Everything posted by DocRob
I scratch build my own supports for the boat from planking rests, cut with my trusty mitre cutter and sandwiched the MDF parts for the boats stand between them. After a coat of varnish, I added some eyebolts and decorations, which originally should be used at the hull sides, but I never liked them there. I like the look, as it fits to the other sub assemblies on deck. What I'm not sure about, is the look of the blue etched rows, which I may exchange for the also supplied wooden ones, painted differently, maybe whit and natural wood. What do you think. Cheers Rob
Many good advices by Oldsalt, Glomar. Airbrushing is about a certain discipline. It's not overly hard to learn, but you have to train a lot, to get decent results. Try everything on paper or an old model first. Keep the airbrush clean at all times and care for your needle. A bent needle will result in bad spraying. One thing can't be emphasized enough, the mixing ratio. Almost all colors have to be thinned. The rule of thumb calls for a milk like mix to spray. Again, this has to be tested. To thick mixes will clog in the airbrush to thin mixes run under masking and don't cover. Try to get adjusted to the medium you spray, acrylics, enamels or whatever. Use the appropriate thinner for the color. When you have found the possibly correct mix of color and thinner, experiment with the air pressure, until you have the right balance. When you spray, try to avoid start spraying onto the model surface, start before and stop, when moved over the area completely. If there is dotting, you may have color clogged on the needle. This can be easy cleaned off, but can be a sign of a to thick mix or to high air pressure, specially with high pigmented colors. Airbrushing is 80% preparations, masking and cleaning and at max 20% of spraying. Be patient and analyze what you achieve. One word about masking, there are several possibilities, the one I like most is yellow Kabuki tape, which you can purchase from different producers. It's thin, adheres well and can be cut very precise. Sometimes you will need liquid masks or flexible masks for achieving contours. Do yourself a favor and wear a respirator mask and rubber gloves, when airbrushing. Almost all mediums you spray are poisonous or dangerous. If you have more specific questions, I will answer you for sure and don't forget, airbrushing is fun and a great technique to have mastered. Cheers Rob
I never tried a carton model, but yours looks sweet and tempting. somewhere, I must have shelved lightship kit, I will look for that. Cheers Rob
Almost there with the Cutter. I painted the hull flat white, the seats flat red and the rudder, rows and stripe flat blue, all airbrushed with Tamiya's XF colors. The gratings, which are made from PE, were primed, airbrushed with Desert yellow and then received a oil color treatment with a flat brush and whit spirit, to emulate a wood finish. Last was a coat of clear matte. The colors were chosen to match the DoK's colors. Some minor touch ups and fitting the rows, hooks and anchors and this little side project can be called done. Cheers Rob
Your boat looks absolutely fantastic, made with great woodworking skills. Cheers Rob
- 216 replies
- masterkorabel
- ships
(and 3 more)
This boat is truly a model in a model and consumes lots of time to build up. My new Sphinx kit has thee boats included, that will be a real test. I added the spars, which are made from pearwood strips, which I soaked and clamped around a tin for drying with a curved contour. These were glued in with CA and then cut. Finally after adding the supplements for the seat panels, the inside of the boat got a coat of varnish. The rest of the boat will be painted matching the scheme of the ship. Cheers Rob
I feel with you Vane, as I'm building a boat for my Duchess of Kingston at the moment. It's a tedious affair for a novice like me and the first planks were not the most difficult. I feared the step of removing the frames, but it worked out good, without destroying the hull. I used PVA for the planks in places, where the frames will be removed and CA on the other parts of the planks. Cheers Rob
A wonderful and clean build of this very attractive ship, congratulations. Cheers Rob
- 91 replies
- Speedy
- Vanguard Models
Thank you Tom, your build progresses greatly. Installing the fragile side railings was not the easiest task in my build, but they do add a lot to the appearance of the DoK. I recently joined here and started my build log, right were I was last week with the decks done. It can be found here. The full build log was started on MSW's partner forum Large Scale Modeler, where I'm an active member since some years. Duchess of Kingston - Beauty of the Seas - Wooden Sailing Ship 1/64 - Non-LSM 'WIP' and Completed - Large Scale Modeller BTW, I have to find a way to add my current projects to the footer of my profile, but couldn't find out how. Cheers Rob
- 118 replies
- Duchess Of Kingston
- Finished
Thank you Oldsalt, indeed these tiny boats can challenge my patience. I've managed to smooth the hull due to sanding and applying filler and have torn out the MDF frames, which worked surprisingly well, given the eggshell like appearance of the cutter. It turned out to be very time consuming, to get rid off the glue residues on the inside of the boat with sanding tools, rounded scalpel blades and small chisels. After this was done, I made a small placement test on my DoK. Cheers Rob
This is a very fine build of that lovely ship. I really like the cleanness of your build, which was inspiring, while I build mine. I'm slightly ahead of you with my first wooden ship, as I have just finished the decks and am fighting now with a planked boat, I want to add to my DoK. I took some peeks into your build, as I gathered as much information as I could possibly get, to help me with my newby attempt. Cheers Rob
- 118 replies
- Finished
Thank you Derek, that sure helps. Buying a mill is not urgent and I'm still in the phase of deciding about my needs and what I'm willing to pay. I was a metal engineer in a former live and used professional mills extensively for some years. During my education as an engineer, I was part of a team, developing a self built CNC-mill. That was back in the 80's mind. I wish, I had one of those machines now. The wood milling aspect is what's new to me and you are right, speed helps with clean cuts here. My plan is to mill wood, brass and aluminum and I will dig a bit deeper into the subject now. Cheers Rob
