BranPie
Posts posted by BranPie
The OcCre supplied thread is terrible. Your first attempt is already a marked improvement.
On 3/3/2022 at 2:44 PM, The Gimps Chimp said:I've just got hold of a crude 3D printed ropewalk...
May I ask which ropewalk you used?
I just like the name "the necessary". 😊
Looks great already, toning it down will probably be even better.
Hi, Ilia. Thank you for the compliment. I'm just doing the best I can, with the kit and, more importantly, with my skillset.
Now, before I answer your questions I would like to repeat that I am no longer following the instructions, so be careful following my advice, I don't know what kind of trouble I might have got myself into 😁
And now, some answers:
- I'm tapering the planks, but only to the bow (use a very sharp blade and do multiple passes with very little pressure, if not the wood will just split following the grain) . At the stern you can keep the planks (strips) full width. At this point I'd advise you to measure really well before you start planking. The instructions tell you to start planking with the sapelli strips just beneath the bulwark pattern. I did this without thinking too much about it. The result is that, at the widest point I now have 15 strips and 3 mm I need to cover with sapelli strips. Those last 3 mm will not be easy... If you measure well, I think it should be possible to go with 15 strips and stop there. Those remaining few mm would be covered by the wales anyway.
- I don't use any bending method. Lengthwise the 0.6 mm strips bend very easily. I tried edge bending them with a few techniques but the strips just warp. So this is the technique I use; I start from the bow with about 5 mm of CA gel and 20 mm of PVA. I position the strip at the stem, and hold for about 20 seconds for the CA to grab. Then I hold down on the PVA, being careful to apply pressure on the whole strip (it warps from the moisture in the glue) and to push (or pull) it against the adjoining strip. After that I work myself all the way to the stern in 50 - 100 mm segments. I always work with PVA (just personal preference). The planks will tend to warp when you follow the curve of the hull, since I didn't succeed in edge bending the strips I overcome this with glue and pressure.
- I answered your last question above 🙂 If you use CA, be sure to use the gel type. The runnier types will soak through the strips, your fingers will get stuck and it's going to look like **** (don't ask me how I know).
If you like I can add some pictures later to make things more clear. I'm stuck on my smartphone now so it's a little fiddly to do that now.
I can say that for the 0.6 mm strips you get in this kit for second planking, you don't need a tool. Edge bending proved impossible (the strips just twist) and in the other direction the strips bend very easily.
That said, I'll be buying some kind of tool to aid in bending for my next build. Haven't been able to make my mind up on what to get though. I've thought about getting one of those adapted soldering irons and then buying some soldering tips to go along with it...2 tools in 1...
Well, I've been out of the game for a while, but here I am with a - long overdue, and rather long - update. At first I just didn't have much time for modelling due to work in the house/garden. Then I didn't feel like working on my model because I wanted to be able to spend more time with it to properly get my head around how I wanted to tackle second planking (pretty hard with a 2-year old running around the house). After that my perfectionism got the better of me; I wanted to do a whole lot of things, most (or all) of which I lack the skill or knowledge for... And so I just did nothing. By this time it was September and I had to go back to work after the holidays and ... I just couldn't. I'd worked myself into burnout, which in retrospect seems very logical, but at that time it came as quite a shock.
Anyway, I'm feeling much better now, ready to go back to work in a few weeks time. And I've restarted work on my Polaris about a month ago. It's slow going but it's going, and I feel good doing it (most of the time). So here comes the actual progress report.
First I needed to prepare my hull for second planking. This required some filling (not all that much) and quite a bit of sanding. After that I planked the transom (?) and did some touching up at the corners of the stern fascia, which I snapped of twice 🥴 during first planking.
At this point the instructions tell you plank the transom, stick the second layer of planks anywhere they'll go and then fill the gaps with pointy pieces you cut to shape, then trim back where necessary and install stem, keel and sternpost. I decided not to follow instructions... I'm not quite a that point where I'm able to tell if that was a good idea or not ... 🤞
So, at this point I installed stem, keel and sternpost. These were a bad fit and left significant gaps between stem en keel and the different pieces that make up the keel. I decided to fill these. A test with filler and dye (the "walnut" keel needs to be dyed, which is a good thing because the wood quality is ghastly. It's basically a very course ply with an even courser veneer or possibly even just dyed ply, I'm not sure) revealed that I didn't like the look of that. So I cut tiny pieces of the "walnut" board and inserted them into the gaps. Not perfect, but you'll never see it if you don't know it's there, so good enough. Sorry for the terrible pictures btw, they're taken with a simple smartphone camera, often in bad light...
Then on to second planking. First transom and stern fascia. I added my own touch with the diagonal strips, just thought it looked good.
Then I lined of the hull, divided into 3 times 5 strakes and proceeded with planking. Managed to set my first strake about 1 mm high
(both sides 🤪), so I'll have to solve that problem somewhere along the line... Also wanted to try planking with scale length planks instead of full length strakes (perfectionism, so tiring) and shortly after that I REALLY wanted to bin the whole thing. There are no 2 strips alike in this kit. They vary in width, but worse than that, nearly every single one tapers from 4.5-5 mm at one end to 5.5-6 mm at the other end. They are also very dry, hard and very brittle so there isn't much you can do with them because almost anything you try, they split, or a piece just breaks off, or ...
