Everything posted by allanyed
Planking Primer.pdf
allanyed replied to rudybob's topic in Building, Framing, Planking and plating a ships hull and deck
Some would argue that you can edge bend......... to a point. Depends on the severity of the bends, the type of wood and the methodology you use. Ebony is near impossible where as holly is a breeze with many species in between. The open grained wood found in many kits are difficult to work with so may be problematic if you wish to taper and properly lay the planking. Check out the 3 part video series by Chuck Passaro then you can decide on spiling or edge bending or a combination of both. Allan Allan -
JD, they are a pain in the neck to make and glue/pin into the side of the deck beams, but look great if well done. If you leave off a few pieces of deck planking you can hang a few hammocks secured to the battens (and sleeping sailors) so they can be seen. Lavery has about a page and a half of text and layouts of hammocks on pages 180-181 in The Arming and Fitting of English Ships of War. One of the drawings of the lower deck of HMS Bedford 1775 can be seen in low res on the RMG collections site as well. https://www.rmg.co.uk/collections/objects/rmgc-object-86584 Allan
Hi Aoi To which manufacturer are you referring? If they have a contract or agreement with a rep (Model Expo) here in the US, they are probably legally, and certainly morally, obliged to work through them. They will not keep a good rep for long if they are going to steal every customer that tries to go around this agent to save a couple bucks? Allan
Kristyn How are you going to finish the tops of the treenails? They really should not stay sticking up as at full scale they would be a huge tripping hazard. A very well honed chisel will do the job followed by a good sanding. You can also use a vibratory mouse sander before installing them into the bulkheads. Really looking good so far. Allan
MeanSuzy1 Welcome to MSW. It would be great if you would post a little intro about yourself and a name by which we can address you in the new member forum. Regarding your project, there are numerous posts and discussions regarding glues here at MSW and there is no single answer. Most seem to prefer carpenters' glue (yellow PVA) for all wood to wood, (me included) but many others like cyanoacrylate, others epoxy, and more. I assume you have studied the numerous build logs on the same Bounty kit here at MSW as that will help you during your building process. If not, it will be a big help pointing out the plusses and minuses you will encounter including where to research additional sources of information such as proper planking techniques and more. Read five times, glue once. 😀 Allan
Hi Dave, From Lees' Masting and Rigging the lower yard sling cleats were 1/25 the length of the yard between 1763 and 1815. If this is an important point for you, the shape is in the sketch below. The topsail yards were the same to about 1775, then were made like stop cleats set one yard diameter apart. The lower yard rope strop style to about 1840 is also shown. I agree with Glenn that wire was not used to secure any block, but for a super small scale model, I believe McNarry and others use wire at times. Allan
- 362 replies
- Amati
- Lady Nelson
It is nice seeing the hammock battens being made and secured in place. Not a common sight! Gorgeous work as always Allan
US Merchant Marine Academy Museum, Kings Point, NY
I am glad Sam started this thread as it is benefitting a lot of us even if he has not followed up on any of these great responses himself. Allan
KJ, everyone has their own thoughts regarding all aspects of our hobby, none are wrong, but rather it is what you are looking for and what you like. If you want to replicate the old masters, don't use treenails. If you like the look of the treenails, go for it, but as in most aspects of model ships, err on the side of smaller, not larger. If you can get them down to the 0.75" to 1" diameter range they will probably look really good. Allan
Hi KJ, According to Goodwin the treenails were from to 0.75 to 2". The smaller ones were normally found on the deck planking. Yours look to be on the smaller size of the range you give which is great. There a lot of models we see here at MSW with huge treenails, especially on the decks, looking really obtrusive. On the actual ships the trennals were often covered with diamond shaped cover pieces thus not visible at all. Note that contemporary models rarely, if ever, show treenails on the deck so at smaller scales better left out. Then there is the matter of when iron dumps or bolts or nails came into use on the deck planking. If anyone knows of treenail size information for the deck planking based on contemporary sources, that would be great. They are addressed as to material in contemporary contracts that I have seen but sizes are not given. Allan
