Everything posted by Jack-in-the-Blue
Aye, very true. Trafalgar was a perfect example of that. Being a physical coward myself, I can’t imagine how it felt watching the battle approaching all morning at walking pace. I’d have been a wreck! I neglected to mention how much I like your model. You have done a fine job of this fascinating vessel.
I think that might be staining caused by the aggressive vapour emissions from the CA. I’ve seen similar marks form on plastic surfaces a little distance away from the actual glue. Perhaps better ventilation, forced draught of some kind, is what we need? The painted planking looks exactly right to me. It’s just like the real thing, as seen on ships like SS Great Britain in Bristol. Outstanding work!
Fix uneven paint area
Jack-in-the-Blue replied to DMM's topic in Painting, finishing and weathering products and techniques
I was a plastic modeller of fifty years experience (and an airbrush user) who only recently became a novice in wood kits. I’ve stripped acrylic paint dozens of times so I’m speaking from experience here. I’ve also tried and failed with abrasives. Stripping the paint = thirty minutes and no damage to plastic. IPA is not toxic or even unpleasant. It’s also cheap. A few sheets of alcohol wetted kitchen roll will wipe away even thick paint like yours. You may need a toothbrush in heavily recessed details such as around the prop shafts and rudder. Abrasives will clog straight away, take ages and destroy the plastic surface details. You will need lots of paper. You won’t be able to sand around the details. If you do decide on sanding use wet and dry paper with lots of water, under a shower perhaps. And let the paint dry and cure really well - several days! I suggest trying both methods on a small inconspicuous areas before committing yourself. Good luck. Let us know how you get on. 🙂 -
I suggest that you strip it all off the plastic with IPA and start over with thinned paints in multiple coats giving plenty of drying time between layers. -
Yes you can. Isopropyl alcohol won’t damage polystyrene but will dissolve acrylic paint. (I am assuming you have used acrylic paint because of your suggested solvent.) Personally I would remove the paint that you don’t like and start again with primer and topcoat. Painting over the gloss is risky because gloss paint isn’t a very good base layer. Sanding it might lead to unwanted scratches and texture showing through.
I'm sure I read somewhere that it wasn't original practice to taper below half of the plank width for strength reasons; a blunt ended stealer being preferred? Of course that doesn't matter at all if there's going to be a second planking on the top (which can follow whatever rules you like).
- 148 replies
- Vanguard Models
- Cutter
I just did my rudder in exactly the same way, and I think it looks fabulous. Mine isn’t quite as good as yours because the cut outs are the wrong shape but I can live with that.
I have found that when I run out of edge bending it’s time for a stealer. Maybe that would help?
- 148 replies
- Vanguard Models
- Cutter
It’s very good. Well done! Im trying to resist buying one for myself. 😁
- 42 replies
- Cannon Jolle
- Master Korabel
Would you buy pre-owned wooden kits?
Jack-in-the-Blue replied to Frank Burroughs's topic in Wood ship model kits
I agree entirely. My first build and so far only completion was the Vanguard Models Zulu fishing boat. If you can find one of the smaller Vanguard models second hand, I think that would be perfect. They do pop up from time to time, as one of the ones I found was an HMS Alert - box worn but contents pristine - Price £102. (Er, I may have drifted into bragging, sorry. Only you guys understand. There's no-one else I could tell. 😏) -
You are welcome. I will encourage you every step of the way (which may be a long one...) Oooh, creativity! You know, even if your chances of finishing this to standard that will satisfy you are slim, imagine what you are going to learn in the attempt! Even better, think of the things that you are going to have to invent! Speak not of Major Problems, he is outranked by General Opportunities!
I agree entirely. "Appropriate" is something of a weasel word, very ambiguous, undefined; it's definitely a matter of opinion what it means. I suggest that the builder choses his own definition for terms like this for the pragmatic reason that if they canvas opinions, they will get a gazillion different ones and still have to chose which one they prefer. 😄 But I don't know...
Excellent advice. I was able to find logs or at least reviews for every kit that I bid on at auction. It tales only moments online and saves a lot of pain. (It's also a good way to find out whether the kit is from a pirate manufacturer.) -
As a new guy here, I don’t presume to tell you what to do with your project, but personally, I like a little imperfection in a model (which is very convenient given my limited skills 😁 ). For me the crooked stanchions add the ‘human touch’. They give the model ’soul’. I admire the skills that produce ‘perfection’ but don’t love such models. Many beautiful people have crooked teeth.
I have recently bought several pre-owned wooden ship kits from eBay. All were reputable European and American brands. About a third were out of production. All were complete and in good condition. All but one still had the wood sealed in its moisture barrier packaging (and I suspect the exception didn’t have such packaging when new). I limited my bids to half of the retail price and paid about a third of the retail price overall. I can neither recommend nor condemn the practice because I might just have been lucky. This is simply some data for you to consider. -
Victory 357 Hawk Ekranoplan by RGL - Paused
Jack-in-the-Blue replied to RGL's topic in Non-ship/categorised builds
Seriously, does an ekranoplan count as a sea-vessel? It can only fly over water. It could perhaps be considered as a ‘super-hydrofoil’ or a hovercraft?
