HIPEXEC
Everything posted by HIPEXEC
  1. The first picture is of a pre-bent, pre-twisted, pre-beveled plank. The next photo shows this plank freshly glued in place. Notice...it doesn't need clamps!
  2. Another pair of planks. so far so good with just the usual problems attached to planking
  3. While the glue dries on my last plank, I'm wet pre-forming two planks putting the last bends, twists and curves before beveling and later tapering.
  4. I love the way my planks fit into place after all the pre-bending, twisting, beveling and wet pre-fitting I do. The fully prepared plank virtually snaps into place even without glue. I've come a long way from the first models where I wrestled with planks forcing them into place.
  5. Another plank. I'm showing all progress in case someone really wants to see how long this planking process takes me and why. On many logs they show the beginning of the planking process...then wham....they show the whole hull planked. If it only was that easy.
  6. Balsa seemed to work for me in past models.
  7. I'm showing pictures of plank progression since the plans do not have detailed pictures as the planking progresses. The center part of the hull is always the trickiest part, so I will take photos along the way so maybe it can help others building this kit.
  8. 1/8" a day. That's slow planking. So, I'm still bending, shaping and gluing planks. Pre-shaping the plank on the hull really makes the gluing part easy. No forcing at all.
  9. I just finished gluing the port and starboard garboard planks. By pre-shaping them, they just snapped into place.
  10. Now I'm shaping the first garboard plank. It goes from vertical to past 45 back to vertical
  11. Here I'm bending and twisting a plank in several directions so it will easily fit on the hull. Most of the planks from now on will need the same treatment.
  12. With all the manipulating the hull while planking, the center section of the transom came un-glued. It'll be good the get the transom planked to protect it.
  13. Here's the upper planks without clamps. They look pretty good without any sanding if I say so myself.
  14. My Syren plywood was heavily charred and very difficult to sand off. In some places I never removed all of the char. Good luck with your build.
  15. I've installed the last upper planks. I've made a slight mod to the plans which I will explain later. I also noticed that one side is 1/32 higher than the other? Go figure. It's an east fix with some sanding, but with all the careful measuring I did for the first plank, something must have slipped in the first gluing.
