src
Members-
Everything posted by src
Phantom Henry J Gasser by jct - FINISHED - 1/24 scale
src replied to jct's topic in Non-ship/categorised builds
Oh......Popeye the Punster Strikes Again.😂😂 Nice work J. the repair and everything look great. Mark, those hangers are still there, every time we drive down to San Diego (a 4+ hour drive each way these days) I think about that story of the F4 pilots. Side note, apparently it is now a court marshal offense to fly under the Golden Gate Bridge. Sam -
Captain!! So good to see you makin' dust again. Well done. And the tattoos on the wrists, very smart of you. But, what happens when you look in the mirror, then your left is your right and your right is your left! Sam
- 48 replies
- queen anne barge
- Syren Ship Model Company
Jo, Here in the States you can get rubbing alcohol (isopropyl) at drug stores. Not sure what they are called in your part of the world wherever that may be. Its where we get proscriptions filled and first aid items here. It does work with the titebond 1 and 2, not so sure about Titebond 3 though. Oh Carl.... you are SUCH a puny man!!!😅 Sam
Jo, this chart will help you determine the correct pilot drill for the screw you are using. I am assuming you are using “jobber” type bits; regular every day drill bits from the hardware store not special tapered bits. Use the column that says straight bit. You can buy tapered bits later. https://www.boltdepot.com/fastener-information/wood-screws/Wood-Screw-Pilot-Hole-Size.aspx another way to choose a bit and I what I have done in the field is to eyeball the drill bit to the minor dimension of the screw threads. I am st work right now (shhhh don’t tell anybody) I’ll try to post you a picture of what I mean when I get home. And what the others said about soap/candle wax to lubricate you threads. Sam
Vossie, those look great to my eye! Kudos to you for wanting to do things "right." Something I have been trying to tell myself as I learn this hobby is to think of how far away scale-wise we are working on is. From 64 feet away I think those are quite convincing Under the circumstances you've done quite well and persevered, next build will be even better. Just my two cents for whatever that's worth. Sam
- 624 replies
- lady nelson
- victory models
I have been following this discussion with interest, silently, since I have nothing to add. I am always pleasantly surprised when a simple question turns into a completely different discussion, I never fail to learn something from all of you. Since the sails, or non-sails, has garnered so much discussion here is a link to where I found the image above, there is a hi-res version available for download if that helps. https://www.history.navy.mil/our-collections/photography/numerical-list-of-images/nhhc-series/nh-series/NH-54000/NH-54387.html Thanks Sam
Wefalck, Thanks for the input. The book was only $15 US and with my level of knowledge (read nonexistent) I am sure I will get something out of it. Sam
Russ, GRSJAX, thank you. Bridlecombe ordered. it will be in on Wednesday. Sam
Thanks Russ. Lees doesnt mention anything about a Fore Gaff that I have found yet. Would it be safe to follow the same proportions as for the Driver Boom/Gaff? The drive Gaff is 5/8 of the driver boom which is the same length as the Fore Top Yard. So following that I would make the Foresail Gaff 5/8 of the Fore Top Yard? Sam
'Morning, What are the names of the gaffs circled in red below, are they Trisail gaffs? I have another drawing of the Enterprise around the same period that shows none of these, how often would they be employed? I understand the gaff NOT circled is the Spanker or Driver Gaff. I am searching through Lees to work out my lengths and taper, so far I havent found any mention other than the Spanker, Driver and Trisail Gaffs. I am kind of assuming I would use the same length and taper ratio as the Driver Gaff. Thanks in advance. Sam
Rich, His parts really are top notch in my opinion. Take a look at the picture below. The block and dead-eye on top are Constructos offerings, the parts below are Chucks. The dead-eyes can be a bit fiddly to assemble but he has planed it out well, if you follow his instructions you shouldnt have any problems. I did have to open the holes up after I glued them up and tumbled them but otherwise no major issues. Now Chuck, if your listening, how about some belay pins??? 😉 Back to you Rich. Sam
- 1,133 replies
- model shipways
- syren
You wont be disappointed Rich, other than all the hard earned cash you will start sending him once you discover all the goodies he offers.😀 Sam
- 1,133 replies
- model shipways
- syren
Jo, Vossie got to the meat of if. Just take one step at a time, ask lots of questions and post pictures of what you are talking about. Someone will jump in with answers. Dont forget there are also the Shop Notes forums here. Building and Planking area will be your best friend. AS far as terminology goes, dont worry too much about it, it will come to you, I am still making Widgets That Look More Different Than the Last Widget!! Just try to make the parts look like the pictures. Again dont be afraid to ask questions. Sam
Jo, Plans are for studying not talking about..... Actually if you have a place to put them up on the wall that is really helpful I have found. Thats it Carl, tell her to screw the braces to the table top. What will her Better Half have to say about that?? If your other half takes issue with holes in the dining room table Jo, just tell 'em to talk to Carl, its his fault. 😀 Sam
That's half the fun;venturing off into the unknown! I feel you though, I struggle with the same thing on my build. Hang in there you will figure out something that works for you. Sam
- 624 replies
- lady nelson
- victory models
