Posts posted by John Gummersall
On to trimming and shaping the four sides..... I mentioned above that laying the strips got old very fast.... but sanding and shaping these same strips really got old fast. This step kicks up a lot of dust. I recommend wearing a mask and if the weather is nice outside, do this trimming outside. Main idea after the strips are trimmed is to sand them from top to bottom forming a somewhat convex shape. Very little is trimmed off from the top of the strips to when almost all of the strips are sanded off at the bottom.
Below is on of the two finished sides. Pay special attention to the four areas marked with black boxes. Since the finishing strips will lay across these initial strips there needs to be a smooth transition between the strips and the side walls.
Pardon my photos,,, I seemed to have moved the camera with them as some of them are out of focus.. I will try to be more careful in the future.
Below are some close ups of the four transition sections I mentioned above. You will also note the convex shape of these walls
- BLACK VIKING, Canute, Ryland Craze and 5 others
6
2
With the inside lined, time to add the external strips that will form the curved edge. Looks like I jiggled the camera when I took this shot. Basically the strips around the sides are laid flat and the ones on the lower part of the carriage are laid on edge
Now starts the process of cutting the small strips that will eventually form the curved edge. Not much to show of the process other than to say cutting the strips and laying them on edge got old really fast. Below is the completed left side. Don't need to make it too neat at almost all of it will get sanded off
And the completed right side. Again, are really tedious task.
Before the sanding, others have mentioned to make up the two doors so when sanding the curve there is a smooth transition between the walls and the doors. Making the door will be the next step.
- Canute, Seventynet, hof00 and 4 others
7
Once the clips come off and excess trimmed, the inside is done except for the floor. Take you time with the thin rim around the top of the carriage (marked with black arrow). As you work your way around the top of the carriage, this area is so thin, when cutting across the grain it is very easy to split the very small thin piece of wood. Expect to have some bad words as you go around the top.
Other than that, the rest of the carriage is pretty straight forward.
Finished and trimmed top edge
On to the floor. As mentioned earlier, the best/easiest way to lay the floor is to do it before you attach the walls. If you are like me and did not think that far ahead, the 2nd best way is to assemble most of the floor outside the carriage. I started with the outline of the floor on a sheet of paper. This was to get the general size of the floor and lay out the panels. All the panels are full length except for the two panels by each door. Those will take trimming.
Once the panels are all laid out flat and lined up, slip out the paper and you will have the layout of the floor. Make sure the panels a lined up and close together. Tape them to keep them together. I would recommend some not very sticky tape such as painters tape. Does not take much to hold these planks together. At this point you can lift up the entire floor and dry fit it in the carriage. The final four panels by each door will be shaped and glued in once the floor is in.
Below, floor is dry fit into the carriage.
Once you see how the floor will fit into the carriage, line the floor with glue and lay the flooring done. Add whatever you have to weight it down. Note the tape is still attached at this time.
Once the glue dries, 99% of your floor is complete and way easier then laying one plank at a time in the carriage. Only thing remaining is the four trimmed panels by the doors.. At this point remove the tape.
It take some patience and a steady hand but these pieces are easily trimmed and glued into place. These trimmed pieces will be similar to below.
After filling in four corners then proceed to fill in the walls between the walls. Not a big deal as these are flat pieces and go in pretty easy. A more difficult area is the very thin border around the top of the carriage. These are marked by red arrows. I did not do this, but I would recommend when forming these very thin pieces, to cut them very close (a little larger) to the actual size. Than after the glue dries, it will only take sandpaper to smooth them out. In my case the pieces are way to large and I needed to use a cutter to cut away the excess. As mentioned before, these pieces are so thin, cutting them is a challenge. They tend to split just looking at them. Best to only sand them if possible.
Next came the curved piece at the top of the carriage (marked with black arrows). Instructions do not mention this, but use the carriage itself as a template to create the curve. As shown below, use some card stock and trace the outside curve of the carriage.
From there you will have an outline of the curve
Cut that out and you have your pattern. it will be a little long, but better long than short. Just trim the ends to fit inside the carriage
From you pattern it is easy to create the correct curve out of the sapelly.