There may be some variation for a 1901 schooner, but this MIGHT act as a guide. Working backwards, using ratios in Lees Masting and Rigging on page 164, for a 12 inch block (1" at scale) the diameter of the sheave hole was 1/8 the length of the shell, so the sheave hole would be about 0.125" (3.175mm) The sheave was 1/16 less than the sheave hole (~0.118" - 3mm) If that is the case, and the rope is as he describes at 1/10th the width of the sheave the rope would be 0.106" in diameter. This is the largest rope Syren offers on the website so large rope will need to be made by Elmina or sourced elsewhere. The blocks would likely be internally stropped and unfortunately Syren's blocks only go up to about 5/16" so Elmina may need to make his own blocks. over 5/16". Making internally stropped blocks at this large scale is really as difficult as making those for smaller scales. Ropes of Scale makes larger rope, but the larger rope is all cable laid so will not look right. Allan
I believe Roger is correct, your model is definitely not the 72 ton Elmina. The Elmina and her sister, the 72 ton Muriel were racing yachts built in 1901 by Townsend & Downey. There is quite a history of their races in the New York Times. Allan
Various applications of 3D drawing
allanyed replied to 3Dships's topic in CAD and 3D Modelling/Drafting Plans with Software
3D You make it look easy, but after your many years of doing this, that seems logical. Not so much for us neophytes. There are a number of articles here at MSW by a number of authors in subjects from basic lines drawings to planking to making various items such as stoves. It would be SUPER if you did one with STLs of various cannon that can be downloaded and then they can be 3D printed in resin. Let me know if this would be of interest to you and I can email you 2D drawings of cannon designs and sizes from about 1675 through about 1815. Cheers Allan- 39 replies
This of course does not apply to dry bending, but if soaking first, distilled water is a good idea. I have noted slight color changes (staining) from tap water on a few occasions, especially if it is a thicker piece that needs a longer soak. The water around the world varies so this may or may not be an issue everywhere and might have more to do with the type of wood than the water. A wide variety of chemicals are added to drinking water to remove various contaminants. Among them are alum, iron salts, chlorine, fluorides, and others. Just sayin' Allan
Hi Dave When David Lees wrote The Masting and Rigging of English Ships of War 1625-1860 Alan Villiers noted in the Foreward on page vi that this is a most useful book for the sailing ship modelmaker and for all students of such ships and their rigging. To that end, Lees includes the order of dressing the masts and yards on page 158. This includes standing rigging attached to the parts of the masts and rigging attached to the yards such as braces, lifts, footropes, &c. In addition, as can seen in most build logs here at MSW, it is pretty much a given that rigging the yards as much as possible before securing to the masts is preferable including the blocks to the trestle trees and yards followed by the foot ropes. Lees does not give an order of dressing for the running rigging but working from inboard to outboard on the model seems to work for most modelers. Perhaps your kit gives some guidance as well. Allan
- 362 replies
- Amati
- Lady Nelson
Welcome to MSW 3Dships, Now that you have come aboard, it would great if you would post a little intro about yourself in the new member forum. Your drawings are terrific! I've struggled just trying to do cannon barrel drawings for various time spans in the 17th and 18th centuries. Sailed the seven seas in the MM? Me too, lo those many years ago. US or other flag? Thanks Allan KP '69- 39 replies
Dave, Just as an FYI, for the next go around, according to Caruana's The History of English Sea Ordnance, Volume 2, page 386, 32 pounders and above normally had a double block and single block for the running out and training tackle. For calibers below the 32pounders the running out tackle and training tackle normally had two singles, not a double and single. Allan
- 362 replies
- Amati
- Lady Nelson
- 362 replies
- Amati
- Lady Nelson
Hi JG There are many places to learn about planking properly, but many members (including me) think a couple of the best and the easiest are here at MSW on the Antscherl spiling piece, Passaro's lining out piece in the Articles data base and Passaro's 3 part video on You Tube. They are not so difficult and they work. For example, your strakes at the stern should run to the stern post rabbet. not the bearding line. I may be wrong on this if you are double planking, but if you look at a contemporary planking expansion drawing you will see how they should lay. Just go to the RMG Collections site and type in planking expansion plans on the search box. There are 16 expansion drawings some of which show both outboard and inboard planking. https://www.rmg.co.uk/collections/objects/search/planking expansion drawing Cheers Allan
- 74 replies
- Lady Nelson
- Amati
