Everything posted by John Ruy
Thanks for your comments, are you building the Bluenose II or the original? Here is a vintage photo of the original Bluenose just before it was sold. I’m trying to strike a balance, using the Bluenose II photos as a guide to my finishes but build her as the original. Do you have a build log posted? Cheers 🍻
- 282 replies
- Bluenose
- Model Shipways
Pumps and another Hatch… Up next, The Cabin… Details… Here are a couple of photos I took on board the Bluenose II. Cheers 🍻
- 282 replies
- Bluenose
- Model Shipways
Main Mast and Fife Rail… Laser cut parts for the Fife Rail. Did someone say “tedious”? Repaired… Next step, repair the knees. NOTE: Knees were on up side down. 😬 Love my new micro drill bits… Knees look better. 😆 Used paper strip for mast coat. Laser cut Boom Rest needed a bushing to fit the mast. Again, paper strip… Snatch Blocks… More “tedious” detail. Chocks for Boom Rest. Paint White with Semi Gloss Poly. Galvanized Metal Chafing Peace for Main Boom Jaws. Completed Main Mast Fife Rail. Next up, another Hatch and Pumps. Cheers 🍻
- 282 replies
- Bluenose
- Model Shipways
Yes, when the Dories were stowed they removed the Thwarts and Oars so the Dories could nest in a stack and then placed them in the last Dory to be stacked. No need to build more than can be seen. 👍
- 282 replies
- Bluenose
- Model Shipways
Only the two on top have been fitted inboard. I’m not that crazy. 😜 I do still have Sixteen pairs of oars to carve out and stow in the top of the Dories. John
- 282 replies
- Bluenose
- Model Shipways
- 282 replies
- Bluenose
- Model Shipways
- 282 replies
- Bluenose
- Model Shipways
- 282 replies
- Bluenose
- Model Shipways
- 282 replies
- Bluenose
- Model Shipways
Cathead remake… Below are photos of the Catheads on the Bluenose replica Bluenose II. After being in Nova Scotia and seeing the Bluenose II, I decided I needed to rework the Catheads. The MS kit supplied metal parts for the Catheads were just too small to look correct to me. Here is a photo of the kit supplied parts. I replaced the parts with my own build of the Catheads. Brass needed to be painted to look galvanized. I used Testor’s Flat Aluminum Enamel. I’m much happier with Cathead version 2.0. Cheers 🍻
- 282 replies
- Bluenose
- Model Shipways
The right tools can make all the difference in the struggles. 😜 Soldering Iron Premium Kit, 60W Soldering Gun with Ceramic Heater, 12-in-1 Soldering Tool, Adjustable Temperature 200 to 450°C, Includes Soldering Iron Tip, Solder Wire, Pump and Paste https://a.co/d/70GVtiS Cheers 🍻
- 282 replies
- Bluenose
- Model Shipways
An eBay search will yield many choices. Good prices🍻 https://www.ebay.com/itm/145275231804?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=cPgOyRMKSxK&sssrc=4429486&ssuid=saHjlWAtSV-&var=&widget_ver=artemis&media=COPY https://www.ebay.com/itm/394472180685?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=koWLSQuSTmC&sssrc=4429486&ssuid=saHjlWAtSV-&var=&widget_ver=artemis&media=COPY
You’ll get the hang of it, I did. I only post the success, plenty of fails before I got it right. LOL 😆
- 282 replies
- Bluenose
- Model Shipways
Eye Bands… Using kit supplied brass strip and brass nails, jigged up eye band per instructions and soldered. Note to self: buy a smaller tipped soldering iron. Drill eyes before trimming tabs. Eye Bands fitted. Easy? NOT! Paint flat black to represent iron. 2 of 17 eye bands completed. Should get easier with practice. New soldering kit order. Cheers 🍻
- 282 replies
- Bluenose
- Model Shipways
Corrected Coaming detail to Forward Companionway and Metal Band on Foremast Pin Saddle. Began working on Eye Bands for the Bow Sprit. 🍻
- 282 replies
- Bluenose
- Model Shipways
Your wheel holds up to photo magnification. 👍 As for the yellow you may want to try a poly sealer semi gloss to brighten up the tone. Looks good. 👍
- 129 replies
- Victory Models
- Pegasus
- 282 replies
- Bluenose
- Model Shipways
Foremast - Mast Coat, Pin Saddle, Gooseneck… Kit provided laser cut rings have to large of an inside diameter. Solution: drill out a 1/2” dowel with a 5/16” bit and slice two mast coats. Utilized the laser cut rings for the pin saddle. Carved chocks from a mahogany strip. Here is a picture of the gooseneck on the Bluenose II. NOTE: Oringinal Pin Saddle no longer there on the replica. Created the gooseneck from provided brass stop and wire as follows.
- 282 replies
- Bluenose
- Model Shipways
