Everything posted by Coyote_6
Yay yard work!! I'll be watching closely as I am getting close to yard work myself. Two beauties you have there sir!!
- 261 replies
- Victory Models
- Pegasus
(and 3 more)
You have captured the essence of that era of U.S. Navy ships Phil. Just wow!
- 490 replies
- minesweeper
- Cape
So dang awesome!! Especially the low light shots! Amazing - glad I was able to witness this. Well done Glen.
- 156 replies
- Queen Annes Revenge
- bottle
Ahh symmetry. So peaceful. (We'll bring that mainmast back in line when we rig the tackles.) All the foremast shrouds and forestay are preliminarily rigged. I will probably redo the forestay collar - I used too thick of line (almost 2 times too thick!) and the collar/stay keep twisting likely due to the use of thimbles (Smithsonian plans) vs hearts. If I can get a heart into the stay without having to remake it that will be better. But that collar is too thick, Smithsonian says it should have been half that. Ooops. First mouse ever, all line using my serving machine. I feel sheer (shear?) poles and futtocks are next to lash in. How does one lash - criss cross and end with overhand knot/superglue? Seems the sheer poles should be in place before we secure the deadeye lanyards? As always, I appreciate any thought or advice! Thanks for stopping by.
This way your "mahogany" will definitely match. Looking good Phil!
- 490 replies
- minesweeper
- Cape
"1/64 inch plywood". Me mind is blown!! (Cape is looking fabulous. Very very nice bulwarks!)
- 490 replies
- minesweeper
- Cape
Mr. Nash has turned in the deadeye on the first starboard shroud. So far so good. I also got the shrouds served. Like a goofball I only served the top half of the forward shrouds - at least I got the aftmost shroud fully served. It was a good lesson learned. Lever confused me with "serve the forward shroud halfway". I just today received my copy of Steel and he be like "serve the whole fore shroud." Doh! So the rule for a fore and aft rigged vessel is to fully serve the foremost and aftmost shrouds fully. (On the Prince that only leaves the middle shroud, top 1/8th served to go around the mast and over the bolster.) New things every day! We'll get it right on the mainmast.
Thanks Bob! You can't argue with the results - they look awesome! I will be trying that!
- 261 replies
- Victory Models
- Pegasus
(and 3 more)
Those ratlines look great! Do you mark them with chalk when you're laying them out? Darn fine work sir!
- 261 replies
- Victory Models
- Pegasus
(and 3 more)
That money is well earned. There is nothing wrong with charging a fair price - the quality speaks for itself. I would hate to no longer get Syren products when I am halfway through my project! 😭 Keep up the good work Chuck! Looking forward to the reopening - shrouds and stays take more line than I would've thought!
@Chuck Seiler Thanks Chuck. The serving thread was fine. Like a goofball I doubled the tackle line overall and then served it all. Where it was wrapped around the mast the tackle was as thick as two sets of shrouds!! My remakes are closer to what you might see in Petersson's and it looks much cleaner. I have my first shroud pair mocked up and it looks pretty clean. I am horrified at how much Syren line each shroud pair uses. I went to order more but they are out of stock for a bit! Yikes!
Wow Phil! There is a lot going on there. The card templates look like they will serve you well. I am adding that one to the "toolbox in my mind". It is a cluttered toolbox.
- 490 replies
- minesweeper
- Cape
@Dr PR Thanks so much for the sanity check. I must've looked through four references to figure out how those tackles should be. If you look close Mr. Nash is all bent over banging his head on the forward fife rail because it took like 6 hours to rig two tackles. I love having Lever as a reference - I think Sheet Anchor is the most approachable reference I have found from that time. You are too kind Phil.
Ok. Not on to the shrouds. I am pretty confused but I hope I am in the right direction. I added the tackle rigging first. With the exception of a double block in lieu of a fiddle block, this rigging aligns with Marquardt's Global Schooner. Rigging to the chainwales outside the shrouds is in Rigging Period Fore and Aft Craft by Petersson. Any thoughts on the tackle rigging here? My main question is why do they lay outside the ratlines in Petersson? Is that correct? At first I rigged them inboard to the deck but they would have interfered with the fore gaff sail.
For better or worse, the first serving of my life is completed. I give you... Ta da... Fore Mast Tackle Pendants! Oooooh! Ahhhhhhh! They are not pretty and are bulky around the mast. I thought the tackle pendants were double lines all the way, but after seeing they were too bulky I redid them. But I like the Syren Serving Machine. I think this was a little complicated for my first serving but it worked. On to the shrouds.
Looking soooo good right there! Congrats!
- 261 replies
- Victory Models
- Pegasus
(and 3 more)
Too cool! I bet there was just the slightest beam of light on that beautiful gem of a steam engine you put in her! 🤣
- 457 replies
- sternwheeler
- Hard Coal Navy
Wow. Those belong in a museum somewhere! Truly spectacular!! Just wow. And then one considers the scale and the mind is totally blown...
- 457 replies
- sternwheeler
- Hard Coal Navy
