Everything posted by John Ruy
I am looking for the best way to turn brass parts into chrome. I have just painted a brass propeller chrome with Model Master Custom Enamel System. Are there other products or methods out there? This looks good but will it work well for all of the small fittings in my Corel kit. Corel has supplied all brass fittings for the Corsaro. The photo above shows chrome for most of the hardware. Your collective knowledge will be appreciated. John
The Mahogany Rail continued… The stern planksheer is shown here as part 47. Unfortunately part 47 is 1.5 mm ply and the Rail is 2mm x 4mm solid mahogany. As seen here I will need to laminate the 2x4mm Mahogany to create this curved section of rail. The Rail or Planksheer as it is called out on the Corel Drawings and instructions, is now finished. Cheers 🍻
- 84 replies
- Corsaro II
- Corel
Hi Rick Agreed… Building the rails aren’t even mentioned in the instructions. I personally have not found any good instructions with the exception of Model Shipways New Bedford Whaleboat. That kit came with a book that was a build log of the prototype. It had very good instructions with photos it was written by the kit designer. That’s where I was able to improve my wood modeling skills. Most of these kits just aren’t assembly type model kits. I consider our “hobby” an art form some experience required. That’s why there are so many unassembled kits out there on eBay and in closets. Thanks for the opportunity, this kit is definitely challenging my skills. John
- 84 replies
- Corsaro II
- Corel
More sanding and another coat… She is coming along rather nicely, sure is a lot of sanding and painting. It’s getting there. Another sanding and we should be ready for the color coat. 😎 Cheers 🍻
- 282 replies
- Bluenose
- Model Shipways
One more coat of poly… Rudder… Cut from 1/14” pine lattice… Rudder fitted… Primer coat… Display stand painted Matt Black. I added felt pads to hold her hull. I could not bring myself to permanently attach this stand to this hull. Mahogany Rail… First coat of Polyurethane on short bulwarks and rail. It will need another coat or two. Onwards 🍻
- 84 replies
- Corsaro II
- Corel
It was an ink-jet printer. The water slide paper and acrylic sealer are readily available and MS Word has every font and word art to creat the decals. Vinyl Pin-Striping is a great way to add the striping, as well. John
- 84 replies
- Corsaro II
- Corel
Wow! Nice detail at this scale. Excellent Work. 👍
- 200 replies
- Whaling Bark
- Charles W Morgan
- 84 replies
- Corsaro II
- Corel
- 84 replies
- Corsaro II
- Corel
- 282 replies
- Bluenose
- Model Shipways
Decals and Strping… Decals produced in MS Word and printed on ink jet water slide decal paper. Bow markings and yellow striping. Stern markings… @rshousha Rick’s beautiful deck planking with its first coat of semi gloss poly. I’ll probably do another coat or two before I clear coat this hull. Cheers 🍻
- 84 replies
- Corsaro II
- Corel
Decking completed… …and Finished. Sanding the hull… Using an Acrylic Auto Body glazing and spot filler. The glazing worked well, you will want to keep it thin. It does sand easily… Ready for the paint booth with some Filling Primer. Cheers 🍻
- 282 replies
- Bluenose
- Model Shipways
It’s pin-striping for rc’s fuel resistant @rcmdrvr It also formed to the tight curve on the stern. You are correct Yves, I will be spraying on a Gloss Clear coat as soon as I get the yellow sheer stripe and Script completed. Photo courtesy @rshousha and the Italian Naval Academy. Thanks Rick. John
- 84 replies
- Corsaro II
- Corel
Finishing the Hull… I am using the above photos as my guide to finishing the hull of this impressive sea-faring yacht. I really want to get this right. 🧐 After 3 sanding and coats of paint, the final fine sanding is complete and we are ready for striping prior to the clear coat. Water Line striping completed… I am going to have to create my own lettering decals for the stern and bow. She is coming along. Cheers 🍻
- 84 replies
- Corsaro II
- Corel
- 282 replies
- Bluenose
- Model Shipways
Fore Deck planking complete… Used pencil lead to represent caulking. Planking complete… Cherry Stain applied to darken planks First coat of Shellac applied several coats will be needed. The Quarter Deck will be tricky. 😬 Planking is curved and tapered. I am planning to work from outer edge towards the center planks. If anyone has any tips, please let me know what works here. Onwards 🍻
- 282 replies
- Bluenose
- Model Shipways
Off the shelf, now that the Robert E Lee is complete. Planking the decks… Good progress on the Fore Deck… Feels good to get back to the Bluenose. Cheers 🍻
- 282 replies
- Bluenose
- Model Shipways
Thanks again for all your comments and encouragement. This model was my greatest challenge thus far. It certainly has been a pleasure to build. Gallery photos have been posted. Onwards 🍻
- 238 replies
- Robert E Lee
- steamboat
- (and 3 more)
Yves, Thanks for your vote of confidence. This one is of a larger scale than I have done before. Every detail will be visible. No pressure. 😬
- 84 replies
- Corsaro II
- Corel
Welcome to my latest build log. Picked up this beautiful kit from my new friend out of Montreal. @rshousha Rick has had this model on the shelf for the past 10 + years and wanted to find someone who would take her to completion. I have accepted that challenge and so, here begins the rest of the story. Here she is received into my home safe and undamaged via international shipment. After a close inspection 🧐 I found that time had not been kind to her deck. My first order of business was to remove Rick’s wonderfully installed deck furnishings and fittings to restore and finish the decking. I used Minwax color match filler to close the gaps and fine sand the finish. I then cut in the scuppers and hause holes. Prepared the hull for a few more coats of paint. Drew the waterline and masked to paint from the waterline up. And then waterline down… Ready for some more sanding and then a few coats of clear ploy to give her a nice shine. Rick, Beautifully done hull and decking. 👍 We are on our way to completion. 🍻
- 84 replies
- Corsaro II
- Corel
Flags and Decals… Done… Started this build just over a year ago. Time to build a case to display her. Thanks to all who pulled up a chair and encouraged me all the way. Onwards Now I can get back to the Bluenose. Rolling on up the river. The fastest Mississippi Riverboat, winner of the Great Race in 1870. 🍻
- 238 replies
- Robert E Lee
- steamboat
- (and 3 more)
- 238 replies
- Robert E Lee
- steamboat
- (and 3 more)
- 238 replies
- Robert E Lee
- steamboat
- (and 3 more)