Insert it into the curved section of the carriage and you have a perfect fit. Excess will be trimmed later. Again, you just can not have enough clamps 🙂
Once both front/back sides are covered, you fill in both left/right sides. Instructions call for a very inaccurate way to measure for the curved sides (Part 71). At my skill level I would have really hard time making that curve match the actual curved corner in the carriage. I pondered it for a long figuring there was no way I was going to be able to make that curve match the carriage.
Finally realized, and I am not sure why the instructions did not talk about this, but you already have a template that will match the curve exactly. That being the outline of the sheet wood that contained both sides of the carriage.
Insert a sheet of the sapelly into the frame and you have the exact curve. Use a pencil to mark the curve and cut it out with a sharp scissors. Again, this wood is so thin a scissors works far better than even a sharp exacto knife. I am sorry I did not get a picture of the resulting piece, but it really is the exact shape of the curve.
Below you see the shaped piece inserted into the corner of the carriage. Using the supplied template is really the only way to do this..
After all four corners were in place, just started going around the inside of the carriage inserting in the straight pieces. Note each piece is a little long and will be trimmed later. I think (hope) it will be easier to trim around the windows and doors later on then try to trim the pieces to make at exact fit prior to gluing them in
- Seventynet, Diver, hof00 and 8 others
11
Next come bending the cover over the carriage structure. Instructions calls to start at one end and slowly with CA glue bend the wood over the cover. To me that seemed kind of hard and i am not a big fan of CA glue when wood glue would work. To me the easiest way to ben the cover over the structure was to slightly dampen the cover - both sides. Find the middle of the sheet and clamp the carriage to it. I then used a heat gun to soften the wood (not sure that was necessary) and slowly bent each side up at the same time. Again, make sure the carriage is securely clamped to the center of the wood sheet. At that point l the sheet is up over both sides, clamp it well and let it dry overnight.
Next day remove the clamps. The cover sheet will flop down some, but can easily be bent back. Add some wood glue to all glue spots and clamp well. Again wait over night for the glue to really set up. In addition to clamps, some rubber bands were added at the curve to make sure it was also well glued.
Next day when clamps are removed all is good
Used an exacto knife and sand paper to remove the excess wood.
I forget exactly what happened here with the gouges, but it had nothing to do with bending the wood. I seem to remember "trying to be cute" and "Fast" with the wood trimming and these gouges were the result. Not a big deal. A little wood filler and all is good with the world
On to lining the inside of the carriage with the really thin .06mm sapelly wood. That is really thin... it splits and cracks just looking at it. I found one was that worked for me in cutting the sapelly was to use a sharp scissors. It is especially hard on both sides of the carriage as the sides are curved. So you have to shape the wood and it can be a challange do to the wood being so thin.
Once side complete
Second side complete. I am not too worried about the middle piece on the left being a little short. In the end, when the floor is laid and seats added, that little gap will not be seen. However, there really was no excuse for that piece being short.... other than lack of skill on my part 🙂
Next step call for gluing the floor between the curved walls. Instructions say to do this like it is not big deal. And for a more experienced modeler maybe it is obvious. I spent way too many hours successfully discovering all the ways not to do it. May issue is the fact that the wall are not yet secure, so gluing on the bottom proved challenging.
Anyway secret (for me anyway) was to use double sided tape. Tape holds the sides steady while the top is glued. Here again, ways not to do it. I initially used some 30 lbs double sided tape. As soon as I stuck on the first piece, I knew I was in trouble. Tape was way too strong and I felt I would break the piece trying to get it off the tape. I then used some 6 lbs tape. Again too strong, but that is was I used. After glue dried, with a putty knife I slowly worked off the pieces. If you have some plan double sided tape around, you might try that. I may or may not be strong enough, but it is worth a try. All it has to do is keep the base from moving around while you glue on the floor.
A few pictures showing the floor being glued onto the carriage. With the base secure due to the tape, it was pretty straight forward.
And finally gluing on the two straight beams
- Jack12477, Canute, Landlubber Mike and 6 others
9
Final step for the frame is to add the previously assembled wheels and haul pole. And the frame is complete
At this point the frame is complete.. It will be set aside, at the speed I build models, for a very long time while the carriage is built.
