Rustyj
Everything posted by Rustyj
  1. Ok all the paint has been applied and gangway iron supports are being installed. I've also placed the cannon and rigged them. I'll finish the supports and make the walkway next. Then it's ladders and a few other bits and pieces.
  2. Good catch there. I think I've had that same supervisor on some of my builds. Had to fire him more than once too!
  3. Hi Ben, You're making good progress. Seeing you're doing such a good job of it I think I'm gonna mail my frames to you so you can raise them too!
  4. Hi Augie. Very nice job on the anchors and buoys! Man you are getting close.....except for the case that is.
  5. Hi Bob, Very nice job on on the deck and bulwarks planking. Also lining the ports with red heart came out very nicely too.
  6. Wonderful Chris! Keep it going your almost there. Plus I'm greedy and love seeing your work on her.
  7. Thanks Paddy and Antony. Ben, I used a torch and regular solder. Grant. Plans and build match? Never had that happen for me! I also used a plank to check both the height and angle. I marked each bracket and each location as they were all unique. Here they are drying. Coat two of ?????? Not gonna be twenty though Ben.
  8. It’s time to make the gangway iron supports. Between the various heights of the gun deck spirketing and the gangway clamp each bracket will have to be to custom fit at their correct location. Here is the first bracket being test fit. All the pieces ready for soldering. And the first one soldered. Now I just have to clean it up and make seven more.
  9. Hi Paddy, Ah you are off and running now! Looks good so far.
  10. Thanks Augie, Ben and Bob. Hey if you add the two together I came up with 20 coats!
  11. Hi Grant, Oh I've had so many oops moments and there wasn't always an extra piece made. Well I've assembled the carriages and painted the barrels. Sorry Ben but I stopped at ten coats of paint. Next it’s time to do some iron work and soldering!
  12. Hi Harley, That's what I did too. Sand and sand and sand with a little more sanding thrown in for good measure. Patience and time are what is needed. Best of luck.
  13. Thanks Grant. They were done individually as I did not have a block big enough. I set the table saw blade for each cut level and the cut 5 blanks progressing from lowest cut to highest. The extra one was for an oops moment.
  14. Thanks Paddy Hi Rob Yes the great crash of 2013 did touch us all. I learned I hadn’t saved as much of my work as I though I had and having a system melt down to boot would have been terrible. Well we all just start over where ever we can. Good luck with the Pinnace. It’s a wonderful kit.
  15. Thank you all for you kind words. The ruler was what was at hand but any flexible straight edge will do. Ok the nerves have settled a bit. I guess I can start working again. I've wandered back to the gun carriages. I cut them out of Bloodwood. Just because I had some and wanted a little color variation.
  16. Well all of the steps have been made and attached to the hull. The back of each step had to be sanded to fit so the tread was level. I did them one at a time so I didn’t mix them up. To keep the steps in an even row I clipped a ruler to the hull and used it as a stop. Then while I was working on the Triton the Admiral called to me and wanted me topside. Being the good mate I jumped to, set the cross section down and went to see what was up. Upon returning to the shop I looked at my work bench, and mind you I have a mastiff that can put her head on my desk with all four feet on the ground and regularly does, and almost had heart failure…………... I tipped toed over, gently picked her up and placed her squarely back away from the edge. Needless to say I didn’t do anything more that night. I figured I had used up every bit of luck I had and only bad things could happen!
  17. Hi Rob all I can say is . Typing was never one of my strong points. I went back and hopefully made all the corrections.
  18. You're right Bob. With less available modeling time during the summer I've been giving the Triton the majority of that time.
  19. Well done Augie. Great work and I think the pictures should keep you know who happy too. Enjoy your fishin' and flyn'
  20. Hi Chris. Very well done and I'm glad that you have decided to re-start building her.
  21. Thanks Paddy, Grant. Ben, There was so much I learned doing the Confederacy and I still look back at the practicum every once in a while. Here I’ve started making the entry step. I first cut the angle for the bottom portion and then made a second cut forming the tread lip. They were then cut to length and the sides trimmed to match using a xacto knife and files. Now I just have to finish making them, 18 total are needed.
  22. Hi Ben. Looking really good there. Keep it up!
