Mike_H
Members-
Everything posted by Mike_H
All that remains is to add the iron bands: reasonably straightforward using a method I saw elsewhere on this site - perhaps @James H - 2mm wide lengths of cartridge paper cut out. Tacked in place at 25 mm intervals on the after centreline of the mast using CA, wrapped around, trimmed to length, coated lightly with PVA, pressed on and held for 2 min. Scarcely a worry. Top tacked with PVA, seemed to sit square and parallel to the waterline (much shaping of the bibbs required at an earlier stage) Foremast swayed up! You can tell, I insist, that the mast has been tapered to take the cheeks And herre that the top sits on the bibbs You can even get vertigo Back when I have done another one or two.
- 109 replies
- snake
- caldercraft
Fore Top Quite a lot of fun to build, but surprisingly labour intensive. The Trestle- and Cross-trees should slot together but the slots need to be machined out. Two pieces of original thought required. I laid out the battens at 30º intervals radially around the centre of the mast - I'm not sure what the real-life arrangement was. To erect the rail along the after-edge I cut the supports 3 mm over-length, and then turned the bottom 3 mm to a 1.5 mm diamter, having drilled 1.5 mm holes along the after-edge of the top (you can see the circular supports on the underside). The supports then slotted-in as round pegs into a round hole. The rail itself I then marked up and milled 0.3 mm deep slots to take the tops of the supports. In the photographs you can just see the rebates to take the supports. Once glued it seemed remarkably strong And here it is painted and with the ringbolts and blocks installed.
- 109 replies
- snake
- caldercraft
The sun has been out so I've been indulging one of my other obsessions - riding a bike around the Peak District. I've also combined my engineering obsession with model ship building and bought a Proxxon MF 70 mill so I don't have to battle with filing flats, among other things. I decide to really go engineer and draw up what I needed to do: According to Petrejus, the cheeks are closer together at the top of the mast, so the amount of material to be removed, or rebated, increases the higher you go. That means that the shape of the "flat" to which the cheeks are attached is not rectangular, and so, of course, nor are the cheeks. Those provided with he tkit vary from 4.2 to 6.2 mm. Using the equation at the top of the sheet, to make a flat of width a, machine down a depth h (where R is the radius of the material). that means that at the top of the cheek, the rebate is 1.5 mm and at the bottom 0.6 mm. But before that the square tenon at the top must be machined, by reabating 1.17 mm Machining the cheek flats was a challenge for the first use of the machine, but here's the rough finish Once sanded it looks just fine. A bit of cartridge-paper work to do, and then I can show the finished product.
- 109 replies
- snake
- caldercraft
Lovely to behold, James. As Chris says, you really are doing the magnificent kit justice. (Aright, he didn't say magnificent, I did!)
- 355 replies
- vanguard models
- Sphinx
HMS Snake by BenD - Caldercraft - 1:64
Mike_H replied to BenD's topic in - Kit build logs for subjects built from 1751 - 1800
Very nice, Ben. I particularly like the ironwork on the companionway and you obviously have something grand planned for the rigging of the guns. To say nothing of the rigging thread. Is it possible, do you think to make parcelled rigging for sale? If so, there would be quite a market even at astronomical prices. Just a thought. -
Ah... it does. Delightfully, it's the inverse of your jig for shaping your hatch-comings on Snake. I'm currently sitting in a Zoom meeting, which gives me enough time to go full-engineer on planning out my next stage of my Snake, so if it goes to plan, I'll post calculations, sketches, workflow and final result. Fingers crossed. I must say that your advice philosophy of "thinking ahead and not sweating the small stuff 🙂", is just what I strive for. The paradox is that thinking ahead is all about sweating the apparently small stuff!
That's kind of you. By coincidence I have just spent an hour reading through pages 12-15 of your Snake log to see how you dealt with masts and bowsprit - particularly in connection with shaping. Very enlightening. Think I'm about to explore the wold of serving On the design of your planking jig, two things occurred to me: are you an engineer by any chance? (I am, and am in awe) The spreadsheets and jig-making say yes. But delaying to now to get a digital calliper says no (I expect I'll buy another as I need one in the shipyard (spare bedroom) and the spar factory (garage - think UK, 8 ft wide, no possibility of a car in there). And then the second point, how does the jig work for guiding the sanding? Asking our of interest because I cannot imagine having the craft skills for this (and besides I could spend more money and attach CNC control to my Proxxon mill)
Well, the hull is pretty-well done. The chains and dead-eyes will wait until I have the masts marked up, so I get the lines for the shrouds right, and the boomkins look a bit delicate, so they will wait as well. All was fairly straightforward, just required time and patience. The supplied gunwale rail for the stern had a noticeable curve, which I did not manage to crate wen planking so I machined my own using my new Proxxon toy. To celebrate this milestone I got the proper camera out and rigged some lights. Here are a few pics for posterity (with a dummy bowsprit).
