Everything posted by Toolmaker
Good 'Hobby Quality' Metal Lathes
Toolmaker replied to tmj's topic in Modeling tools and Workshop Equipment
That is some fab work you are doing. Very impressive. If you haven’t tried this you might want to give it a go if you need very small turned diameters. It’s an old machinist’s method where you start with a larger sturdier diameter, one that won’t noticeably flex when you make the cut. I can’t vouch for wood as I never machined it professionally but I could take a .500 brass bar and machine a .020 diameter by 1 inch long. The tooling has to be geometrically correct, and of course it has to be on centre. You also have to hit the required finished diameter on the first cut as you certainly cannot take a second cut. I suspect with wood, you would need to take the grain into account. -
If it helps, I just tried this. Using the hand wheel method on the Sherline I drilled a .1875 (3/16) hole to a depth of .375 (3/8) in under 4 seconds. Probably the worst aspect is not the drilling, but the retraction. That always feels a little annoying but on the plus side the control aspect is very good.
That made me chuckle. Many years ago a colleague got his “S” and “Z” mixed up and sent the turret into the headstock on a fairly large (and expensive) cnc lathe at 3 metres per minute feed rate. The complete 10 station turret detaching and dropping onto the swarf conveyor had us all on our toes. -
Interesting. The Hardinge HC was often fitted with a similar attachment. I was a long time user of Hardinge machines in a past life and for small part, high precision, non automatic production work, they were probably unbeatable. -
Capacity and power? What size workpiece do you want to machine. What material do you want to machine and how much metal do you want to remove in a cut. Not withstanding, how much space can I dedicate to the machine and how much machine running noise is acceptable. If it’s true model making you want and it has the capacity (workpiece size) you need, then Sherline is a great piece of kit for the money. Sherline is way ahead of Proxxon and is excellent in all ways straight out of the box. It was my choice and they have to be imported to the UK making them considerably more expensive than you can get them for in the States. Take a look and see how well developed their whole system is. My decision was also aligned to me wanting to use my modelling machines in the house rather than a “workshop”. Hope that helps a little Paul -
I have managed to miss a couple of your updates Mark but enjoying catching up now. Glorious craftsmanship, really lovely. Those gratings look fab. An additional method that can work for large radius requirements (like the top of the gratings) is to put a fly cutter in the mill and then kick the head over. One side of the radius sweep will give you a concave and the other side will give you a convex surface. Just to mess with your head a little more, using a rotary table for the work piece, and then a fly cutter in a tilted head can produce convex/concave spheres. As I said, brilliant work mate.
It’s always a highlight when you post an update Mark and your latest is no exception. I became fully enabled recently when I made my purchase from Ancre. Le Rochefort, like yourself, will be my first scratch build, and the driving factor in that decision has been your fantastic effort. That said, I still have a couple of years work on my Winchelsea so you won’t be flooded with questions anytime soon. From our previous chats you won’t be surprised to hear that I have recently built three quarter galleries for Winchelsea, and I still have one more to do! Keep up the fab work mate, it’s inspirational. You definitely have a bitt of an idea.
Caldercraft Red Ochre
Toolmaker replied to scrubbyj427's topic in Painting, finishing and weathering products and techniques
Shown as available here; https://www.shipwrightshop.com/contents/en-uk/d22_Admiralty-Paints-Individual-Colours.html -
You likely know this but your support piece (the glued together planks) needs to be measurably thinner than the plank you are cutting. If not when you exert downward pressure with your fingers you will be potentially clamping on the support piece rather than the plank you want to cut. I cut my planks like you but I don’t use a packing piece. I also tend to make 4 or 5 lighter cuts rather than trying to cut it through in one go. This helps preventing any movement. I then finish with a sanding stick.
