Everything posted by Thukydides
That is very kind of you to say. My goal with this build has been to figure out what I am capable of producing and though I have in some ways exceeded my expectations, there has also been a wide gulf between when I first try something and my later work (as evidenced by the above picture). My goal for the next build will be to hopefully bring up the quality of my weaker work so there is less variance across the build. I do hope other first time builders will be encouraged that even with limited experience you can push the boundaries of what can be produced with a kit. Granted having such a high quality kit as a starting point certainly helps.
- 562 replies
- vanguard models
- alert
It is looking good. As with all skills you get better with practice. I find if you take your time and are not afraid to redo things that are not quite up to standard, you may surprise yourself with what you can achieve.
- 83 replies
- Lady Nelson
- Amati
I think the bow shouldn’t be too hard to change provided you are planning on painting it. You could just build up additional material. The biggest challenge I imagine will be the redesign of the stern and quarter galleries. If you get those three things right then I suspect it will look very close to the Christinia. For the gun ports I think they should be fairly easy to modify (just use the longitudinal pieces for the gun port framing, but place your own vertical pieces). Obviously this will necessitate you planking this area instead of using the laser cut pieces, but should be very doable. Overall sounds like a very interesting project. I approve of your decision to try and push your boundaries a little and make this your own. I will be following along to see how this progresses.
- 111 replies
- Christiania
- Vanguard Models
Log #89: Mainmast Finished Time for a minor update. I finally got round to finishing the topsail bowlines and so was able to put in the topgallant sheets. I am not planning on adding bowlines to the topgallant yard. For the topgallant sheet I used .35mm rope and for the topsail bowlines 0.25mm rope with the eyes served with fly tying thread. The topgallant sheets are belayed to the foremost shroud cleats. With that done, the mainmast is finished apart from the topgallant stay which will have to wait until I get to the end of the bowsprit. Then more rope coils. I feel at this point I have the hang of them and my latest jig seems to give me the right shape. Just two small spots of super glue to tack things in place, a blast from the hair dryer and then a coating of very thinned matt varnish to hold it all together. If you want a more detailed explanation of my process you can find it here and here. You can see below the progress I have made on these. The one on the rightmost cleat was my first attempt, the next was somewhere in the middle and the leftmost is the latest one using the above jig. And that is all I have for today. Not a huge amount of progress, but it has been a busy week so I only got a little time to work on the model. I now have to give some thought as to what order I will tackle the ropes associated with the bowsprit. Thank you to everyone who has stoped by to take a look.
- 562 replies
- vanguard models
- alert
Edit the title of the first post I believe
- 152 replies
- Flirt
- Vanguard Models
It does take a bunch of them to get the hang of it. My earlier ones are not good and even now I would say 1 in 5 I have to redo. I do them as I go along as I find it easier to access the belaying point when I am tying off the line. This also spreads out doing them.
- 152 replies
- Flirt
- Vanguard Models
1779 Frigate color scheme
Thukydides replied to tennfox's topic in Painting, finishing and weathering products and techniques
For British ships of this period it is a time of transition from the more colorful painted friezes to the simple yellow and black. This is also the period when ships start having their bottoms coppered (mass use of copper plates starts around 1776). However much of this depended on the ship in question and you might want to do some research into the specific ship. I took a quick look at threedecks.org and couldn't see much info on the protector. In general the wales and often the strake of thickstuff just above the wales were painted black. Often the planking below the wales was also painted black down to the waterline, but on some the white came all the way up to just below the wales (search on RMG for the frigate Amazon 1773). How much of this practice the American navy copied I can't say. -
Sorry I should have been a bit more clear. I took a few more pictures to illustrate, but I think you have the idea. First I should note that I am using polyester rope and so that has dictated some of my process. If I was using natural thread I could use white glue to hold it, but that doesn't work on the polyester so I have to use super glue. If using natural thread you might want to experiment with alternative fixing agents. With regard to the super glue I use Bob Smith Medium super glue. It is pretty runny and I only use very small amounts. I really just use it to tack things in place so that they don't move until I can blast them with the hair dryer and then varnish them to fix them in place. If you use small amounts and you are careful to let it fully dry then I find it leave no visible marks other than a shininess. The matt varnish is both to take away the shininess and also to hold everything together. Note I thin the matt varnish with equal parts flow aid to make sure it goes on very thin. you don't want to have the rope looking like it has a coating over it. To apply super glue I put a bit on a yogurt container lid and then use pins I got from the dollar store to carefully apply tiny amounts precisely. These are really cheap so the moment I get much glue build up on the pins I throw them out and grab another. With regard to the actual process I have taken a couple more photos using a scrap piece of rope. You start with a length of rope cut to the approximate size you think you will need. You can see above where I have glued the first loop (A) and then flipped the second loop around and attached it to the first (B). Note that the direction of the first loop will depend on the direction you attached the line to the cleat or pin. You want this to simulate that the end at A is a continuation of your tied off line. Then you loop the rope around through the gap between the loops as many times as you want. D and E show where the pins would theoretically be. I have this upside-down in the picture as you want the glued loop to be the lower one. If you are wondering why my jig has the loops bent over the edge of the wood, that is because polyester rope is stiff and so I need to pre form the fact that the loops will not be on the same plane as the coils when it is hanging. Hope this helps.