Not required, but I choose to pre-bend the bottom half of the carriage by wetting it and using the outline the upper curved beams, let it sit over night.
with both side pre-bent I joined them with the upper curved beams.
At this point the instructions call to "glue on the floor".... Prior to doing that I drew some lines on the floor to give me a line of reference when later laying the floor beams. Lines are not any particular distance apart. They are just there to give a line of reference when laying the floor beams in a later step.
Creating the four frame exterior and interior brackets. This involves curling over the ends of each bracket and then inserting the interior bracket inside the exterior bracket. Note the resulting hole in the end of the combined brackets will eventually need to be able to fit a 1.5 rod. Before you are finished, make sure you can fit a 1.5 rod in the rolled hole at the end of the combined bracket. This will save you a headache later on.
Making the suspension spring links, instructions call to use the etched brass parts and 1.5mm brass rod and attach them with CA glue. My problem was that the holes in the etched brass parts was a little larger then 1.5mm. Not sure the CA glue would really fill the gap and hold tight. Instead I used a tab of epoxy to hold the 1.5mm brass pieces. Epoxy not because there would be any stress on these joint, but more for it was thick enough to fill the gap. All would be painted black in the end anyway
Bracket clamps attached to the frame after painting them yellow
And then adding the black suspension springs via the suspension spring brackets
- Seventynet, Canute, yvesvidal and 3 others
6
Next item is to figure out where the brake bar is located on the frame. Instructions call for it to be 24mm back from the front stabilizer. Not sure I would trust that measurement - especially with my modeling skills... Instead I temporarily put on the rear wheels, and with a toothpick holding up the brake struts, it is pretty easy to see where the brake bar should be located. Basically above the holes in the brake struts.
Instructions do not call to cut a little channel in the three lengthwise beams, but the brackets (that attach the brake bar) are too small to fit around the brake bar, so you really have no choice. From the measurement above, mark the lengthwise beams adjacent to the holes, and with a drill bit, create a little channel to hole the brake bar.
Use the brackets that are used to attach the brake bar as a guide as to how deep the channel needs to be. When all is done, brake bar should easily fit into the three lengthwise beams. Brake bar only now needs some blackening.
Next the three brake bar rails were formed to shape and located on the three lengthwise beams. Again temporarily attach the rear wheels and position the brake to locate the position if the brake bar rails. Once located, blacken them and nail to the beams.
Next came the suspension springs. In order to get close to the actual curve I used the "actual size" diagram to form the curve. I put the "actual size" in quotes as I assume do to camera angles and what not, the pictures are not really actual size. I mentioned the earlier, the picture are close but in reality a little larger then actual size. But close enough in this case.
After soaking the suspension springs, who says you can not every have enough clamps? Let it dry over night, and you have your suspension springs
Paint them black, add the fitting on the ends.
Not the fastening wires in the end of each spring. Instructions state they are the 10mm wire bent over and thru the spring. On the other side of the spring the end are soldered and sanded, and eventually painted black
Below is the other side. The four wire ends have been soldered and sanded smooth. Just need to touch up the black paint.
Started working on the brake bar... For me, this proved to be more of a challenge that it should have been. Process starts out drilling two 1mm holes in a 2mm round bar. After measuring where the holes were to be places, I filed a flat spot to help the bit not to wander. Instructions talk about using a punch to also help steady the bit. I found that pretty hard to do. Even putting the bar in a vise, it just would not hold steady to take the punch. Instead I finally got the holes drilled by using a very slow speed on the drill and a stead hand. By slowly drilling the hole it was easier to get the bit not to wander and start the hole. Once the hole was started, with steady pressure, bit when through. Secret here is take it slow
Formed the brake bar into the correct position, and made the brake hooks cut from 1mm wire and soldered them into the brake bar
then attached the brake lever onto the brake bar
Next add the metal (?) straps to the steering bars. As before I choose to make these out of card stock and paint them.
and applied/painted to the steering bars. To me it really looks like metal and a whole lot easier to make.
Start making the haul beams by blacking the fittings
Trimming and forming the haul beams was relative simple with some sand paper
and final assemble
Applied to the steering bars
building the brake system starting with the brake struts.. One hole in one end and two holes in the other end
Add the struts to the brake bar.