Pretty cool tool: drilling positioner
Toolmaker replied to CPDDET's topic in Modeling tools and Workshop Equipment
Here is another tool offering the same capability but using a different method. This one uses a fixed drill shank size but the diameter of the material is less critical. https://hobbyisthaven.com/pages/dspiae-9-in-1-assistance-bench-tool?utm_source=fb&utm_medium=cpc&utm_campaign=Jun+18th+Dspiae+Platform+–+New+landing+–+UK%26CA%26AU&utm_content=Photo1_+Medium&utm_term=UK%26CA%26AU&placement=Facebook_Desktop_Feed&audience=new_cust&utm_id=120228898377920471_v2_s02&campaign_id=120228898377920471&ad_id=120228898378080471 -
The link is to a short one page thread of mine showing simple “fittings” ideas. Those little spring clamps are used extensively. I find them continually useful with my ship building. Hopefully of some use Paul
Have a look here James. I think they do various sizes and it’s local. https://www.hannants.co.uk/product/CMK001
- 48 replies
Fractal vise on kickstarter
Toolmaker replied to DavidG's topic in Modeling tools and Workshop Equipment
1.2 inches for the standard version and 3.2 inches for the extended version -
https://www.kickstarter.com/projects/metmo/metmo-fractal-vise https://www.kickstarter.com/projects/metmo/metmo-fractal-vise -
Very enjoyable watching you develop your work on these miniatures. To remove the frustration of the fragile jointing on the masts I would default to soldering the joints. That would make them much more resilient to handling. keep up the good work Paul
- 39 replies
- Black Seas
- wargaming
Question re "Line Off"
Toolmaker replied to JohnWW's topic in Building, Framing, Planking and plating a ships hull and deck
Thats as inspirational as it gets when it comes to planking. -
Need thread about 0.1mm in diameter
Toolmaker replied to Doug McKenzie's topic in Masting, rigging and sails
Fly-tying line should cover what you require. I have been using it with diameters down to 0.05mm. I am in the UK so my sources are not relevant, but you will find plenty of US suppliers. -
Kit review 1:25 Drakkar ‘Oseberg’ V3 - Ships of Pavel Nikitin
Toolmaker replied to James H's topic in REVIEWS: Model kits
The advancements in wooden kit development are just fantastic. 1900 +, pre cut parts, over 6 kilo’s of wood, months of entertainment and all for around £200 sterling plus import. It’s a great review and the fact that Chris is prepared to stock it, further adds weighty kudos.- 14 replies
- Pavel Nikitin
- viking
methods for serving a thin rope
Toolmaker replied to georgeband's topic in Masting, rigging and sails
Hi George, I have recently done what you are asking about. I served various size ropes from 1.1mm down to 0.45mm. I served the 0.45mm using 0.05mm diameter fly tying thread. This thread is 1/9 the diameter of the served line and I thought that was acceptable. With a little practice It was reasonably easy using the Syren serving machine. For me the issue was seeing clearly what I was doing. For the fine threads I used a magnifier to watch the thread. This picture shows some practice, but the serving thread was a bit too fine, however it shows the idea. I am a beginner compared to many so open to criticism if I am doing wrong. I hope something here is useful. Thanks Paul -
Beginner - Rigging Tools
Toolmaker replied to nheather's topic in Modeling tools and Workshop Equipment
Only this week have I finished rigging my HMS Cheerful so I am still running warm. I see lots of good advice above, especially about not buying tools before you have a specific need. You will certainly need 1 and likely 2 pairs of longish narrow tweezers and something to cut the line. I did most of my work with good quality small sewing scissors. My choice of make was fiskars. I also used a scalpel when rigging blocks off model. I used a helping hands system extensively and would find life more difficult without it. Used for stropping blocks etc. For serving I used the Syren version with some modifications, but I didn’t bother with serving on my first two builds. I use the same modelling clamps for adding tension to hanging ropes as I use during the build. The only thing I haven’t seen listed above which I like to have on hand are collapsible eye needles. They make threading through blocks a real breeze. The link is a uk one but I am sure you will find them anywhere in the world. https://www.thecuriousgem.co.uk/needles/beadalon-collapsible-eye-needles-assorted-sizes.html?srsltid=AfmBOoouysXEk_rNhhoVnaP66KHRpxEinAGwkJmAlkwoT-bk1JPEYrgt Enjoy the hull build first, then you can concentrate on the needs of the rigging. Good luck Paul -
Congratulations on your superb effort. Thanks seems so inadequate in consideration of all the pictures and instructions you have posted here. I am about to finish Cheerful having followed your build log alongside the instructions, as it is your level of skill, and more importantly, your patience, that is my aspiration. In the New Year I will begin my Winchelsea adventure and once again, I shall be using your build log as my guide alongside Chuck’s instructions. Cheers Paul
- 840 replies
- winchelsea
- Syren Ship Model Company
Companies such as Dormer do drill sets down to 0.3mm which is a little smaller than number 80. These sets are readily available from various companies. Individual hss twist drills are easily sourced down to 0.2mm (-.008 inch). After that it’s getting specialised and prices start to take off. I’m in the uk so my links are only relevant to there. No doubt similar is available in the US.
