allanyed
Posts posted by allanyed
  1. On 3/25/2023 at 2:33 PM, Ian_Grant said:
    My opinion - that ring is too big. Just my opinion.
    Scotty, no reflection on you at all, but these anchors do not look right.  Not only the ring, the bands around the stock as well.  They look to be far too thick and the proportions overall look a bit off.   The photo above in Richard's post shows a great looking anchor.  These are easy to make with simple hand tools.    Lacking ebony, wood painted black works very well as in the photo below.  Contemporary anchor drawings are below as well.  They are not necessarily for your ship, but may give you an idea on proportions.
    Allan
  2. Joe,
    There is a spread sheet prepared by the late Danny Vadas for British ships that will give you the sizes of masts, spars, standing and running rigging for every line in the Articles database here at MSW .  It is based on the ratios in the James Lees' book The Masting and Rigging mentioned by Gregory in his post above.  One exception, do NOT use it for the period 1670 through 1710 as the base formula Danny came up with for that period is completely wrong so all dimensions that result from your initial input will be incorrect. Other periods are identical to those in Lees' book.  Go to https://thenrg.org/resource/articles and scroll down to rigging articles.
    Allan
  3. 2 hours ago, DaveBaxt said:
    I am  assuming that the water would run off the deck into the waterway so would need to be lower than the deck planks, or is it the oppisite and stops sea water going the other way?
    Hi David,
    There are scuppers for the water to run out.  The waterways on each deck vary. From The Elements and Practice of Naval Architecture by David Steel
    the water ways on the FC of a 38 gun ship is 4" thick and the adjacent plank is 3" oak while the flat of the deck is 3"  Prussian Deal.   The dimensions from the Shipbuilder's Repository 1788 are the same for the forecastle.  By comparison, the upper deck waterway is 5" thick and 11" wide per Steel, (4.5" thick per Shipbuilder's Repository 1788) while the flat of the deck, including the margin is 3" thick.  Steel states that there are four strakes of English oak next to the waterways on a 38, then the balance is Dantzick deal.
    Each deck is addressed in The Elements and Practice of Naval Architecture as well as the Shipbuilder's Repository 1788.  While the below are some years later than the Artois class 38s, a couple cross section drawings from RMG are below that might also be of some help.
     Hope this little bit of info helps David
    Allan
    800px-Jalouse_(1809)_CROSSSECTIONWITHPLANKINGDETAILSRMG_J4486.png.645b66b0d53728fc05271ef83036c652.png
  4. 12 hours ago, Morgan said:
     There is no contemporary evidence to suggest that deck planks at this time on the real ships were joggled or otherwise ‘let into’ the waterway or other margin plank.
    Hi Gary
    You may be correct but Peter Goodwin, author and former keeper and curator of HMS Victory shows in The Construction and Fitting book on page 60 that the margin plank was joggled if the length of the tapered edge was more than twice the width of the plank.   He includes a drawing of same on page 58.  He does not quote a source so I have no idea if he is basing this on contemporary information and/or this era.  By the same token the below contemporary model of Minerva at Preble Hall shows how the planks were shaped at the ends without cutting into the margin plank.  As you say, in this case they butt up against the margin, but they are still interlaced with each other rather than the margin plank, not with a straight tapered edge that comes to a point. This convention is shown on page 172 of TFFM, Volume II as well.
    Allan
  5.
    52 minutes ago, Roger Pellett said:
    The eye is not going to recognize.001” thickness differences.
    Seems right Roger. I got curious and did some digging and found this.
     At best, humans can resolve two lines about 0.01 degrees apart which is a 0.026mm gap when 15cm away.  In practice, objects 0.04mm (0.0015") wide (the width of a fine human hair) are just distinguishable by good eyes, objects 0.02mm wide are not.
    Allan
  6. B&L
    Your workmanship on the boat is very nicely done!