- 109 replies
- snake
- caldercraft
I meant to add, I'm happy for you that your health allows you to work up to retirement. My retirement is now 5 weeks away, and I see some ship building on the horizon...
- 53 replies
- brig-sloop
- Caldercraft
Hi, Masts! I'm getting close to completing the hull, so should be with you fairly soon. I bought the DB 250 lathe, and the MF70 milling machine. Made a few sample pieces and they went well. I bought the dividing plate for the mill which makes machining hexagonal and square sections very precise and enjoyable. Will be machining out the slots in the bulwark rail in the next day or two so that will be the mill's first real job. Mike
- 53 replies
- brig-sloop
- Caldercraft
Hi Sjors. I missed this update. Good to see you are progressing. I’ve managed to sneak two Proxxon tools into the house! Mike
- 53 replies
- brig-sloop
- Caldercraft
And very, very nice they look, too. Will you be documenting the rigging, as well James? Having just spent a day at Portsmouth Historic Dockyard, can I say that this model would look entirely at home in the museum there. Exceptional work by Chris and James.
- 355 replies
- vanguard models
- Sphinx
This would be so much easier to discuss in a pub!
- 355 replies
- vanguard models
- Sphinx
Well Glenn, I think there is a point about a model design being time-efficient for the modeller. I can see no basis on which I could find enjoyment in cutting out gun ports through splintering stripwood that I had spent hours - days - getting just-so. Nor is there a lot of fun to be had in working out the extent to which the instructions has the assembly sequence wrong, or the drawings being nominal or indicative rather than instructive. And I don’t think that view differs much from what @ERS Rich was saying. It’s not so much about time saving as about be able to use time where it is most necessary. For all that, I still want to build a kit, not assemble it. And my word I want to build this one!
- 355 replies
- vanguard models
- Sphinx
Just spent a very happy day at Portsmouth Historic Dockyard - torrential rain, but that just meant staying below deck, and in clear spells going “upstairs” or into the museum. Spent my time looking at details with a view to informing modelling. Some of relevance to Snake, others for the future. These are from Warrior and Victory, with one from the museum. When I rigged the breechings, I followed the books on how to secure them to ring bolts. Didn’t really believe that a single knot with a little seizing would be strong enough, but seems that is what is used: Here’s some more carronade rigging - though the breechings seem a little loose Petrejus says that the bits had copper caps and ends… I rigged a galley flue just like this: I want a binnacle, just like this, but can’t fit it in But I can have an elm tree pump like this The new ( to me, anyway) access to the dry dock means you can see things up close. I had wondered what the horseshoe is for, now I know: But gudgeons and pintles - entirely familiar Have occasionala thought of rigging some boats for Snake. Beautiful set of models in the museum. Here’s one
- 109 replies
- snake
- caldercraft
Hi, I've built on your super-sauce and started a thread on the topic. You get the credit!
- 222 replies
- First Build
- Lady Isabella
The ropes certainly look very fine. Best of luck as a trader. -
Aha - and he has shown a photograph with an entirely sensible explanation. But why did/does she have only 3 (more) per side? Mike
- 355 replies
- vanguard models
- Sphinx
Oh my giddy aunt! She looks absolutely magnificent, and the detail seems extraordinary - much more than I would expect from a 1:64 model. I’m sure that I won’t be able to resist, even with 20% VAT. And while that 20% price hike might seem bad news for us in the UK, it is great news for model ship builders as it’s a sign of Vanguard prospering. But a question: the closed gun ports are obviously shown with port lids (or they wouldn’t be closed). Why are there no port lids on the open ports? Mike
- 355 replies
- vanguard models
- Sphinx
Welcome. The model looks great - even upside down. I don't think you can rotate them using the forum's tools, so you need to do it at source - on the camera or phone you took them on, or on the computer they passed through. Mike
Great to see the painting develop as you go - I particularly like the extra vessels appearing at the end. And of the painting itself the background landscape is incredible. I like the graffiti too - Vega and Kilroy.
