Everything posted by GGibson
As a relatively new amateur, the video presentation is amazing, very impressive, in my humble opinion. I will leave the greater analysis to those that are historians of the Royal Navy and the Battle of Trafalgar. Looking forward to reading more details from fellow hobbyists as you dive into this massive project. Best wishes! Fair winds and following seas!
GGibson replied to mtbediz's topic in - Build logs for subjects built 1751 - 1800
Planking looks really nice. I see your tick marks on the bulkheads and you mentioned having to taper some of the planks at bow and at stern. Are the tapers going according to how you planned them? -
I probably fall into that "lurker" category, as well, Evan. I've got the Titanic in my shipyard, but may never get to it. In case I do, though, I'm paying attention to as many build logs as I can! Great work on yours, sir! Carry on!
Ahhh, ok. Thanks. I'll stick with what I am using then. Watching all your rigging and above deck work with bated breath... or, since the Bluenose is a fishing vessel, perhaps it should be baited breath... <shrug> 👍
- 282 replies
- Bluenose
- Model Shipways
Thanks for that info! Truth be told, though, the UPS and Fed Ex deliveries are outnumbering the other guy... <shrug>
- 282 replies
- Bluenose
- Model Shipways
At least he's not sleeping on the bench! <shrug> 🤣 The Bluejacket case option sounds nice! Thanks for that info, Helmarsowick! I've got a local cabinetmaker that does awesome work, he recently custom built our entire kitchen, so I will probably visit with him when I get to the point of wanting to case my ships. The first three ships I have done are simply being displayed (proudly, nonetheless) on the fireplace mantle. EDIT: And I just noticed you have your Constitution in the foam cradle (which I also use), but sitting on a lazy susan turntable! I'm sure others have done this, as well, but it's an awesome idea! 🏆
Ha! Yeah, I'm sure I'm going to forget a necessary eyebolt somewhere that will be critical for rigging and will be a PITA to get to as the deck gets "busier"... <forehead slap>
- 184 replies
- Bluenose
- Model Shipways
Ahhh, I'm paying serious attention to your metalwork! I am not good at this. Hey. I love your desktop vise! I assume the base is super heavy in order for it to stay in one spot while tugging while clamping and tugging? Mine is fairly mobile and handy, but my wife would love seeing another front porch delivery dropoff! Where did you get yours? A new tool!
- 282 replies
- Bluenose
- Model Shipways
A few more small updates... As mentioned previously, I gave the hull several "seal coats" using the Minwax Wipe-On poly. Nice and shiny! Before sealing the deck and some of the box structures, I needed to finish the skylight. As I did with the other boxes, I used some 1/16" thick basswood sheet stock for the base, the walls and the top. As I've done on the other deck structures, I added some scrap stock to the inside corners for stability. Stained the base and top and painted the walls white. Drilled a 3/32" hole in the port and starboard sides. It was now time to position all of the deck structures completed so far on the deck, get them glued down, and seal everything. Made sure everything set nicely to the contour of the deck, and PVA'd each structure in position. Two coats of Minwax Wipe-On Poly were brushed on here, as it was hard to get into some of the tighter areas. All in all, looked pretty sharp. Now it's time to knock out some of the smaller deck pieces... Fore Boom Sheet Buffer - I had already done the main BSB when putting in the aft main rail, because of the tight space underneath and, at the time, had cleaned up and painted the fore BSB cast metal piece black with the gold ring on top. So, just needed to assemble the laser cut pieces for the little shelf that covers the BSB. Painted the shelf white, drilled holes in the deck close to the great beam, inserted the Boom Sheet Buffer, and glued the shelf above it. Main Boom Crutch - Laser cut piece for the vertical stand. The base was made from a 1/16" x 7/32" piece cut 3/8" long. Drilled partial 1/16" holes for the notches in the bottom of the stand to sit in when assembled. Stained the base and painted the stand white. Glued the base to its location on the deck behind the wheel box and in front of the main rail, but will not place the stand into the base until later, as it would be a prime candidate for getting knocked over by an errant arm swing while doing other things on this busy deck. Bilge Pumps - I flattened the bottom of these castings with my Dremel, drilled a hole in the bottom and inserted a 1/32" brass rod to make it easier to secure to the deck. Dropped in some white distilled vinegar to clean, then primed them and painted black. Drilled holes in deck and used CA glue to fix onto deck. Quarter Bits - Used 1/8" square stock. Although plans mention using wood, I decided to use brass rods and keep them brass colored. Also placed 1/32" brass rods in the bottom to help secure to deck. Galley Stack - Same as the bilge pumps, I cut off the bottom piece of the Britannia casting using the Dremel to make it flat, and drill a hole for a brass rod. Cleaned, primed and painted black. Stern & Bow Chocks - Cleaned, primed, painted black and placed using CA glue. Main Sheet Lead Block Horse - Used brass rod, drilled holes just in front of main boom sheet buffer and behind main boom crutch base. Jumbo Jib Sheet Traveler Horse - Same procedure as the Main sheet horse above. This one sits just ahead of the fore deck mast hole. A few fun little pieces to knock out. Next projects will be to assemble the fife rail and to work on the catheads. From what I have read on others' build logs, the catheads could be a challenge. Always appreciate the drop-in peeks, likes and comments. The advice I have received so far has been awesome and much appreciated. Supposed to be in the 70s in Kansas City for the next week or so, so may try to get outside around the yard before it gets colder heading towards late fall and... ugghhh... winter.
