Everything posted by AnobiumPunctatum
Sorry to say, but this is definitly wrong. Suldelev I and III were found in the beginning of the sixtieth and the drawings of these ships were available. Also if you can not read the book, the drawings are very well researched.
Hi, there is a really nice book and planset about this kind of ships: Werner Zimmermann "Nef de Cinque Ports". Another good information is the drawing in Landström.
You only need to scan the body plan. Measure the length between the first and last station line in the sheer plan. Then measure the distance between the station lines to check and correct the first measurment. With this information you can draw the station lines in your cad-system. The offset between the station lines is the same. If you have scanned the body plan you can add it to your sheer plan and then the funny part can start. These are the steps I started my Triton drawing
Congrats for finishing this beautyful model. It's looking really wonderful.
- 433 replies
- open boat
- small boat
As always, it's a pleasure to follow your progres.
- 433 replies
- open boat
- small boat
I am a fan of the "Wappen von Hamburg", since I was a child. I read the book of Wolfgang Quinger in the 70th of the last century. I think the kit is a good representation of the ship, based on the older Höckel drawings.
It's looking really nice.
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Glenn, thanks for the really nice descriptions. This is very helpful for me.
- 778 replies
- cheerful
Today I found time to sand the first half of the hull. After removing the adhesive tape at the keel I have to sand a little bit at the stem. Those who can read have a clear advantage. 😉 If you see, I didn't follow Chucks advise, I simply overread this. So I copied the marks on the other side of the frames.
Wow, the cannons are looking great. I like the natural carriage. It will be a nice contrast to the hull color.
- 1,784 replies
- winchelsea
In order to be able to securely fasten the model to the stand, two recesses for nuts were milled into the keel board and two holes were drilled for M3 threaded rods. Today I glued the ribs into the prepared keel board. For the right-angled alignment I built small auxiliary constructions out of Lego bricks.
Die Kogge Von Bremen by kentyler
AnobiumPunctatum replied to kentyler's topic in - Subjects built Up to and including 1500 AD
The planks at the bottom of the hull are krawel planked. So I think it is a good idea, to add some real frames to your shell. -
With the plans from Werner Lahm, you have the best source you can find for the Bremer cog. I Will follow your build with great interest. The plans are also the basis for the replica's in Germany. I've published a pert of the foto's I did from the original ship at Modellmarine.de.