- 152 replies
- Flirt
- Vanguard Models
Looks great, well done. See below for a picture of the jig I have landed on after trying a bunch of different methods. The two pins you can space further apart or closer together depending on how big you want the coil to be. I start by super gluing a small loop and putting it on the large pin. Then making a loop in the remainder and twist it and flip it over on the large pin (see below crude diagram). I then loop the remaining rope around the two smaller pins slipping it in-between the two loops until I have enough turns. Finally I super glue the end of the rope against the coil to hold it in place. I then give it a blast with the hairdryer and finally coat it in diluted matt varnish to help it hold its shape. Once all dry I pull out the smaller pins and pop it off and it holds its shape.
- 152 replies
- Flirt
- Vanguard Models
Can confirm, even the most tedious other tasks I liked at least somewhat. Ratlines were just something I needed to endure.
- 56 replies
- Cala Esmeralda
- OcCre
Log #88: Hoisting the Anchors Thank you to everyone for all the kind remarks. Today I finally completed work on the anchors. I don’t have many pictures in progress as nothing I am doing in this post is particularly novel and given the limited wiggle room I had it was hard to get good pictures. I will note that for the small bower I tried making the rope coils first and then attaching the anchor to the cable. For the best bower I tried it the other way round. You can see below a picture in progress where I have attached the coil for the buoy rope while the coil for the lanyard is in progress. I am still not sure which method was better as they both had their advantages and disadvantages. For the shank painters I used 0.5mm rope and just secured the anchors to a timberhead. The coils are simply glued to the shrouds. I though about trying to actually tie them, but it was much easier to tie the coil first and you would have to look very closely to notice. The sizing for the cable was 0.25mm rope and though it is hard to see from the picture I followed the method of securing the cable to the anchors as depicted by Lees. And here is the final result from above. Now the anchors are out of the way I can move on to finishing the final mainmast lines and then it is on to the bowsprit.
- 562 replies
- vanguard models
- alert
Indeed she is looking good Glenn, Alert looks so small in the background :).
- 587 replies
- Indefatigable
- Vanguard Models
If it was me I would do it again, as every time I have failed to go back and fix something I have regretted it, but in the end it is you who will look at it the most so the question is how much does it bother you. These sort of problems are hard as it is not just a small simple fix. Whatever you decide she is look good. Those 24 pdrs at the front are very imposing.
- 146 replies
- Adder
- Vanguard Models
In general you want to work inside out. Always be thinking about how a line will impact your ability to do others and order them correspondingly. However, as @wvdhee noted in the end this is more about making it easier than a hard and fast rule.
- 152 replies
- Flirt
- Vanguard Models
To be honest I am not sure and couldn't find any good answers on this. Lees depicts the buoy with these bands in his illustration and Goodwin does the same in his Alert book. Steel calls them buoy hoops on p167. So you may very well be right, I didn't find many other models depicting them and so almost didn't include them. One thing I forgot to mention in my post which confused me is that steel says the buoy hoops (the ropes in this case) were wormed and served in merchant service, but not in the RN. This seemed a bit odd to me as I would have thought it would be the other way round. Does anyone know why this might have been. It seems odd to serve the slings, but not the hoops.
- 562 replies
- vanguard models
- alert
Log #87: The Anchor Buoys I have not posted an update in a while as I have been slowed down by a combination of general busyness at work and my current project on the model being very fiddly. As you will shortly see I think I somewhat achieved the look I was aiming for, but certainly there is room for improvement. I decided to add anchor buoys to the model and so started by shaping some with wood using some spare dowel on my drill. For reference all the dimensions I got from p192 of Steel (https://maritime.org/doc/steel/part6.php). In retrospect I think I should have tapered the ends a bit more. Next up was to add some wooden bands. I couldn’t get any clear answers on what the function of these were, but both Goodwin and Lees depict the buoys with them and Steel mentions them on p167 so I decided I would at least attempt to depict them. I used the black paper from the kits cut into thin strips glued with wood glue. I then painted and dry brushed them. Next came the most tedious part of the process, making the slings. These were very fiddly parts to make. Given their small size and the fact that they all need to be the same size, even very minor error resulted in noticeable differences. I needed to make 8 of these, but I probably made at least 12 in total. They were served along their whole length (as per Steel) using fly tying thread. The eye splices etc were made using my previously described method. Once they were all done I took a pair of them and served with my 0.2mm rope around the end to make a double loop with 4 “tails”. These were then fixed in place using super glue and the buoy hoop (confusingly the same name is used for the wooden rings and the rope that goes round the middle of the buoy) was run through the eyes. And here is the result. I would do a few things differently if I was doing them again, but good enough for this model. Finally I spliced a 0.5mm rope into one end for the buoy rope and a 0.35mm rope into the other end for the lanyard. The buoy rope was attached to the anchor as per the description in Goodwin (though it matches what is in Lees). The lashing is done with 0.2mm rope. The length of each rope is long enough to allow a reasonable coil to be attached to the shrouds. I only have one of the anchors done, but the second will have to wait till next time. Thank you to everyone for all the encouragement.
- 562 replies
- vanguard models
- alert
The garboard looks really good. Well done.
- 60 replies
- vanguard models
- cutter