- Ryland Craze, Jack12477, yvesvidal and 3 others
6
Next came the rear axle. Start with the 9x9mm square wood and drill a 5mm hole in each end and insert the 5mm dowel. At the end of the 5mm dowel drill a 2mm hole and insert the 2mm dowel. Paint it up and put aside for later steps
Started working on the steering struts
When gluing the struts together, instructions call to make the gap 5.5mm in order for the haul bar (5.0m) to easily slide. Prior to gluing the struts together I temporarily inserted two of the brass strips to accommodate for the extra .5mm... Having done that, I am not sure that is necessary. In fact I wish I had not allowed for that extra space. Haul bar can still easily fit between the struts and can move around. I really hated to see the extra .5mm gap. In a later picture I will show the haul bar inserted and the gap showing - ugh
Glued with the strips removed. In the below picture the three straps with the pins showing are all made of card stock and painted. The side clamps are the brass strips. As mentioned earlier, it really is hard to tell the difference and the card stock is a whole lot easier to work with.
Next came the haul bar - again card stock instead of the suggested blacked brass.
Attach the steering struts to the front wheel bracket. This calls for slitting the front wheel bracket and laying in the steering struts so the lay flush. Lay the steering struts on to of the front wheel bracket 45mm back from the haul bar. This is where the steering struts should be inserted into the haul bar. You can also use the full diagram to help with the placement. Make some lines on each side of the front wheel bracket and start cutting. After some cutting, filing, and sanding the struts should lay even in the front wheel bracket. Below shows the two parts about to be joined,
And all assembled
- Jack12477, Canute, Seventynet and 7 others
10
Next step was to create clefts in the beams and in the suspension stabilizers. Instructions call to use a fine hack saw, with clamps and steel ruler. Clamp the pieces and then using the saw make the clefts. Here is where my lack of skill started to show up. Making a straight cleft in the suspension stabilizers was pretty easy as those part are wide, but making a straight cleft in the three beams, for me anyway, was really hard. First off the beams are very narrow so there is not much for the metal ruler to grab on to. As such when I started the saw cuts the beam would tend to move on me. Also, in my case, the beams were not perfectly straight. There was an ever to small bend to them. Had to look really close to see the bend, but it was there. End result, while the saw cut was in the middle of the strip at both ends, the slight bend in the middle ended up with the cleft off center. It looked horrible.
Had to go through the process of soaking and straightening out the strips.
Below you see my attempt at clamping the thin strips. I ended up using the sticking side of duct tape to help hold the stirp in place as I made the cut. Unless you really are confident in making these cleft cuts, I would suggest getting of additional 3/16" strips (closest to 5mm) and practice, practice, practice before you make the attempt on the real wood. I did not think this would be a hard task and I ended up wrecking the 3 pieces of mahogany supplied with the kit. At that point I acquired the additional 3/16" strips for practice and eventual strips. Dumb you get early Smart you get late 🙂
Also, it mentions using a fine backsaw. I would suggest starting with a fine backsaw, but the eventual cleft will be "too fine". For the cleft to show up better it is best to follow up the fine backsaw line with a thicker saw resulting is a thicker cleft.
Again, unless your wood is perfectly straight and you are really confident in making the cleft lines..... practice practice practice
Four strips of supplied mahogany
Resulting clefts in the beams and suspension stabilizers - after a lot of cursing and 'redo's
After painting them yellow
Here is my two cents.... I vote not to paint it. I build the Endeavour, and like your model the hull looked great. And to me, too great to paint... even the bottom. I know the hard core realists and going to cringe, but I really like the look of natural wood planking. But as they say, the only one you have to please is yourself (and of course CEO), so whatever you decide I am sure will look fantastic
For the wheel treads, instructions talk about using 1x5mm wood strips and wrap them around the outside of the rims. Problem is (and again it may just be my model) the wheel rims are about 5.5mm wide. So the 5mm strips will show a little gap. Instead I used black card stock paper (doubled over) and painted it will black gun stock paint. Looked pretty good in the end and was pretty easy.
