Everything posted by AJohnson
SU-85 WW2 Soviet Tank Destroyer by CDW - MiniArt - 1:35 Scale
AJohnson replied to CDW's topic in Non-ship/categorised builds
That 'frost'? effect on the larger plate is amazing, I know its plastic, but in looks like cold steel! 🥶 -
Ha! - Just how long did that hat last! Our pooch would have shredded it in no time, he looks great fun! 🐶 -
Hi David, I feel your frustration, brings back memories of my Sherborne. But as Chris says, people can get hung up on this stage of the build. I did line out and work out the plank widths on my Nisha, but that has a more forgiving bow shape!
- 152 replies
- Vanguard Models
- Cutter
I’m sure if Chris did that Ancestry DNA test that by my Admiral is so into, we would see a whole linage of Coyles from Gdańsk! 🤣
Congratulations Chris on another fine example of the “Dark Arts” of card. Really outstanding and having tried card myself I really appreciate the skill and effort required to make yours look that good, wish I could get mine half way there!
Good save David, now this just the sort of “help” I was hoping for as I sit having a beer in Menorca! I promise to be alongside, messing things up in my own way, making you look the master you are, as your Diana stands testament!
- 152 replies
- Vanguard Models
- Cutter
Very nice "Admiralty" style model Richard.
- 104 replies
- pegasus
- victory models
Good luck with the remaining garden jobs before Autumn arrives, after all Keith you live in one of the driest place in England! 😆 My shed re-roofing will have to wait until next year now, other events in the house have taken over this year. I admire the neatness of the first planking close-up picture of the stern, so looking forward to seeing your second planking.
Yes, built like the proverbial "Brick Sh$*-house" as the crude old saying goes! 😆 Once all glued this is a very solid little model, it has been great fun so far and the hull form means I don't think planking will be too troublesome when we get to it.
🤣 - we since got married and now have two "kids" at University, so every penny, included the ones down the back of the sofa, have been raided since 1999! This is just a penny we found recently, I have a little stash of pennies of various significant vintages for this purpose.
Thanks all for the encouragement at the start of this build. Last update for a bit, the Admiral wants me to do some suitcase packing! And while I am away I am hoping David @dunnock will leapfrog me on his "Trial" build so I can shamelessly copy him! Given his just brilliant HMS Diana he has recently finished, I will be in very good company. 😁 So, trying to keep "waffle" to a minimum @Jack-in-the-Blue 😉 - onwards! I was keen to get the Stern parts on in order to protect the stern frames from my inevitable "accidents" so I got the stern counter, Stern bulkheads, Transom and raised stern platform glued on as soon as I could after adding the stern filling patterns (most of these patterns get sanded off later.) - Phew all on and no broken bits! 😀 The false deck is also in place now and drying, but not until I had placed a "lucky" penny as close to the mast position as I could (from 1999, they year the Admiral and me first met.) The front end of the false deck I put in a few pins for good measure where I couldn't clamp it. This is where things will sit and dry for a bit now while real life takes centre stage for a couple of weeks. Over to you @dunnock to keep the campers entertained!
Congratulations on your Grandson Gabe! I hope you buy him plenty of model kits to build and keep him busy / away from smartphones/gaming consoles as long as possible when the he is older! You did well to get anything done on the Agassiz with all that going on! Looking good. 👍
Hi David, I'll be following along and pinching any good ideas as I'm making the same kit! Great start, I was thinking about planking the lower deck, but decided against as I will have only one open companion way and may well add crew members to my build; can visualise a little "Powder-Monkey" running up from below, so unlikely to see below decks.
- 152 replies
- Vanguard Models
- Cutter
Hi Mike, really good to see you on with your latest build. We are both doing a VM Cutter, so will be checking in to see how you are doing.
- 34 replies
- Alert
- Vanguard Models
Welcome back Mike, hope you are all okay now, looking forward to your Dory. There are plenty of build logs on MSW to guide you.
Well another typical UK Bank-holiday weekend ☔! So it means I make a start on Trial! 😁 And in one sitting, on a rainy afternoon I have, without rushing, made my way through steps 1 - 24 of the instructions. First up, I think I am addicted to the smell of laser cut wood! 🤓 I don't want to go over the instruction line by line as Chris's Prototype build-log says it all, but there were a few things I found building it for myself I will comment on. I do a lot of modelling with a Swann-Morton Scalpel, but as mentioned in the instructions, you just sometimes can't beat a heavier knife with a new blade and this stage with the cutting out of the MDF frames is one of those times. It was amazing how much the box emptied in the first hour of so of this, good fun. The first job was making the keel base/supports, almost like having a keel clamp included in the kit! The only messy bit for this first session was the pre-sanding of some of the bulkheads, so I did that in the garage with the Dremel and mask on. One point to note if you are familiar with Vanguard's beginners kits like Nisha I built recently, there are no etched guild lines on the bulkheads to sand down to. No problem, no other kits have that, so I was cautious and did what I thought matched the instructions, I can always do more later. Stage #6 warns builders to make sure they don't get glue in the slot of bulkhead #13 (stern patterns) I got around that by using a metal file to keep the PVA glue out of the slot that goes onto the keel. One slight warning note for other builders is that parts#14 that go on either side of the central keel (they form the three slots for the Trial's sliding keels) are a bit delicate once cut out of the former and through my own roughness/clumsiness one of them started to break; it didn't actually come apart, but it was a close thing. Once held in place by parts "K1" all was solid and no fear of it breaking. The lower deck part #25 makes everything much more rigid. Parts 26 and then parts 15/16 at the bow followed by the pear parts B-1 to B-6 form the false deck supports and these really brings things together; they are helpfully etched with which direction you need to face them. The Stern platform supports #35 & #36 bring to a close this opening session. This part of the build really did go together very easily, the tolerance on the slots was just right, snug, but not so tight you were worrying about braking anything pushing the parts together. There will be a slight pause now for a short holiday and then a final session with the contractors to restore the house following the loft leak, so the garage will temporarily be full of "stuff" hope to back on this soon! Thanks for looking in! 👓
She looks magnificent David, well done! Looking forward to seeing the case. I think from the the dimensions you give the minimum thickness might need to be 5mm to avoid flex of the main side panels. I used this company for my Nisha:- www.acrylicdisplaycases.co.uk but it wouldn't be cheap for a case that big. So if you have the skills, make your own might make more sense.
- 310 replies
- Diana
- Caldercraft