- 184 replies
- Bluenose
- Model Shipways
Yes, the work you've done on the sails really do accentuate the deck and the entire ship. Done very well, sir! I've been discussing on my Bluenose log that I'm wrestling with how to finish rigging and attaching sails once I get to that point and am really leaning towards a furled sails presentation. Not sure I can hang the sails as well as many of you have done. Your gift consideration to a colleague is similar to what I have been thinking about. My son gave me this Bluenose kit as a gift some 16-17 years ago, and after attempting a build as a newbie, I got frustrated and it ended up in a closet. Well, after retiring and finding this hobby with a few smaller builds under my belt, I've now been working on that Bluenose. My plan is to give it to my son upon completion, except that he now lives in South Florida and might be difficult getting it to him! If I finish it during our Kansas winter time, though, it may be an excuse for a long drive... You are almost done with your Bluenose! Congratulations!
Great Photo Etched Saw Blades
GGibson replied to kurtvd19's topic in NAUTICAL RESEARCH GUILD - News & Information
Ahhhh, and these guys are practically in my backyard! Well, technically across the river in another state... but they're close! -
Welcome, Marco! Wow, awesome work on what you have done! I am pretty new to the ship building community, as well, so I can't identify all of them. What is the third from last ship with the white lower hull? Beautiful ships!
You are ahead of me in your build, so I will be paying attention! 👍☘️
- 184 replies
- Bluenose
- Model Shipways
I was the one who asked the question in yesterday's NRG Virtual Workshop, Kurt, and thanks to all for the additional links and suggestions! I've had MicroMark's larger Miter Box for Razor Saw (micromark.com) for a long time, but was intrigued by the "compactness" of the one mentioned yesterday. Appreciate the follow-up, Kurt! And others! -
John & Bill - Thanks to both of you for your input! Always appreciate others' viewpoints and experiences! Regarding the furled sails discussion, I am sure you have both seen, as well, the archived MSW thread from back in 2013-2015 about furled sails - Bill, he does mention considering silkspan in his opening thoughts, but used some muslin fabric. However, later in the thread, he says he'd use even thinner material the next time, so perhaps, as you suggest, some silk handkerchief or tissue material. I still like the idea of doing furled sails with something like that. In doing a quick search, I see that Bob Hunt (Lauck Street Shipyard) has a tutorial, as well, on making silkspan sails, and there is at least one MSW thread (this one from April 2021) on silkspan sails. Thanks for that suggested option, Bill! With that said, I also agree with John's comment that placing the ship on a launching way display would not be right with the masts, sails (furled or not), etc. So... I'm thinking of perhaps some type of "ship at the dock" type of diorama? Or, I'll just put it on two pedestals... 🤣🤣🤣 Again, thanks for the discussion and advice, guys!
- 184 replies
- Bluenose
- Model Shipways
Yes! Furled sails have been a serious consideration! The pictures you shared of the Bluenose II and the pictures from the Nova Scotia Archives (Nova Scotia Archives - Bluenose: A Canadian Icon) have been really good in showing how the sails look when down and furled. For historical accuracy, I believe I read that much of the Bluenose rigging was done after it was launched and in the water. So, not sure that furled sails or even substantial rigging without sails as it sits on the launching way would be correct, but... <shrug>
- 184 replies
- Bluenose
- Model Shipways
