Mirabell61
Everything posted by Mirabell61
  1. Many thanks Carl Bob and Oystein, and all the "likes" Carl, right, trust the whole ship was well ventilated with all those vents, I do`nt know if there were perhaps electric powered ventilators somewhere in the line to enforce the airflow... Bob, thanks for your nice comment... Oystein, If possible, I like to avoid painting brass surfaces, it too easily looks like using plastic parts afterwards. An alternative would have been chemical blackening, but as I used soft solder with the rims and CA for securing the lid-hinges this would have given problems with the surface appeal Nils
  2. Hi Bill, presume you mean the rims of the skylight panel lids.... The rims are made by inserting 2,5 ² mm lead sockets (for conduct wire ends) through the drilled holes in the brass panel, and soldering these to the panel. The German word is "Aderendhuelsen", sorry do`n t know the engl. term. I also used these for all the hull`s portholes The remaining end at the rearside is then cut off, The skylight ports remain without "glassings" Nils
  3. Good work Peter, those copper plates look very nice, one can really see the nail-heads sunken flush into the copper surface... Nils
  4. Thanks Denis, yes, the already painted one was used again......, I put a rotating brush bit on my Dremel and carefully removed the paint and primer. Now there shall go a coating of clear varnish on the brass surface Nils
  5. Mike, thanks very much for your words, and also all the "likes" for clicking on... relating to the sailing on these liners, take a look at the "rolling mode" of the KWdG ( nickname : Rolling Billy) compared with the horizon at relatively moderate sea, trust many passengers had become seasick on those rides. Pic borrowed from the web... Nils
  6. Thanks Bill, sometimes I think its better that I did`nt know what all is involved with the build in the beginning, although it does`nt even look so tricky with this scratch build ....., but you`re right, I`m learning a lot of things "by doing", out of the necessity... Nils
  7. John, thanks for your nice compliment....., much appreciated.. I decided to mount the light lids in natural brass appearence (looks a bit more "technical" than a cover with paint). Had to carefully brush off the paint from the one I did upfront. Two of the skylights will show with open lids, and four of them with closed lids Nils
  8. a beautiful model Mark, very nice work to date.... and BTW, a happy birthday to you Nils
  9. Many thanks Keith and Glenn, and all the "likes"... Keith, doing the light lids in brass is quite time consuming, but decision was made, so push it through... Glenn, thanks for the greetings, and for looking in regulary, I`m pleased you like it.. Nils
  10. Thank your greeting and your nice compliment Martin, I`m very pleased if you look in regulary and you lke it.... the shipyard workers are looking for a place where they wo`nt be disturbed when having their lunch..... Nils
  11. Jack, thanks for sharing the overview of these boatstypes .... Nils
  12. Your fitting out of the decks looks superb Bob, Nils
