tomganc
Posts posted by tomganc
Wow she looks absolutely amazing! Fantastic job with all the details.
I can't wait to get mine finished but still much work to do
Regards
Tom
Great build well done, lovely details and ropes of course... Nothing beats doing your own ropes
Regards
Tom
Wow looking fantastic. Very nice idea for the nails on the hull. I used the same technique for the decking on my Victory. Additionally I painted the sides with black marker to simulate tar filling.
Well done
Regards
Tom
Tat's superb progress! I cannot wait to see more rigging as this adds tons of details and she will start looking alive
Are you going to serve the first shroud all the way to the deadeye as in original?
Reards
Tom
35 minutes ago, Dave_E said:
I have a grandson who is a Lego maniac… where did you come up with the correct Lego parts to build the winder? I have yet to work any rigging on my first build… you make it look easy.
Hi Dave, when it comes to Lego I just opened big box with all bunch of different parts from few kits. Found some gears, 4 really small ones and one big as center wheel. Then it was a case of messing with different blocks to make housing for it so gears are lining up correctly. When you look at the picture of the setup you could work everything out. I'll try to photograph it from the front so you can see everything clearer.
In terms of getting your own ropes once you see how nice they come out you will never use rope supplied in the kit. You have to use really fine thread (depending on the scale and rope sizes). I'm using synthetic gutermann Tera 180. Really fine thread that gives super sharp and detailed lines.
And it isn't that hard once you get your head around it. It takes a little practise and few tries but it isn't that hard.
I'm mesmerized by rigging at the moment and I enjoy the process very much.
All the best
Tom
P.S.
Can you send a link to your build log pls? I was thinking of building Lady Nelson next
Hello again
Another update - rigging started
I managed to get shrouds in, ropes are served as per original, I fitted some blocks and slings too. Right now I need to attach deadeyes to the shrouds which may take a while if you want to do it properly...
I also prepared deadeyes for the upper mast shrouds with some additional rigging that goes with it.
Have a look at some photos...
Let's get back to work...
Regars
Tom
Wow you are really going crazy with it
Some great details there, I wonder when is a point that you say enough? I've got the same thing with my build, once you start adding stuff you want to go back and change everything you've done previously... Ehhh I think it's a time to plan next build and utilise all the knowledge and skills accumulated during this build.
You are doing great job and I can't wait to see your riggingAll the best
Tom
Wow I'm speechless. This is some amazing restoration work, it almost feels like it would be easier to build it from new
Can't wait to see more rigging...
Regards
Tom
Hello all
Another update time 😉
As all the jobs go ahead, I was getting closer to the rigging stage. Seeing some great builds out there I become really unhappy about the quality of the ropes supplied in the kit so decision was made to make my own. The more research I did the more overwhelmed I got. What thread should I use, cotton or synthetic, what type… The brand is Gutermann of course as it’s great quality. I needed two colours – black for standing rigging and natural for running rigging.
Next problem was a size of the ropes. The instructions were inaccurate, so I have found rigging instructions for JoTiKa kit and recalculated the rope sizes to match 1/84 scale.
The next stage was testing and making a spreadsheet for quantities of strands in the ropes to get right dimensions.
For Tera180 thread I’ve got as follows. First number is 1/72scale, the second is 1/84 and at the end number of threads and cores. This will also depend on the amount of tension on rope walk when you twist them together. The same thread was used for rope serving.
2.5mm – 2.14mm – 3x20
1.8mm – 1.54mm – 3x16
1.3mm – 1.1mm – 3x10
1.0mm – 0.86mm – 3x8
0.75mm – 0.64mm – 3x6
0.5mm – 0.43mm – 3x4
0.25mm – 0.2mm – 3x2
0.1mm – 0.09 – 3x1
Lastly I had to construct my own rope walk so I had a dig in my son’s Lego box and got it done 😉 I used small drill to run the gears of course
Final ropes for my build
My setup allowed me to twist about 4m of rope in one go so it didn’t take me that long. To give you a perspective I got about 2000m of thread, and I used 90% already for the shrouds and some stays…
- Ian B, Jorge_Goncalves, ECK and 4 others
7
Hello and congrats on a new build start. I like your idea and remember any design or improvisation - as long as it works it doesn't matter. I have to invent different types of jigs, brackets and holders on the way - I'm sure there is plenty of ready to buy jigs but imagination is a key. That's what makes all the process interesting and fun. Hitting the problems and finding a solution.
I hope you will enjoy the build and I can't wait for the update.
All the best
Tom
1 minute ago, allanyed said:
Thanks Tom, This was new for me I had only seen the cannon pulled tight to the bulwarks and the running rigging lines frapped. What the forum idea shows certainly would not hold the guns tight and keep them from running loose unless it was in addition to having the guns up tight and the lines frapped with the muzzle secured to the bulwarks as well.
Thanks for sharing!!
Allan
Exactly. The muzzle was secured though so I think it is possible solution. Any possible movements were distributed amongst full row on cannons too.
regards
Tom
On another hand have you got accurate rigging plans as mine are bit off
Thanks
Tom
Loving it. She will look amazing when finished.
I’ve started the righing on mine and getting shrouds and masts in. What a taskRegards
Tom
She is going to be massive 😳😳😳
Looking great so far, if I had more display room I’d build her too
Regards
Tom
Hello Allan
I made this basing in the forum discussion years ago. I gues this was the way cannins were secured during rough seas but I could be wrong. I made it that one side is ready for “action” and opposite side looks like this. I also have hull cutout so I can display deck cannons setup
regards
Tom
Looking fantastic as usual. Can’t wait for another uodate
Hiya, that’s very good looking model. You did a great job with all the details 👍
- Bob Fraser, ECK, GrandpaPhil and 2 others
5
- DavidG, GrandpaPhil, ccoyle and 2 others
5
Great looking build, I'm little ahead with my build but I can't wait for more
Enjoy...
HMS Snake by Mike_H - FINISHED - Caldercraft - 1:64
Looking superb. I like you attention to details. Great build 👍
Regards
Tom
