3rd update! I managed to add my SuperCool avatar picture and downloaded Adobe Photo Express (its free and so far intuitive) to edit my photos. Searching MSW the sideways pictures problem shows up a lot and is possibly due to large file sizes so I decreased the bytes or pixels or whatever and heres hoping they stay upright. If you didn't guess I don't like computers and they don't like me. But a necessary evil.
I finished gluing in the bulkheads with yellow glue which seems to get everywhere but is very solid. Per the Hunt Practicum next step is to add the very thin aft/poop subdeck. First I leveled the top of the bulkheads by filing them flat; one I had to glue a strip from the subdeck "sprue" as it was too low.
Next I had to attach the subdeck to the curved surface of the bulkheads. The practicum has you push tiny pins through the top of the subdeck into the bulkheads, then pull them out once the glue dries. I tried a different approach- overbend the subdeck and hold it in place with rubber bands. So first step is bending the subdeck. When I built the Model Shipways LongBoat I spent so much time bending the planks by soaking them in warm water for a while, then rubber banding them to cans or glasses to impart a curve, and leaving them overnight to dry. They would usually end up curved like I wanted but took forever to dry, and whenever I clamped them no matter how dry they seemed they were always still a bit wet and would dent. Then they eventually dried out and shrank and left a gap.
So I decided to try the Chuck technique of minimal water used mainly as a heat transfer device and let heat melt the lignins. The thin subdeck is very flexible so bending it is easy. After spritzing both sides with a small amount of water spread evenly with my finger I used some string to tie the subdeck bent around a coffee cup.
Then I attached my blowdrier to the workbench (actually my woodworking sharpening station) with spring clamps, turned it on Low Heat and dried the water off. After the top part was dry I took off the strings and the back was still wet so I dried it by just holding in bent in my hand. As long as the heat isn't directly hitting your fingers its not bad and took about 10-20 seconds each side. And presto, dried with a nice curve. And I didn't have to leave it overnight. While this was a very thin piece of wood compared to some of the planking strips I hope this is a prelude on how much easier this method is.
Now that the subdeck was bent (overbent on purpose) I did a test run with rubber bands and that seemed to hold it in place pretty well so I forgoed using the tiny nails. Once fitted in place there were some tiny lift-ups that I added pencils to direct downward force and it all seemed to work pretty well.
And finally here are 3 pics of my finished MS LongBoat. Lighting in the basement is from the ceiling so it shadows the lower parts of the hull, another thing to work on. I felt that many model ship bases were too short, running from the stern to the prow, with the bowsprit sticking out waiting to be caught on something, so I made my base extra big. Maybe too big in hindsight it may overwhelm the model some.
Thanks for reading. Have a great night, Cisco
