  14. I worked for a couple of days to clean up the loose ends of the belayed lines and attach the rope loops. I left the lines longer than needed so they could be loosened and tightened as necessary to get them running right. The deck was a mess of loose ends looking more like a plate of spaghetti than a ship. After they were all glued in place I cut off the loose ends. Then I installed the rope loops I made in post #307. I did match the rope size in the loops with the size of the actual line, but I made no special attempt to make the rope coils any special length. In reality some would have more loops than others. Maybe on the next build! At the bow the lines from the fore sails belayed at pins on the port and starboard bow pin rails. Some of these lines are the sheets for the fore sails, and they must wrap around the stays of the sails farther aft. I haven't "tamed" them yet to hang in a realistic fashion. The sheets of the fore staysail pull the clew of the sail forward, causing it to fold back. I haven't figured out how I will fix this so the sail hangs more naturally. The fife rail at the base of the fore mast has many lines belayed to it. This was the most difficult part of the belaying plan - there were more lines than there were belaying pins. But by putting some of the tackle aloft - such as the yard lift gun tackles - the number of lines to be belayed and the crowding of tackles around the base of the mast was reduced. The area around the fore top is pretty crowded. The lines from high on the mast are routed through fairleads on the fore top crosstrees to eliminate tangles and chafing. Some of these lines had to be untied after belaying, pulled back, and rerouted several times to get all of the lines to hang without tangles and chafing! I was worried about getting the lines belayed and the rope loops hanging correctly on the bulwark pin rails because I had to work "blind" from outboard to get the lines hooked around the bottom of the belaying pins. The gaff sails hanging on the centerline prevented me from having unobstructed access from across the ship. It did take some patience and repeated attempts but I learned the routine and it wasn't as bad as I had imagined. The rope loops with two "eyes" to fit over the belaying pin worked nicely. I put a small drop of cyanoacrylate (CA) glue on the part of the loop that would rest against the pin rail. After the loop was in place I put diluted white glue on the top of the pin and the loops that fit over the pin. I think they worked out OK. I worried most about the four lines that belayed to the main mast fife rail. Access to these belaying points was the most restricted of all because of all the other rigging. The main problem can be seen in the picture left above. The pivot gun table is much too close to the fife rail to allow the rope loops to hang on the forward side. So the lines had to be belayed from the aft side of the rail. I made a wire hook to help pull the lines under the rail and loop them around the bottom of the belaying pins. The picture right above shows the rope loops hanging behind the rail. Fortunately there were only four lines to rig this way! There aren't many lines to belay at the stern. However, the lines there belay to cleats, and not belaying pins. This requires a different arrangement for the small loops that tie around the cleats. My pre-assembled rope loops weren't optimal for this belaying method. There are still a few more lines associated with the ship's boat to be belayed here. The ratlines and the boat are all that remain to be rigged on the model. I will be doing this bit by bit, while I resume my USS Cape build. I will also need to make a permanent base to display the ship. I did discover one more broken plastic hook - on the port cat block. Soon that will have a metal hook!
  15. I use Squadron White Putty to fill small gaps that will be painted (it is white and stands out like a sore thumb if not painted). If you are filling larger gaps and cracks in hull planking there are better fillers. There was a lengthy discussion on the Forum a month or two ago about how to make wood fillers using sanding dust from the wood you are using and mixing it with something like white school glue (Elmer's Glue All or similar) that dries colorless. Smear the paste into the cracks and sand it after it dries. If the gaps are pretty wide (1 mm or 0.039 inch) I just shave off a thin strip of wood, taper the ends as necessary, and glue it into the crack. Use the same wood that you are planking the hull with and the filler will not be noticeable.
  16. I agree with Trevor that you probably should have a bit more curvature in the planking at the bow. That would bring the point where they join a bit farther back. In your post #63 it looks like you didn't cut back the side pieces #21 at the bow far enough. Also, It looks like the hull sides are a bit too vertical at the top - in other words the planks should slope outwards more. This would cause the line of intersection of the planks (the stem) to angle back and intersect the gammoning knee a bit farther back. You could cut the planking back from the bow and reshape the filler to add some of curvature to the planking, and increase the outward "V" flare a bit. Or you can just live with it. No one else will notice on the finished model. The real problem will be finding a place for the gammoning ropes if the knee doesn't protrude far enough forward from the stem. I had that problem on my Albatross build. My solution was surgery on the bow to extend the gammoning knee. https://modelshipworld.com/topic/19611-albatros-by-dr-pr-mantua-scale-148-revenue-cutter-kitbash-about-1815/?do=findComment&comment=912575 One Lynx plan shows the gammoning ropes running under the knee and over the bowsprit, rather than the ropes running through an opening in the knee. However the Lynx model in the Smithsonian doesn't appear to have gammoning. Chapelle doesn't show gammoning in his drawings of Lynx or Musquidobit, although he does show this in drawings of other vessels. I have seen instances of where the gammoning was positioned inside the bulwarks at the bow. Unless you have drawings showing the the British added gammoning around the bowsprit and knee I think you can leave it off. And that means you don't need a long knee. In fact, some vessels had no knee at all, with the stem rising straight up to the bowsprit. The modern Lynx reproduction has a much larger decorated gammoning knee, but I can't see any gammoning in the photos I have. Murphy often gives us additional opportunities to practice our modelling skills.