Started with card stock paper and made three deep lines with a pen. 3mm, 6mm, 3mm
Folded up the paper on the lines and glued them together, resulting is a 6mm strip twice the thickness of the paper
Folded it over and turned over so the seam will be on the underside, glued it to the outside of the rim, and painted it black. Looked pretty much like a black metal rim
Instructions then call to cut two 54mm pieces and two 45mm pieces out of the 4mm brass strips to be used for the interior axle housings. Eventually these will be painted black. In my experience (and I am little more than a novice at model building) I hate painting brass. Even after using an etching primer followed by paint, while the result initially looks good, it does not take much handling (like actually installing the piece), for little pieces of the paint to fleck off. Based on my experience with the black cardstock on the rims, I decided to use this method on the axle housings.
While the instructions call for two 54mm pieces and two 45mm pieces of brass, in my model the axle housings were actually 60mm and 47mm. The width of these axle housings on my model were actually 5mm instead of 4mm. Before you cut these pieces, either out of brass or card stock, verify the proper length... and maybe a little longer.... You can always shorten them.
In this case, same as before. Line out 3mm, 6mm, 6mm lines, fold on the lines to make one strip and paint black with gun stock paint. From here you can cut the required strips for the axle housing.
Happy with the end result and a whole lit easier than working with brass strips
Next step is to add all the pins on both sides of each spoke - a total of 192 pins.... Since the pins are 5mm in length and the wheel is 5mm in depth, all 192 pins need to be cut in 1/2 - preferably a little shorter or the pins from each side of the wheel will hit each other. Just cutting these pins in half is a long frustrating task... pins are so small, and to cut them in half takes some real patience. After that you need to drill .5mm holes through each wheel for each pin. I would not suggest doing this with a pin vise. There is just no way to drill that many straight lines with a pin vise, and if the holes are not straight, the wholes on the other side will not look very good. In my case I used a dremel workstation to drill the holes. Instructions called for a .5mm bit, but I found a .7mm bit fits the nails better.
Also I used a special pliers made for holding pins. Between the jaws are a little hole to hold the pin. Trying to hold these small pins and drive them into the holes would be very hard with a tweezers or needle hose pliers. Here is the one I have
Not really in focus, but you can kinda see the hold to hold the pin in each jaw
After several long tedious sessions, all the pins were inserted on both sides of each wheel
I am really glad the wheels are finally completed..
- Canute, wefalck, king derelict and 7 others
10
I decided to take a break from ship building and try a "non-ship". In this case I selected the "Stage Coach 1848" from Artesania Latina. I choose this one over other stagecoaches do to it's 1/10 scale. A little bigger than the other stagecoaches and I (having fat fingers) I like the larger scale models. For those of you that want to follow along, this will be a very slow build. It will get completed, but I am not a very active model builder. I work on them as time permits, so it is going to take some time. I would suggest checking back every 2-3 weeks or so for an update.
Starting in, the first step is to build the four wheels. More or less a pretty straight forward task.
Assemble the wheel rings - four pieces each
In order to add the spokes, it mentions to use the "full size" diagrams to place the spokes. Problem is, and this just be the diagrams in my particular model, the full size diagrams are not entirely accurate as to the spoke placement. Notice in the two pictures below the spacing between some of the spokes are not the same. So if you lay the spokes via the diagram, the spaces between spokes will not be accurate.
The spokes are made from 4x4mm strips flattened (by sanding) on two of the sides and then cut into 69mm lengths (for the large wheels) and 48mm lengths (for the smaller wheels).
The spacing between most of the spokes are the same, so by using a compass, it is easy enough to find a correct size that will go all around the wheel. Once you know the accurate space between spokes it is easy enough to go around the wheels and mark where each spoke is to connect to the rim. For easiest spoke placement, I would suggest cutting a circular hole in a piece of 1" board to insert the wheel axle. From there the spokes will lie flat on the board and can easily be glued into the axle and onto the wheel rim
To insure each spoke is the exact same length, use a stop on the saw box. It will save a lot of time and insure each spoke is the proper length
Adding the spokes to the smaller wheels
and to the larger wheels
end results prior to painting
After paint and before adding the trim
- king derelict, Jack12477, gsdpic and 7 others
10
Thanks for all you comments...I appreciate them. For anyone who thinks they may be interested in the model, I highly recommend it. It was fun and I learned a lot along the way.
