Everything posted by HIPEXEC
Thanks for the nice comments. Yes, Sjors, the cannons stay brass according to the Constructo plan. No paint!
- 1,756 replies
- constitution
- constructo
Your work is terrific. How did you make the stanchions for your stairwell? The photo is blurry.
- 1,477 replies
- essex
- model shipways
- 1,756 replies
- constitution
- constructo
- 1,756 replies
- constitution
- constructo
The following is my solution to mounting a ring on to the cascabel of the cannon. I first glue (CA) the breeching line on to the cascable of the cannon.
- 1,756 replies
- constitution
- constructo
Speaking of old....an old dog can learn new tricks. I just discovered I can follow each of your builds by clicking on that little box on the upper right of your build. Up until now, I had to search for your builds to see your progress. Now I have to click on a lot of those boxes because I love watching your builds.
- 1,756 replies
- constitution
- constructo
Since it will probably take me the best part of a month to rig my guns...I figured I'd install little thing while the glue dries. Here's the first of many cleats installed. Constructo is very weak in showing me exactly where these little things go. I have to look in several places for exact positioning. At least one location has a major conflict with gun rigging. I'll wait until that particular gun is installed before installing the cleat.
- 1,756 replies
- constitution
- constructo
Oh bless you, Sam for calling me young! I'll be 76 in 30 days! I do feel young at heart but my bones ache from time to time.
- 1,756 replies
- constitution
- constructo
I didn't plug in the Dremel. I turned the chuck by finger power. There was no way I was going to use a power tool on my hull.
- 1,756 replies
- constitution
- constructo
While I was waiting for the glue to dry on another cannon, I finally got up the courage to drill into my hull! Believe me....I looked at that hull and looked at that hull and looked at that hull for several months, now. All I could remember was how much work went into getting those planks just right. Making a hole in them wasn't my idea of fun. But.....I final did it and installed the starboard below decks portholes. Constructo wanted them to be bright brass in finish, but I toned them down to a dull bronze. I first hand drilled a small pilot hole, then using my Dremel, but twisted it my fingers, and I made the final holes.
- 1,756 replies
- constitution
- constructo
Coastie96, The Constructo rep is: Marcos mcarracedo@diset.com
- 1,756 replies
- constitution
- constructo
Coastie96, When you start your build forum, please use a lot of photos. I forgot how I started mine. My Connie is only my second build. I did soak and pre-bend the piece you mentioned. I will give you the e-mail of the Constructo rep who can get you missing parts and also a parts list.
- 1,756 replies
- constitution
- constructo
Did this website suddenly get balky and slow or is it my computer?
- 1,756 replies
- constitution
- constructo
It's a bit of a slow start, but it's good to be back in the shipyard again. I just rough rigged a gun in 30 minutes! That's great progress for thick fingered me.
- 1,756 replies
- constitution
- constructo
I mentioned in my build log that this was a trouble spot. I filed and sanded the slots to widen them and make the extreme bend easier. I also pre-bent the gunwales. Good luck and please start a build log so I can watch. I'm no expert, but I've come up with some tricks to overcome Construct's lack of instructions. Page three of my log shows the trouble spot.
- 1,756 replies
- constitution
- constructo
Now that the fishing gear is put away...back to rigging the guns. Here's my gun rigging factory. At this rate I'll be rigging guns for a month. I'll probably do it quicker since I always get better and faster with each new piece.
- 1,756 replies
- constitution
- constructo
- 1,756 replies
- constitution
- constructo
Thanks for the comments and suggestions. Fishing in Minnesota was great. My best was a ten pound Northern Pike!
- 1,756 replies
- constitution
- constructo