  17. You did not "cheat." You improved the chance of success!
  18. There are days when nothing seems to go right. But it is amazing how a bit of sunshine can make things right again.
  19. Nice planking job. Can't say as much for the Texas penguins! Kind of like the Wyoming jackalope. I am from Arkansas originally and we have learned to be leery of Texican exaggerations! But I do have relatives from Texas. My father's mother was an Austin, related to Stephen Austin, as in Austin, Texas. So I guess that gives me some immunity from exaggeration.
  20. The model is fully rigged (almost) - I think. All of the sails and running rigging are in place. I still have a lot of tidying up to do to trim excess line lengths and add the rope loops to belaying points. But I think all of the lines are in place except the ratlines. The thought of tying thousands of knots for the ratlines brings nothing but joy to my heart! One more plastic hook broke. I replaced it with one of my metal hooks. I suspect it will be necessary to tighten some of the lines, but at least the all are in place (I hope)! After that the ships boat will have to be added. I have a Vanguard Models 18 foot Cutter kit for the boat.
  21. Falconer's Universal Dictionary of the Marine (1769) says the lanyards in deadeyes were smeared with hog's lard or tallow so it slips more easily through the holes. Consequently I would suspect that they aren't tarred heavily, But the fat probably oxidized to a brown color, so the lanyards wouldn't look like new rope - unless they were new. He doesn't say anything about rat lines (rattlings) being tarred or not. But they are part of the standing rigging. Since the shrouds were tarred it is safe to assume the ratlines would be tarred also.
  22. It has been a while since I updated this log. I have been working to finish the rigging on my topsail schooner build, and that has been very time consuming. I had to order more rope for that job, and also ordered a helm (ship's steering wheel) for the Cape's pilot house. I considered carving one from scratch, but noticed that Syren had two "mini kits" for ship's wheels, 15/16 inch (26.34 mm) and 1 ¼ inch (31.75 mm) diameter. The kit wheels are ten spoke wheels, and the Cape's wheel had eight spokes. I originally estimated from the pilot house photo that the wheel was about 4 ½ feet diameter. So the 1 ¼ inch wheel would be closet. But I have since found a blueprint that says the wheel was 48 inches diameter – 1 inch at 1:48 scale. So this wheel is a bit oversized. But only the top will be visible in the model's pilot house, so this is good enough! If I had the proper tools I might try making a wheel, but the Syren kit is a lot simpler, and can be finished faster. So I decided to order the Syren kit and see how it works out. Here is a build log for the Syren 1 ¼ inch Ship's Wheel kit. The kit comes in a small plastic bag with seven small pieces of laser cut Castello Boxwood and a kit label. You must visit the Syren web site to get the instruction sheet PDF file. The instructions caution to not use CA (cyanoacrylate) glue for assembly. It sets too fast, and you need to be able to align parts before the glue hardens. Syren recommends water soluble yellow glue. I used Sig-Bond aliphatic resin. The instructions say to sand all sheets lightly to remove laser char. These are solid wood sheets, not plywood, and they have grain. If you bend the thin sheets along the grain they will break. Handle with care! The two largest sheets must be carefully aligned and glued together to create a jig for the wheel assembly. The ten round holes in the bottom sheet should line up in the center of ten arc holes in the top sheet. I used the shank of a 3/32 inch (0.094 inch, 2.4 mm) drill bit to align the center holes. Next you should remove the "rim segments" – the short arc pieces – and carefully sand or file the curved edges to remove char. The short end sides should not have the char removed so they will fit tightly in the assembly jig holes. The instructions suggest using 320 grit sandpaper and sanding lightly to remove char. I used a small "D" cross section file and used very light pressure. I used tweezers to hold all of the small pieces firmly while removing the char. Some of these parts are only 0.025 inch (0.6 mm) thick and fragile. By filing only where the tweezers hold them I avoided bending the parts. Even so, I did break off a bit of one of the "C" shaped pieces, but it glued back together nicely with Duco Cement. It didn't take long to remove the char from all the parts. Extra pieces are included for the rim segments and spokes in case you lose or break one. The next step was to place the rim segments into the positions in the jig. Here you see seven of these pieces in the holes in the jig, and three more waiting to be placed. They are not glued! I found it necessary to file the curved sides a bit to remove all of the char before the pieces would fit into the jig. The rim segments are thicker than the jig piece and stand