Everything posted by SiriusVoyager
Great job on completing the pram. That was a good fix on the rudder. The brass fittings are definitely too small. Looking forward to the smack!
- 33 replies
- Model Shipways
- Norwegian Sailing Pram
In your iphone settings at the top, search "camera format" and it should take you right to it.
- 46 replies
- Mayflower
- Artesania Latina
Welcome to MSW! Looking forward to the build. Your photos aren't showing up because they are in a format that only iphones use. If you change the format to jpeg they should show up properly.
- 46 replies
- Mayflower
- Artesania Latina
Continuing the work on the hull on the other side. Drilling pilot holes to cut out the gun ports seemed to work ok some times and not so good other times. I switched to a finger drill which was a better option than the dremel. As can be seen in the photos below, most of the holes were fine, but one caused some damage. Fortunately the frame seems to cover it all up, which I didn't expect. There isn't enough room to cut out the gun ports from inboard side because the knife handle is too long, so it must be cut through form the outboard side. This wasn't an easy task and caused some damage. I decided to build some frames to make it look cleaner. I tried to find images of gun ports from the inside of real and recreated ships and had a hard time finding any could be seen well. I only noticed one with a frame and couldn't really find anything on Spanish galleons. The inboard frames may not be historically accurate, but they look better. I don't like the shiny iridescence of the sapele decking and also wanted it just a bit darker so I experimented with some acrylic paint stains. I found that I liked plain ole brown the best. It is a subtle difference but I think it looks a lot better. Hopefully in the next update or two, once the cap rails are in place and the outboard gun port frames are in place it will start to look better.
- 86 replies
- San Francisco
- Artesania Latina
Nice work on your first planking. You will definitely want the hull as smooth as possible so that the second layer of planking fits on nice and flat. Using some wood filler and sanding it down again will help with that. The gaps between the hull and the keel are exactly why I say to lay the keel first. You can use the second layer of planking to cover up those gaps. Had the second layer of planking be placed first, that wouldn’t have been possible. Again, a little wood filler in those gaps can provide a bit of structure for the second layer of planking. A small rabbet along the keel, especially on the bow and stern will help hold those second planks in place.
Cutting the Freeing ports and gun ports on the starboard side is a little tricky through the sapele since it is so brittle. In the future I will cut the holes before placing any sort of veneer to avoid breakage like this. Measuring the gun ports and freeing ports on the weather deck seemed to match with the instructions almost exactly, but on the gun deck, I didn't think they looked right. The line is based on the measurements in the instructions. The two drill holes are where I estimated where they should be after doing some measurements of my own. I think the drill holes are right where the bottom of the gun ports should be. All six holes cut, sanded and filed down. There will need to be a little more fine tuning after the planking patch work dries, which I will do when I add the frames to the gun ports. I may make small frames for inboard sides of the gun ports on the weather deck to make sure everything looks nice and square. I would definitely suggest to anyone else building this model to cut the gun ports and freeing ports out prior to placing the second layer of planking. Also carefully drill a couple of pilot holes in each corner of the gun ports to make cutting them out easier. The freeing ports are too close to the deck so I wouldn't recommend drilling there.
- 86 replies
- San Francisco
- Artesania Latina
Aloha from North Carolina
SiriusVoyager replied to Charles Roseberry's topic in New member Introductions
Welcome to MSW! -
Great job! You really made it come to life in the stormy seas.
- 97 replies
I have always loved Arleigh Burk class destroyers and you have definitely done her justice. Great model!
- 97 replies
- Curtis Wilbur
- I Love Kit
Thanks for the heads up. I had a similar problem with the Palamos now that you mention it. I have some brass tape that should work in a pinch.
- 56 replies
- Cala Esmeralda
- OcCre
Thank you @tmj. I am specifically talking about the really thin strips used as a veneer over the first level of planking. Looking at it more, I think it is the iridescence that doesn’t look quite right to me. Darkening it just a bit with a stain may be enough to cover that iridescence. I’ll look into the veneers on eBay for future models as I have at least one in my stash with those strips.
Second layer planking laid, trimmed and sanded. I am going to try to remove some of the iridescence of the wood to make it look a bit more realistic. Maybe a raw umber stain.
- 86 replies
- San Francisco
- Artesania Latina
Great job! The ship looks amazing. I’ll be referring back to your build long when I start my own in about 6-9 months.
- 56 replies
- Cala Esmeralda
- OcCre
Welcome to MSW!
Welcome to MSW!
Welcome to MSW
Intro and interests, from a beginner
SiriusVoyager replied to Desert_Deckhand's topic in New member Introductions
Welcome to MSW! -
I have two of these carts from Ikea. I work at my dining room table and these make it easy to move my tools and equipment to the corner when not being used.
Welcome to MSW. This was my fourth build and it is a pretty good one for a beginner. Getting the Bulwarks on is a beast so be prepared for some frustration there. I was as conservative as I could be with the supplied wooden strips and I had a reasonable number left over, so don't worry too much about that. It looks like you are off to a good start.
I didn’t make a build log for the pram unfortunately and it’s been over 9 months since I would have been at this step. I seem to recall having a similar issue with the planks not quite fitting on the bow. My thinking is this. The planks can’t really be made larger, but the bow transom can be made smaller. I would fine tune the edges of the bow transom to fix the planks. As far as the glue, it should hold. When you use water to bend the wood, do you use hot water? My technique was to lay the planks in a glass baking sheet pour boiling water of them. After a 5-10 minutes I would clamp them across large sauce pan to get a nice permanent bend in them prior to attaching to the rest of the build.
- 86 replies
- Model Shipways
- (and 3 more)