Luckily (?) I was able to restrain myself, and just put the model away for a week to regain my sanity. I adjusted my expectations, discarded to idea to rip of what I had and buy new stock, decided to plank in full strakes and here we are: 5 strakes done (both sides), 10 (and a half) to go. And I'm actually pretty happy with the result AND enjoying myself again. Hopefully next update will follow "soon".
- BobG, AJohnson, GrandpaPhil and 3 others
6
I think I've already read just about every Vanguard kit log there is, including your prototype builds
I like the kits, I like the fact that they're all the same scale and I like the fact that they seem to be easy (relatively, of course) to build but offer enough options to personalise and expand on.
The only thing holding me back, really (apart from finishing my current kit), is that I'm afraid my skill is insufficient. But then again, I'm learning now that you can't acquire much skill with the kit I have now (apart from dealing with frustration 😁) anyway so should probably just stop worrying... 🙄
On 8/12/2021 at 3:21 AM, Bob Cleek said:
In my opinion, the best way to learn is by building a challenging, sophisticated kit that has good instructions, rather than a "dumbed down" "beginner's kit" with inadequate instructions.
I couldn't agree more. I'm on my first kit, Polaris from Occre, and whilst it is indeed a good beginner kit in that it's simple, it is also uninspiring and often frustrating to work on.
The cheap materials (especially the "walnut" ply which has the tendency to crumble as soon as you touch it and the 0.6mm "walnut" strips which are so hard and brittle that it's nearly impossible to do anything with them) are really no fun at all to work with. The instructions are simplified so much that if you follow them you don't learn to plank properly (and if you try the wood quality drives you insane (this is where I'm struggling now, I almost binned my model last week) and you don't learn to do rigging properly (I've decided I'm not going to try on this model, I just don't have enough knowledge to make something of it).
So in the end, at best, you end up with an OK model... I'll be putting much more thought into what my second build wil be. The Vanguard kits are at the top of my list, because they seem to have excellent instructions and are designed so even a beginner can achieve a good result.
- mtaylor, Ryland Craze, James H and 1 other
4
I'm building a polaris myself and had the same issue with the bent spine. Attaching the deck won't cure the curve (I assumed that too ☺️) . That said, it isn't that bad that you can't just continue your build. Polaris is a good starter kit in the sense that it's relatively easy to build, but issues with material quality do sometimes make it frustrating. If you like I can post some pictures of how mine looks now; I'm almost ready to start second planking and (since I'm not following instructions anymore) have the keel already attached which makes the curve very visible.
Oh, those are beautiful! I think at least one of them will be be on my “to do” list…
- mtaylor, Canute, thibaultron and 1 other
4
Well, I'm only on my first model (which will take me quite some time yet), but I've already decided my next model will be from Vanguard. Partly because I want to support you, partly because your models look great!
(I've actually got a whole plan for which models I want to do next including almost all Vanguards 🙂, but hey, at the rate i'm going that's probably more than ten years worth of modelling so we'll see about that 😃)
Congratulations on your 2 year anniversary, you have done some great work!
- austristan, Canute, chris watton and 2 others
5
Looking good! My Polaris has - for now - come to a complete standstill. Work (and other things) have been too much lately, so come the evening I just can't muster up the strength to work on my ship. Seeing your second planking go on is really triggering my will to get started on mine though! 👍
I'm glad you didn't keep us waiting, because that is just stunning!!!
- mtaylor, Keith Black, chris watton and 2 others
5
Looking good. And you're making good progress.
Just wondering... I see you're based in England. Did you buy directly from the Syren website or is there a European distributor for that rope rocket? I think I'd like to buy the Syren rope rocket and the serv-o-matic for my next model. The supplied "rope" in kits is such a letdown.
4 hours ago, Daniel Filipe said:
I didn’t know what sternpost was 😅
I didn't either before I started reading all the build logs here a few months ago 🙂
Looking good now, though!
Have you read through Havelocks Polaris log? It's really very good for us first-timers.
You're getting along nicely. We're at about the same stage now, though I started quite a bit before you. I don't mind, this way I'll have another build log to check on during my build
You're model looks nice. I would take away some more material at the stern where you have to fit the stern post. If you keep it like this, it'll look a bit strange, I think.
- Daniel Filipe and BobG
2
I finished my first planking yesterday. I had to end by inserting a plank to fill a gap midships (it this called a stealer too?) that I ended up with after using full width planks up to that point. For that I used a neat little technique I learned from a buildlog by a builder called Pietsan on modelbouwforum.nl (he isn't active here, I think) which I wanted to share here since mostly beginners will be following this topic.
Picture 1: the gap I needed to fill.
Picture 2: tape over the gap with masking tape. Note: I didn't tape al too well here, pressed the tape down too much so I ended up with a slightly too large piece (better too get the tape tighter to start with).
Picture 3: draw along the edges of the gap with a pencil.
Picture 4: remove tape from model and stick it to a plank (this is the hardest step, according to me).
Picture 5: cut carefully around pencilmark, peel away tape from outside and continue your cut until you have your plank to insert. Then remove all tape (I went too fast here and forgot to take pictures during work).
Picture 6: after some careful sanding (mostly because of me not starting with my masking tape insufficiently taut) you have a perfectly fitting plank to insert into your model.
So, on to the next step. Sanding and filling (or is it the other way round?).
in Traders, Dealers, Buying or Selling anything? - Discuss New Products and Ship Model Goodies here as well!!
Can't wait till James starts building that 😊