For those of you who would like to make the Chaperon and have it look more like the real ship,, I have included a couple links Brian (mbp01) sent me on the Chaperon. One link is a series of photos on the ship and other is a 3D Virtual Walk through. The 3D Virtual Walk through is especially neat as you can take a virtual walk through most of the ship. By the way, if you have not seen it, take a look at Brian's (mbp01) log on his build of the Chaperon. It is truly museum quality work.
Anyway... have fun and hope future Chaperon builders will find this log helpful....if nothing else, show you how not make some of my mistakes. 🙂
https://www.jensmittelbach.de/steamboats/chaperon/index.htmlChaperon Photos
https://search.library.wisc.edu/search/digital?q=chaperon&filter[facets][collections_facet~Historic+Steamboat+Photographs]=yes- Ryland Craze and yvesvidal
2
OK,,, back at it.... The end is near. Starting with the rigging... Used some black .25mm line. As you might imagine, it is a real rats nest of lines going back and forth holding up the smoke stacks. Somewhat of a challenge for me trying attaching each line while trying not to knock any of the existing lines. but eventually they were all applied Kind of hard to see the lines in these pictures with black lines against the black deck, but the plans accurately show where each lines goes, so not a big deal.
On to rigging the forward gang plank. Again a lot of lines in a small area. Plans are accurate as to where each line goes. Only real (shall we say) "excitement" was with the very last line. Swung my head around to fast and the magnifying glasses on my head accidently hit the gang plank. All the rigging, gang plank, and boom came crashing down. By that time (after a few choice words) I had been at it too long and too tired, and too cranky to repair it. Repairs will be the next day. I have found that about 2 hours of work on a model is about all I can do at one time. After that I start making mistakes (like this one). This time I had been working about 3 hours,,,,, and obviously it showed up with the crash. I will try to listen to my own advice more in the future.
On to the life boats. At this point all I really had to do was rig the gang planks. The life boats and posts were made earlier.
Brian made the suggestion in his build that the interlocking rings at the base of the post are a little funky and instead mounted the posts on a board and extended out for the hull. These boards are circled in red below. Also, the upper deck is wider than the lower deck (or at least that is the way it is on my model), so if you use the interlocking rings from the lower deck, the posts will extend out from the upper deck and will not be vertical. I liked the idea of mounting the posts on a board instead of the interlocking rings....
And with the life boats rigged I am going to "call it".... done ...... except for the base.... Over the next week I will figure out some sort of base. Its eventual home will be in a large display case that hold most of my models so it will be protected.
It has been a long journey and a real challenge for me as I am probably a below average modeler at best. But it has been fun....
At this point I am going to take a break from ship building. My next build will be the Artesania Stage Coach. For some reason that caught my eye and I looking forward to it.
Here are a few final pictures
Cathead and Brian
Thanks for your comments. I appreciate them... As for my lack of posting...I really should stick more to ship building.... Seems all sorts of other stuff pull me away, but when I have time and in the mode, I always get back to it. As I do enjoy the builds. It sometimes takes me 1 1/2 - 2 years to finish a model, but they do get done.
Here are the painted coke can smoke stack shields. They turned out OK
I am sure I am the last one to learn this, but I will mention it anyway. When painting coke cans or etched brass for that matter, in order to get paint to stick well to either surface, you really need to first spray on some sort of "etched primer". This primer as the name implies, somehow etches the metal as it is applied and leave a very good base for later paints. I have found (the hard way), that just using a normal primer and then the final paint over metal does not turn our very well. It looks great initially, but when trying to apply the piece to a model, frequently some of the paint flakes off. Sanding the metal with 400 grit and the following up with an "etched primer" and paint leaves a pretty solid finish. I just used a rattle can of etched primer from hardware store, but I have head others talk about an actual product for spray guns call "SMS Etch Primer" that is supposed to be very good at preparing metal for paint.
Starting working on the stern timbers and ran into a slight problem. Since I added the railing on top of the fence, you can not get the correct angle of the timbers to reach the vertical posts. Railing is in the way and there is no way to make the timbers match up with the vertical posts. Took a lot of humming and hawing, but about the only idea I could think of was to extend the vertical posts back over the railing as shown in the picture below.
With the vertical posts now even with the back fence, was not to big an issue to make the timbers line up.
