VTHokiEE
Posts posted by VTHokiEE
  1. 10 minutes ago, JToma said:
    Something you can try when you mask that line is paint over the edge of the tape with a clear paint to seal the edge of the mask.
    I’m also not a paint master so double check this, but I’ve done the same but instead of clear (which is frequently mentioned) used the same color as is under the tape (in this case white) to seal the edge.
  2. Small update, added the mast deck rings and worked on the gaffs. I also began fabricating all the metal work for the masts (making all these pieces is a time consuming affair for a novice, but I think they are turning out well 🙂).
    EDIT: I forgot to ask, the anchor is white metal and the chain appears to possibly be copper (?). I don't believe either will blacken in the birchwood casey brass black that I have. Does anyone have any suggestions? I'm considering whether to purchase some Jax or replace the components and I'm open to suggestions. Thanks!
  3. EDIT: Currently spoken for.
    I bought these three kits many moons ago but now that I've dabbled in wooden ships I severely doubt these will see the light of day. I started the Cromwell (and used too much glue) but the other two are still sealed. I always wanted to build a really nice plastic model but c'est la vie. Anyhow if anyone wants these kits I will gladly send them for the price of shipping; I'm more than willing to ship it internationally but I can't see how that would make financial sense.
  4. I made up two blocks for my travelers, blackened the travelers (I need to do some more practice blackening, I think I'll look into the sparex route for cleaning):
    Next I made the deadeye strops from some brass wire:
    I made 9 rings, 2 were poorly soldered and broke so I had to go back and make an 8th, but I didn't go back and retake the pictures. I did a trial rund with the thin brass strips for the deadeye chain plate and decided that it looked reasonable.
    After I attach these to the hull (hopefully this afternoon), I'll start tacking the metalwork on the booms and spars.
  5. More pictures to come later, but does anyone have a suggestion on what to use for a deadeye chain plate? I finished my deadeye strops and I was planning on using a thin strip of brass, but now that I’m about to make them I’m not certain (the strips feel too flexible, 0.01mm, maybe I need thicker brass?).
    Picture of deadeyes if it helps:
  6. 13 hours ago, Azzoun said:
    You're speeding along, this model took me 6 months to build!  haha
    Thank you for this; I actually felt like I was crawling along at a snail's pace, but having great works to look at (like your gallery really help). This forum has so many talented builders sometimes you have to remind yourself that everyone's pace is different. I'll probably start slowing down now though as I'm reaching the area (getting my blocks and metalwork set up for rigging) which I'm not entirely certain how to do. I'll probably try to closely emulate Hopeful's and your builds. You wouldn't happen to have any closeup shots of your spars, gaffs, and blocks?
  7. Waterline taped off:
    Painting in progress:
    And completed (it isn't perfect, but overall I was pretty happy with it):
    The supplied door hatch wasn't the correct size (as the kit was opened and purchased off eBay, I assume it had broken, but I didn't see the missing part). I had some 1/16" Walnut around (the original hatch was 1/32", but I didn't have anyway to plane the walnut to match) and I fashioned a new hatch:
    Finally, I fashioned a gammon iron and attached the deck cleats (using replacements from Syren since the kit provided cleats were plastic):
  8. 14 minutes ago, wefalck said:
    And you need the appropriate heat-source, a torch, as the melting point would be around 600°C as opposed to 350°C or lower for soft-solder. There are silver-soldering pastes, btw.
    Any thoughts on specific pastes? I’m considering ordering some solder called Stay Brite which seems to have a favorable reputation on the forum, but it isn’t a paste (at least not that I saw during a quick glance).
  9. I decided to try my hand at making some deadeye strops this morning and I seem to be failing spectacularly. I create a ring out of brass wire and then attempt to solder the joint together. When I place the deadeye in the ring and begin to crimp the ring the joint breaks and I can't seem to figure out what I am doing wrong. I was using Solder-it Paste but that seemed to be dripping everywhere and I am contemplating getting solder wire as that may be a little more comfortable for me. I realize there isn't much information here, and that's probably my issue, I'm probably missing a step or two.
    Alternatively, does anyone know where I can buy small brass loops until I figure out my solder issue?
    Thanks for any guidance!
