OllieS
Posts posted by OllieS
A paint or oil finish is a surface application whereas a stain penetrates the wood, so you can stain and gently sand when dry etc.
I use stain because I like the natural grain effect. It's not to scale but MBMR wins every time
Glued wood will not take a stain so I always stain first and touch up with a similar tone of paint.
Personally I would steer clear of oil or anything oil based unless you use nothing else.
As to scaled painting: thin thin thin.
I just wanted to give a thumbs up to OcCre for their great after sales service.
After 13 months I am getting to the mast stage on my Revenge and realised that I was short on several dowels.
I filled in their online parts form on 29th June and a poster tube with half a dozen dowels was delivered today at no cost to me.
- Snug Harbor Johnny, RossR, Canute and 8 others
- 11
The Cala Esmaralda and its back story are almost certainly fictional. This model is actually based on the schooner Santa Eulalia: https://www.mmb.cat/en/schooner-santa-eulalia/
So maybe you could find the information directly (!)
There are also books available at the museum about the ship and its restorastion.
Also, in my opinion, in a model the width of the planking is a lot more noticeable than the plank lengths. 5mm is the stock item not the scaled choice.
Just a guess, but I would say that those blocks would be attached to the cap and not the upper mast because otherwise you would have a real problem if that mast ever needed to be replaced. Which they did.
Full scale rope approximates to a cylinder much better than thread does.
In a model, I would guess that the difference between different weights of line would be more important than the absolute circumference of them.
- modeller_masa and mtaylor
- 1
- 1
Just had a look at the Occre site where instructions are downloadable. They get around the very bluff bow with some solid wood at the prow, which might be a comfort. I don't know about other kits but personally I would be tempted by Caldercraft. Either way I absolutely recommend getting a copy of the anatomy of the ship book for the Endeavour. There are plenty second hand, but shop around because the price varies wildly. Then you could start a semi-scratch adventure by trying to follow the book using a kit as a basis.
Almost forgot.. I would go for a double planked model every time as there is more room for error.
The incompetent horror of a plastic childhood is abhorrent to me now and I don't expect that to change. (incompetant middle age is comfortably normal)
That said the great thing about wood is that you are halfway to scratchbuilding whatever you need. I have seen youtube modellers explaining that they had to wait for a (plastic) part. Wood modellers do not have that problem, if I break or lose something I sigh and pick up a file etc, the only thing I've lost is time.
I also have the sense that wooden ships are inherently made of wood; and steel ships of some modern steel substitute which can't be wood because that would be a fake somehow.
- Canute, Ryland Craze, mtaylor and 1 other
- 4
Time is the biggest factor. A small model is a few months a large one maybe years.
If you are looking for a result (everybody is at the start); then go as modest as is possible for something you wish to make.
Generally, don't ignore Occre; they have a good range ofreasonably priced kits and very good support with their youtube channel.
If you are truly thrilled by the SoS then do that one. If not then go to Vanguard Models and choose a level that you are comfortable with there. Perfect for the non-basher or scratcher I think.
- allanyed and GrandpaPhil
- 2
It is privately printed (2011) which explains the wonderfully uncommercial title.
It is however a very well written and generally useful book for anyone who is trying to move on from an out-of-the-box kit build.
It can of course be used as an enhanced set of instructions for the Sherbourne; but it is equally valid as a good read with lots of nice photos and a source of useful tips for any ship modeller.
There is an associated website with some downloads from the book: https://www.grbsolutions.co.uk and a contact email which is how I got hold of my copy.
One thing that as far as I can see nobody has made much of is how time consuming a wooden kit build is.
This is not a complaint, the hobby is better for it I think. My first (covid lockdown) model took me 3 months, because I was determined to reach the finish line (I was still working as normal I was just curtailed in my old hobbies). The second took 18 months because I began to understand that the journey is the hobby and I bought a book to help make improvements.The most recent was started in June last year and will not be finished this June...it was a simpler build than the second ('about a year!') ...until I focussed on easy improvements.
So, any kit turned into something good will be 500 hours and the big one more like 2000+
I'm sure plastic modellers build up a stash of future projects and so do wooden ones.
Watch out for planned decades!
4 hours ago, bluenose2 said:
Hello Les here. I am currently building the Corel version of this ship. I have purchased the book Endeavour, by Karl Heinz Marquardt......Now my dilemma is that the mast and rigging plans don't necessarily agree with each other. So what next? The build plan shows the places where you belay or rig the ship but the book does not. I feel your pain.
Standing rigging page 95 running rigging 120/121 deckplan. No deck plan for the standing but a combination of the book plan, kit plan and common sense was enough for my Occre Beagle with its Marquardt book. Good luck!
2 hours ago, RossR said:
First item I can't seem to figure out is the name of the triangle shaped sail that is attached above the driver on the diagram below. I am also struggling to determine the names of the lines used on the stay sales. The diagram shows two lines that start at the upper corner. One goes up through a block on the stay and then down to the deck the other goes down along the stay through a block on the mast and to the deck. I am not sure what purpose the second line serves. It would seem to me to make more sense if it was attached to the sail near the top forward corner. The remaining lines are at the bottom of the sail, one forward and two aft. The purpose of these lines makes more sense, but I still would like to know what to call them.
Okay I'm no expert at all so please correct me; but the driver is also called the spanker so that triangular sail would be the spanker topsail.
The second rope you mention makes sense when you know is called a downhauler the other being the halyard.
The lower ropes are sheets and tack (s) in the normal way just like a square sail.
Somebody knowledgable will tell you about the blocks but using what you happen to have also makes sense.
By the way those gunports don't look usable to me; I would probably make some nice stained wooden ones. I am a fan of Occre but their fittings let them down badly: they range from poor to unusable I think.
2 hours ago, Montaigne said:
Thanks, the air ducts got me thinking too....
In their defense though, they do say the following in the beginning:
“We’ve based our model on the HMS Victory..
WhenI went round Victory last Summer is was actually quite stuffy in the hold and orlop so the air ducts being a modernish improvement for the benefit of the public makes sense to me. No windows this far down for some unfathomable reason
This is great! Pretty much everything you need for general knowledge in 25 minutes.
- Tossedman, mtaylor and thibaultron
- 3
1 minute ago, OllieS said:
my stupid.
10 hours ago, Kevin said:
no issues at all so far, have done a lot more over night
No need to lose sleep
This is a long haul.
So. How do you bash this?!!!
- Obormotov, Old Collingwood and mtaylor
- 2
- 1
I agree with everything but in particular points 3 and 4. That's my hobby!
The only thing I would add is that if you happen to be making a kit that there is a book about that will really enhance the whole thing for you.
- BobG, JohnLea, wernerweiss and 4 others
- 7
The actual wood won't be fragile because it's blocky enough (like snapping a half matchstick say), and the 'real' hinges is the strongest fixing available I would think. So I suppose it comes down to whether you think it's worth the trouble.
I have a 'that'll do' moment at every stage of my build. And that will do
- Peanut6 and HardeeHarHar
- 2
Interesting and detailed useful review.
Staining
in Painting, finishing and weathering products and techniques
