Everything posted by AnobiumPunctatum
Really nice progress Chris. What glue do you use ? In the instruction manual Shipyard shows a contact glue (Pattex) and I was really surprised to see this. I am thinking to use Titebond woodglue. If the the weather is so worse as expected, I will start the build of my model today.
- 179 replies
- shipyard
- wütender hund
Gary, can you send me please a link to the figures? Do you know, if they have these also in other scales?
Translation help needed - Renaissance German
AnobiumPunctatum replied to Louie da fly's topic in Nautical/Naval History
I speak German, but I couldn't read the text. I think that this are an old dialect and letters. -
The stern castle of the "Kogge von Kampen" is based on a shipwreck which was found in Kamen Netherlands. It's showing an older type of a stern castle. I am quite shure, that the rest of the kit is based on "Kogge von Bremen" The cog "Wütender Hund" shows in my opinion the classic cog also with a stem castle. It's a generic cog model. Most historical pictures are showing the stem castle. There is always a discussion, of the Bremen cog was finished before they got lost, because she don't has this.
- 175 replies
- hanse kogge
- shipyard
Matthias from Berlin, Germany says Hello
AnobiumPunctatum replied to victory78's topic in New member Introductions
Willkommen an Board, Matthias. Welcome on board, Matthias. -
Really nice figurehead. You made a great progress in the last few month.
- 889 replies
ancre Coureur by cafmodel - 1/48
AnobiumPunctatum replied to cafmodel's topic in - Build logs for subjects built 1751 - 1800
Really nice progress, Tom -
After finishing the ensemble I got the information that the step between stem and knee of the head doesn't exist. There is a drawing in Steel's Naval Architecture, that shows this detail. I am missing this book in my library and follwed the design which David descirbes in the Swan Class series by my first attempt. Now I've reworked the comstruction:
Congratulations Karl for finishing this beautyful model.
- 87 replies
- royal caroline
- yacht
Actually, the weather is too nice to work in the shipyard... ...but a little bit I did manage to do this weekend. The two prepared parts of the "Knee of the Head" were carefully fitted to the steven and then glued together. Next, all templates were carefully removed and the fit was checked again. To make it easier for me to glue the Knee of the Head to the stem I drilled three holes of 2.0mm and fixed the component with brass wire. At this step the fit was checked one last time and some slight corrections were made. Now the Knee of the Head was sandes into shape. It tapers from the keel to the upper corner of the leading edge from about 10.5'' (according to SR 9.5'') to 7.5''; the trailing edge has a constant width of 10.5''. To transfer the measurements to the wood, I made small templates in CAD and glued them to the component. The stern changes its width from 10.5'' at the transition to the keel to 16'' at the top edge. I have also made a template for this. Because of all the sanding I forgot to take pictures of this stage of construction. The last three pictures show the finished ensemble. On the second last picture you can hopefully see the wooden dowels I glued to the model instead of the brass rods.
Thanks for the Likes. Today I prepared the "Knee of the Head". I have divided this one into two parts to make it easier for me to adapt to the stem later. First the chocks of the upper part were adjusted and glued together. For the caulking was again single layer cellulose used. To compensate for small tolerances, the templates were again exchanged for a single one after completion of the assembly. The main piece and the other components of the upper assembly were then added. The lower assembly was then adapted and assembled. The following two pictures show the current status: Since my vacation is coming to an end, the shipyard is now being exchanged for the home office. Nevertheless I hope to finish the "Knee of the Head" next weekend.
Further with the "Upper stem". There are only two parts that have to be glued to the lower part of the stem, which was already shown in the last part. The issue is complicated by the fact that even tiny angular deviations in the "Joint" lead to deviations at the upper end of the component. Aggravating is the fact that the component is about 1.7mm thicker than the keel At first I built a small jig, which fixes the keel during the adjustment work. To check the position of the components, a template was aligned on the working surface and fixed with adhesive tape. Thin wooden plates were placed under the keel to compensate for half of the height difference. Next, the two components of the "upper stem" were glued together. A little more material was deliberately left at the sides to compensate for the construction tolerances later. Then the joint between the new component and the "Lower stem" was adjusted with my milling machine, chisels and sandpaper until the upper end of the stem was in line with the template. Now the components could be glued together. The old templates were removed and a new template was glued and aligned. Finally, the stem was sanded into shape.
The description of my reconstruction you will find here. On Easter Monday the time had finally come. The keel of his majesty's frigate HMS Triton was laid. First the 5 components for the keel were sawn out. I have simplified the design of the joints considerably, as they will be completely covered later on by further components. I will continue to apply this principle during the further construction in order to adapt the building as far as possible to my craftsmanship. The first cliff that had to be overcome is the joint between keel and lower stem. I worked this out with my milling machine and chisels. After I had attached the wrong keel, the joints have to be dowelled. These dowels are a bit too big for the chosen scale, but I cannot draw pear wood thinner than 0.8 mm. I know that many modellers swear by bamboo, but I find pear on the finished model more discreet. I have simulated the caulking with single-ply pulp.