proud. Next the ring "C" pieces were glued to the rim segments. You must use glue sparingly, placing a small drop on the rim segments to ensure that you don't glue anything to the jig. Clean up any glue that squeezes out. Here two ring pieces have been glued in place and the third is waiting. Position these carefully over the rim pieces so a bit of the rim segments shows on both sides. I used Sig-Bond aliphatic resin to glue the parts together. It is slow setting and that allowed me to center the ring pieces on the rim segments. I allowed the glue to set several hours before working with these pieces. Next the wheel hub was made by gluing a "star piece" to a circular disc. I used the 3/32 inch drill bit as a mandrel to ensure that the pieces were centered correctly. After the glue set I scraped the char from the star piece. I probably should have done this before gluing the pieces together. Any glue that squeezed out was removed. After the glue had set the wheel rim was removed from the jig. To do this I pushed through the holes from the back of the jig, one at a time gently until the ring was free. The wheel spokes will fit into the gaps between the rim pieces. The "C" pieces are very thin and will break if you put too much force in any one position. Work slowly and work the piece free a bit at a time. After it is free from the jig you can sand both sides of the ring to make them smooth. The wheel spokes have square cross sections when removed from the sprue. The instructions say to remove the char from the square parts that fit into the ring and the hub, but leave the char on the parts that need to be rounded. This makes it easier to see the places that need to be rounded, and those that should remain square. I used a motor tool to spin the spokes and the D cross section file to turn the parts between the ring and hub. The handles on the ends of the spokes were also fashioned with the file. The instructions say to turn all fourteen of the spokes provided with the kit before trying to place any on the ring and hub. You will get better at it as you go, and afterward you can select the ten best spokes to use in your ship's wheel. You can see where the file slipped on the bottom spoke and rounded the edges of the square segment close to the handle. Another spoke has a handle that is too large. Next the spokes must be trimmed to length. The jig has a pattern that can be used to trim off the extra material. The ends that fit into the notches in the star piece of the hub need to be filed to a "\_/" blunt point shape to fit All of the pieces need to be the right length so the square cross section pieces fit between the ring and the hub. This was the most difficult part of the build. I used the drill bit to center the hub on the jig. The holes in the jig were used to align the ring centered on the hub. Double sided tape held the ring in place while each spoke was trimmed to the same length. The spoke on the right is trimmed so the square section at the ring aligns on the inside with the edge of the ring. The piece on the left is a bit too long, so the inner part of the square section is too far out from the hub. I filed some off of the hub end until it was the correct length. With all the spokes the correct length it was time to glue them to the hub and the ring. Again, it was necessary to be careful that the ring, hub and spokes were not glued to the jig. For this job I used Duco Cement. It makes a good bond between wood pieces and takes a bit longer than CA to set so the pieces can be repositioned as necessary. After the glue set the surface was sanded smooth. Next the remaining "C" pieces were glued to the ring. I used Sig-Bond glue for this. The "C" pieces must be positioned carefully to be centered on the rim pieces. After the glue set the wheel was carefully lifted from the double sided tape. Then both sides were sanded with 150 grit paper to reduce the thickness of the "C pieces to about 0.012 inch (0.3 mm). Then they were finished with 220 grit sandpaper. The resulting wheel looks pretty good! I put a layer of shellac on it, and may follow up with more to darken it a bit. There are a few places when some of the char is still visible, and this probably should be filed off. If I had a lathe I might have turned some knurls or rings on the spokes like on the Cape's wheel. But I wasn't going to attempt this using a motor tool and a file! The original wheel had some brass parts around the hub. I am not going to try this at 1:48 scale. Now I just need a pilot house to put it in!
  23. Paul, You are planking the hull from the inside out! That is a very good way to get all the bulwark frames in place. I envy you on this build. The HAER report drawings show so much detail of the construction of the ship. We don't have that detailed information for most builds. Somewhere here I should have photos (slides) I took on the Wapama back in 1972 when I was in San Francisco for discharge from the Navy. If I find them I'll scan them and send them to you.