Final result showing the stern timbers now lining up with the extended vertical posts. An other option, might be to have a break in the fence on both sides of the timbers. That might have looked better, but I did not want to destroy the already installed fence.
Started working on the hog truss posts and caps
Paddle wheel installed and cables. Rather than us the supplied thread I decided to us 22 gauge black wire. If you decide to use wire, 22 gauge wire fits the hog truss posts cap holes exactly. Turnbuckles have not been painted black
Black cable over a black floor did not show up on all the picture, but hog truss posts, caps, and cabling complete
Really nice paint job. And even smooth gloss finish... not easy to do.
Looks like I found an excuse not to not to work on the pilot house staircase.... Decided to finish up the paddlewheel...
After aligning the spokes with a piece of wood shown in the rear, I started to add three board to each spoke
just keep working your way around the spokes, until complete..
Now it is time for the staircase.... In looking a the picture earlier of the railing added to the pilothouse, I discovered I did not quite measure them correctly. They are a little high the horizontal beams and did not meet the top railing of the stairs.
As such I had to add an extension on to the stairs to meet the pilot house railing. In the picture below, the pilot house railing should (if build correctly) align with the top of the diagonal hand railing. In my case, I have a little extra on top,
Just needs paint, but all lines up with the skylight deck and the Texas roof.
With paint added,,,,
And attached to the hull..
As mentioned earlier, there was just no way I could create the tiny cones for the small smoke stacks. No matter what material I used, cardstock, paper, aluminum, nothing looked very good do to lack of skill on my part.
For the cone shaped shield for the large stack, I took Brian's suggestion and used aluminum from a coke can. The aluminum is very thin an easily cut with a scissors. Since the cone shaped shield was larger (more my size), they turned out OK.. I strongly suggest you use this method when building your cone shaped shield... At this point the cone shaped shields are just dry fit. After all the rings and crown are attached these cone shaped shields will be applied, primed, and painted.
On to the turnbuckles...As others have commented, the supplied turnbuckles are completely flat and cut out of the etched brass sheets. Kurt and others have made very elaborate turnbuckles that really look neat. Again, I made an attempt at it, but I just could not get the slot in the brass rod to be anywhere near smooth and not good looking at all. Instead I took the easy way out and just use 1/16" brass rod and inserted eyelets into each end. I would have preferred to use smaller eyelets, but these were all I had on hand.
No were near as elaborate as others have made, but to me they get the point across and look better than the supplied turnbuckles (shown below on the far left). Just need some primer and paint.
Any finally for this session, blackened the eyelets. Defiantly gives them that worn look.
Stage Coach 1848 - John Gummersall - Artesania Latina - Scale 1:10
in Non-ship/categorised builds
Starting to add the external planking on the carriage. Instructions calls to use CA glue due to the fact (I think) that the carriage is curved and easier to lay the planks. I like using normal wood glue. I used a side of a soldering iron to bend the end of each plank (to match the curve in the carriage) and then using wood glue and a large rubber band glued the piece in place. Laying planks on both sides of the carriage, wood glue does dry fast enough so that as you glue each piece, by the time you get to the 4th piece, the 1st piece is dry. So you can just keep going around the carriage laying each piece and not have to stop waiting for the glue to dry. I would highly recommend getting some sort of band to hold the planks in place while the glue dries. Really helps keeping the curved down for the glue to set up
Instructions do not call at this time to do it, but I thought it would be a good time to sand down the doors to match the curve in the carriage. Instructions call to do this in a later step after the carriage has been planked. Actually I probably should have done this before I starting the external planking. Anyway, with some 2 sided tape, a couple spare planks, and some clamps you are able to hold the door pretty close to where it will be in it's final position. From there you can see the curve of the carriage and sand down the door to match the curve. Basically looks at what needs to be sanded, remove the door, sand it some and then stick it back in the carriage and look at the curve. Only take a couple attempts to get the curve in the door to match the carriage.
Not a real good shot, but you can see the curve in the door matching the curve in the carriage. Before I do the final planking on the door, I may have to do some more fine tuning, but this is pretty close.
Status at the end of the day. Again, both sides of the carriage are planked at the same time. Working my way to the bottom. Once complete, I will work my way up to the top
