Tony Hunt
NRG Member-
Everything posted by Tony Hunt
The guys sitting on a suspended plank servicing the engine with the rotating prop about a metre from their heads have some very steady nerves.
Great, I'll claim a 1/3 share of the victory. 😁
Pat and Jim, three fathoms of 1½ inch hemp rope (½ inch diameter) is surely just a length of lashing line, it's too light to be part of the rigging of a ship this size. Since the blocks are hook-on, perhaps it is just for securing them in the top if/when they are not rigged?
HMCSS Victoria 1855 by BANYAN - 1:72
Tony Hunt replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
First paragraph on Page 68 of the edition Eberhard linked.- 1,013 replies
- gun dispatch vessel
- victoria
Hi Pat, re the sewing of the hoops, I think Eberhard is referring to the two overlapping tapered ends of the hoop being sewn together, not the spaces between hoops. Re how the sail was attached from the reef bands down, I wondered the same thing. I assume the absence of hoops is somehow associated with the reefing process, although I can't see how. All the yachts I've sailed on have track runners evenly spaced all the way up the sail, they don't get in the way when reefing. More to understand, definitely. I'll have to track down some more of Kipping's treatises, they're really good.- 1,013 replies
- victoria
Thanks for the link. This is what he has to say (with regard to the Driver): Cringles for the lacing are made above the upper-reef on the mast- leech, 30 inches asunder : the one next the nock ought not to be less than a yard from the nock. These cringles are stuck two high in the strands. Based on that, the 32 inch spacing looks more like it than the 60 inch spacing.- 1,013 replies
- victoria
Do any of Robert Kipping's mid-19th century texts on sails and sailmaking have anything to say on this subject? Unfortunately I don't have any of his volumes in my library.- 1,013 replies
- victoria
Hi Pat Five feet apart does seem to be a lot for the eyelets, although Victoria was a fair-sized ship and the sailcloth and boltrope would be reasonably heavy grade materials, I'm sure. I'll have to take a look at the photos myself 😀.- 1,013 replies
- victoria
MONTAÑES by Amalio
Tony Hunt replied to Amalio's topic in - Build logs for subjects built 1751 - 1800
Light it up and start cooking! -
Hard to believe that's a kit. Fabulous.
- 355 replies
- vanguard models
- Sphinx
There's also a 1:400 card model available https://www.ebay.com.au/itm/221896517945
That's looking really good Steven. It looks to be about a foot long? It will be a very striking model when it's finished.
That's a nice drill set up you have Pat. Which piece of tubing did you end up using - looks like the thick-walled one?- 1,013 replies
- victoria
Thanks Dick, interesting. It does look there aren't any gains on those planks, although it is a little hard to be sure from the photos, as you say.
Ancient galley rams discovered - photos
Tony Hunt replied to Louie da fly's topic in Nautical/Naval History
Fascinating! That's going to leave a nasty mark when it hits the side of your ship! -
Druxey makes an interesting point about the "gain" at the ends of the plank making the overlap of the clinker planks disappear as they approach the stem and stern posts. It raises the question about when the practice of using gains was first developed? Did the Vikings use it on their ships? It's way outside the date range that I'm familiar with for shipbuilding practices, but someone must surely know.
I was thinking the same thing. If it was a waterline model, I think a photograph would be indistinguishable from the real thing. Amazing work.
NAIAD 1797 by Bitao - 1:60
Tony Hunt replied to Bitao's topic in - Build logs for subjects built 1751 - 1800
Incredible, exquisite, too close to perfect to be able to tell the difference.
