native one
Posts posted by native one
  1. Been working on the getting the ships steering put together,made up the pulleys and some scale rope, made the ships steering wheels drum and positioned it where it would be so I can get the rope tension right,everything seems to line up and now I need to make the tension pulleys that run down the side of the tiller ,I deviated on the plans a bit on the first set of pulleys that are right under the orlop deck,they called for them to be set parallel with the center line of the ship but everytime I put pressure on the line the rope jumped off the pulley,so I decided to give them a slight offset, now the lines run alot smoother back to the second set of pulleys. 20241225_193112.thumb.jpg.2311ba5cd0851f7f3d6b6bf7d55f8844.jpg20241229_163124.thumb.jpg.3636eb6b7fe515ecbd1ff22282e33340.jpg20241225_192843.thumb.jpg.2ddfb65cc596fa6af2c00b26ab616bf2.jpg20241225_192832.thumb.jpg.4b618c0299ed4f2d0637c8ba8b04ecbf.jpg20241225_192905.thumb.jpg.678a574a960f2df40133c9eb62e89c9f.jpg20241225_192900.thumb.jpg.3b416e4564c8f0eab41c2530382fda7b.jpg
  2. Before starting on the decking of the orlop I decided to plank between the waterway and spirketing in the stern of the ship,kind of a tricky task on the Mahonesa's because the waterway starts out nearly flat then makes a gradual climb towards the deck clamps,the bend of the planking in the stern area is so much that I had to make templates for every piece then cut each piece out of thicker material then sand in the curve top and bottom before fitting them in place.20231229_232942.thumb.jpg.8e8f72165626ee7e2c3d4aa20058312c.jpg20231229_232758.thumb.jpg.c1d48a961507caa4e31a34358d4dc567.jpg20231229_200210.thumb.jpg.c5b492dc33c4ea3cf8fed037be099619.jpg20231229_200202.thumb.jpg.8cba0fc60a34b148c6f782786fce2270.jpg
  3. With the deck down in the hold done,I can began building the storage rooms,towards midship the beams are two piece which are milled out then fine tuned with files,not very complicated work to be done but  i ⁹really have to pay attention to where parts of the deck beams cut thru the walls in places.20230311_214405.thumb.jpg.d32efaf00dfbeac831f0e717cc61c030.jpg20230312_143824.thumb.jpg.9120fd7dd3fe9bd322a782bafd37f5d7.jpg20230311_215114.thumb.jpg.a8654d06fd3c5e058998513b7bb2b465.jpg20230311_221324.thumb.jpg.84e996d87406e47eb680ff50375e8295.jpg20230313_223407.thumb.jpg.cb516f6b63b9a95d1919b212e2f4df37.jpg20230314_180247.thumb.jpg.ec87b269edbff6bdff4554d76a3f4035.jpg20230314_220225.thumb.jpg.214a2da2179f326bf081318c2be60e6b.jpg20230318_205912.thumb.jpg.a2a9649c2558e8c550aabd4fdb385b7a.jpg20230318_205937.thumb.jpg.401c80dba173cbb043b4857643b45ee8.jpg20230318_210020.thumb.jpg.9939ef09f330bf00e37dec30b78127b1.jpg20230318_210057.thumb.jpg.3ff4214c78f1e49c9bc548d0891def9b.jpg20230318_210115.thumb.jpg.4593f8765b295006c94c56e880df6ada.jpg20230320_215534.thumb.jpg.293892a937c8b729d1bbcdfeb252fd0c.jpg20230320_215544.thumb.jpg.39cdef6b75efc74e1f0c5c6ff17408b2.jpg
  4. Finally finished the pump well and mounted it permanently, there are two beams in the hold that go thru the pump well and they have to be placed so the front one is right in front of the mast when it is put in and the rear one that  the down tube for the chain pumps has to sit against,took me some time to get them exactly  where they go but I  got them,then I  moved on up to the front of the hold and installed the forward platform which numerous storage rooms will be built,and with the pump well in place I  was able to continue building the beam supports for the orlop deck.20230304_211808.thumb.jpg.dee6ad658424aace42213d70cc1cceea.jpg20230304_211821.thumb.jpg.574a0941360b5c1e0f1da403c01ac783.jpg20230304_211840.thumb.jpg.5b5a4a6344509b2035a1daced309b117.jpg20230305_222452.thumb.jpg.374ae90559b2c2b98874e4553493402a.jpg20230305_222624.thumb.jpg.c4b088aed8839a2aa5cffba00176bbf6.jpg