Like most of the above comments, I would say the booth you have chosen is not suitable for sanding dust. There are different padded filters which would clog rapidly with sawdust. I own a spray booth similar to the one you are showing, but have enhanced it a bit for bigger models and better suction. I wouldn't use it for sanding though, but the basic construction in combination with a small industrial vac cleaner might be worth trying. Using a booth limits your ability for handling a lot, you can't lets say sand a hull in there, so generally I think, like mentioned above, it's better to use tools, which have a vac cleaner port and collect the dust where it emerges. In case you are interested ,I show some pics of my booth which was enlarged using a big container made from transparent plastic. I cut an opening into it's underside, more or less the size of the booth, without the plastic sheets and connect both with duct tape. I used some ropes of LED's for lighting wrapped around the transparent box. If you find a way to install a powerful vac cleaner instead of the booth, it might work. The planes in the booth are 32 scale, the box is ca. 60 cm wide. Cheers Rob
I built up the the Duchess of Kingston, hull and decks complete with all the decorations during a three month period and needed almost two weeks for planking the cutter. I have to admit, the little bugger took a bit of wind out of my sail, but I'm stubborn enough to want the boat having finished somehow. I'm really happy, that I wouldn't have to use the cutter in real live, as it's planking job is far away from being watertight and even if it was, it wouldn't row straigth at all. My second planking job was somewhat harder than with DoK. That's it in full ugliness, before sanding After a bit of sanding it looked a bit smoother. I wouldn't go to far with sanding, as the planks thickness is only 0,5 mm. I will use some filler next, liberally applied which will not disturb, because I plan to paint the outside of the hull. Cheers Rob
You could apply some iron pigments with a cotton swab. My go to metal pigments are from Uschi van der Rosten, because these are the finest. Another fine weathering product ar AK's weathering pencils. They are special, because you can apply them dry like chalks or dampened. Oil colors are also very useful and on a pump like yours, which is painted matte or semi matte, you can work some gloss onto oiled parts or where spills occur. These are only some ideas which originate from my plastic modelling background, BTW.: Yor Cutty Sark looks great with all the detail. I will savour your log with a bit more time. Cheers Rob
- 444 replies
- Cutty Sark
- Revell
Very nice, showing the internal structure is a great idea, especially in this relatively large scale. Cheers Rob
- 7 replies
- Endeavour
- cross-section
Started reading the Pellew bio today. He's still on HMS Juno but it seems to be a good read. I'm definitely interested into the Indy kit, but with that size, I'm not so sure. It's not only about displaying when ready, but also handling in the cave, I'm a bit afraid of. Maybe this changes with the Duchess of Kingston finished in a while. On the other hand, I can't stop savouring your log, open end... Cheers Rob
- 488 replies
- Indefatigable
- Vanguard Models
A very interesting discussion you have here, about mills. I'm actually thinking about buying one and have ruled out the Proxxon MF 70 as being to small, specially considering the possible way of the table, too fast for some materials and last but not least, being limited to tiny tools with only one shaft diameter. As an alternative in the Proxxon range, I figured it could be possible to combine the stand BFB2000, the table KT150 and the motor BFw 40/E. All components are a bit bigger and sturdier than with the MF 70, but are still compact enough. You can go from 600-9000 rpm and use tools with up to a 6 mm shaft. I would be interested, if somebody has experiences with the combo or parts of it. The price tag is around 600€, more or less double than the MF 70. Cheers Rob
Very nice work on the rigging David. I have to thank you for your immense resourceful build log, which I used as a reference for my newb build of the very same ship. I have to admit, that I stole one or two alterations from your log, like the brass pump outlets and the rounded mast bases. The 18 ft cutter, which I probably add (if I manage to build the tiny thing up) was planned and purchased from the beginning, though. I will follow your rigging experiences with great interest, as this is the part of the build, where I'm completely lost and need to absorb some help from more experienced builders like you and others here. Cheers Rob
If this is still of interest, I built the same kit some years ago and had absolutely no issues with the masks, which I also purchased from Cult man, alon with the electronics. The masks where left in the box for some years and showed no sign of ageing. Cheers Rob
A truly fantastic build with interesting problem solving and a beautiful and different look, through the use of boxwood. I hope you don't mind, if I peek in and learn from your build, as you are slightly ahead of me with the DoK and way ahead in craftsmanship. Cheers Rob
- 345 replies
- Vanguard Models
Thank you for the information Keith, I haven't thought about it, but it makes sense to tar the shroud lines, given their exposed position. In case of my build, mind it's my first rigging job and I have no other material available, than what is in the box, I will use, the natural colored one. I have to get a feeling for the materials first and therefore stay with the manual. I have no idea, how much yarn will be used and if there is spare amount, sufficient to change the color, in this case at least to black. I'm living a bit isolated and it's sometimes very hard for me to purchase modelling goods, and that gets even harder, as I don't have the knowledge what to buy. I will keep your information stored though for future builds and will sure browse through a lot of rigging threads here soon. Cheers Rob