    FOR THE FUTURE - I realize you duplicated the build on the site you show above.  Unfortunately it looks like it is either set up for a double banked boat but missing rowlocks for four thwarts, or, if it is supposed to be single banked there should be one rowlock on alternating sides for every thwart.   This is a common mistake as contemporary drawings' side views usually only show one side of the oarlocks so many presume it is the same on both port and starboard which is not the case for single banked boats.   Drawing below showing 7 thwarts and 4 oarlocks.  The photos below show single banked boats.  FYI boats that were double banked were normally at least 7'6" in breadth.  While Syren was a US ship, there would likely be similarities if not duplication of British design in this time period.
    Allan
  7. 5 hours ago, Dr PR said:
    The 1/64" (0.0156") thick strip would be equivalent of 3/4 inch thick at 1:48 or 1 1/2 inch at 1:100. That would be pretty thick.
    3/4" should be close or perhaps a little bit too thin.  The 1719 Establishment gives them 3/4" for a 40.  There were no 32's in the 1719 Establishment so the 3/4" may be the closest to a 32 without under sizing.
    The  1745 and 1750 Establishments do not indicate a size, but the trend was to go thicker as time went on . In David Steel's The Elements and Practice of Naval Architecture he gives them at from 1" to 1.25" thick depending on the size of the ship/port lid.
    Goodwin shows an example at 1.5" thick on page 188 of the Construction and Fitting.
    Keep in mind the thickness often reduced from the area of the shoulder to the lower area of the hinge.
    Allan
  8. Hi Bryan
    While they are British ships, there are drawings of spars and masts on the RMG Collections site as well as on the Wiki Commons site.
    One example https://www.rmg.co.uk/collections/objects/rmgc-object-86593   There are also detailed drawings and text on pages 2-7 in James Lees book
    The Masting and Rigging of English Ships of War 1625-1860.  Too many to post here as it is copyrighted material.
    Allan
  9. If you are still undecided, do you have any kind of CAD program, including Paint which a free app with Windows?  You can make the frieze work then save and print on paper.  You can make it in a large scale so it is not hard on the eyes while making it, then reduce and print so the size is appropriate to your scale.
    Considering the age of sail,  if you are going to show her as she actually looked in 1796, it would then be appropriate to remove the name on the stern as the Admiralty did not allow the names on the RN ships before 1780 or after 1790.
    Allan
  10. 20 hours ago, Bobcat1970 said:
    Does anyone know where I can find 12mm, brass, 2 ball, rail stanchions with holes? I have 13, but need 71 more for the Endurance I'm building.
    Hi Bob
    Yes, but in what country do you reside? There are good suppliers in a number of countries.
    Which Endurance? There have been at least 3 including Endurance 1912.
    You can make a mold in silicone rubber of one or more of the 13 that you have, then make them out of casting resin.
    Cheers
    Allan
  11. 8 hours ago, EYWKPS83 said:
    My take-aways from these images:
    1. If the build is supposed to represent an older ship that's been in service, showing trenails might be appropriate. Otherwise, for a build representing a ship out of the shipyard, you wouldn't see them at most scales.
    2. I'd be curious as to the wood used for the re-planking of the Star of India's deck. Some kind of cedar, redwood, or cypress, perhaps? The color of each plank varies across the plank. I suspect if you're mimicking other woods, the whole plank would be the same color, though it might vary from plank to plank. A "good to know" for my next (first) build (which will be Bluejacket's We're Here--as a lifelong fan of Captains Courageous...).
    Ey
    Looks like that is your first post, so welcome to MSW!!
    Allan
  12. 23 hours ago, wade13 said:
    Any advise would be much appreciated
    Post 3 above is probably the best advice I can think of.  Add to that, the type of line you use.  At your scale, you will probably be limited to very few circumferences but that may be a plus in the end.  Regardless, if you can find the sizes you need in rope rather than thread go for it.
    For English ships regarding the cannon,  contemporary models sometimes left off all the cannon and when they did have them they were rarely fully rigged (just the breech is often seen).  I know most of us like to show the cannon, me included, so if you are making them fully rigged keep in mind for less than 32 pounders they used two single blocks, not a single and a double, which seems to be prevalent in modern day models.  This includes both the running out tackles and the train tackle.
    Allan
