![](https://modelshipworld.com/uploads/set_resources_21/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
marktiedens
Posts posted by marktiedens
Thank you very much Jan.
/Mark
Keith - thank you very much. As far as what`s next,I haven`t decide yet but am leaning toward the Royal Wm. or Nuestra Senora from Occre. I have several others in my stash including Constructo`s Prince & the Model Shipways Vanguard. Maybe I`ll try working on 2 at once
Brian - thanks very much.It was a a long haul but worth the time.
/Mark
Finished.Finally. Well, I finished up by rigging the anchors & finishing the running rigging.Not sure about some of the belaying points but I think it passes the galloping horse test
. Sorry I was not a little more descriptive of some of the work but sometimes I get going on something & forget to take pictures.A lot of modifications were made but I think the end result was worth the effort. I would like to thank everyone for looking in & posting all the generous comments & hitting the like button. I will try to put a few more pics in the gallery. Now for the hard part - trying to decide what to build next
/Mark
- Keith_W, popeye2sea, GuntherMT and 12 others
15
Nice work. I am using a mixture or Corel`s plans & all the photos I can find of Clayton`s fine model. I can tell you that Mantua`s rigging plans are pretty much useless - not even close. Apparently the Vasa book will not be out by the end of the year - maybe by spring.
/Mark
Been making rope coils - thought I would take a break from that & work on the anchors. First I filed a groove around the stock so it would look like 2 pieces. Then I drilled some small holes & glued in some toothpicks,then I sanded them off smooth to simulate treenails. Then I added some small black nails to simulate bolts & finished with some satin poly. The treenails can barely be seen but that is the effect I wanted.
/Mark
I have been using Elmer`s carpenter`s color change wood filler - it is a pink color in the tub but turns white when dry. It goes on smoothly & sands easily when dry. It is water based so there is no bad odors. It is usually dry enough to sand after about 1 to 2 hours.
/Mark
- Canute and wilspaul49
2
Thanks Michael,your thoughts are appreciated.
/Mark
Hi all - a bit of progress. First I pre-rigged the yards as much as possible.
Then I attached the yards to the masts & got all the lifts & halyards rigged. May not be 100% correct but it should be close. Still a bit more to do such as braces,rope coils,anchors,& a few other misc.items. I went by Corel`s measurements for the masts & yards but the yards seem a little on the short side
.Oh well - I`m not going to re-do them at this point.
/Mark
I may be wrong but I think Model Expo used to advertise their brittania metal as lead free.
/Mark
Hi Michael - nice tops. di you make them by hand or with your milling machine? It seems it would have been easier to cut the profiles with the milling machine & them slice them off - I`ve seen many people do that with gun carriages. I found it a bit difficult to make them all by hand & keep them close to identical to each other,but the effort was worth it.
/Mark
Thanks Henry. The rigging is a little hard to see with the light background. Just shows what I know about photography
. Haven`t figured out how to keep the stays from bowing where lines or blocks are attached - if the stays were any tighter they would pull the masts way out of alignment
/Mark
- cristikc, popeye2sea, WackoWolf and 5 others
8
The best small drill bits I have found are made by Walthers. Sizes are always spot on.& they are nice & sharp. My local hobby shop carries them. They are not that expensive either - about $3.00 for a package of 2 bits.
- mtaylor and ken thomson
2
Wasa by marktiedens - FINISHED - Corel - scale 1:75 (Vasa)
Thanks Frank - yours & all the other Vasa builders were my inspiration to improve many of the aspects of this kit. As far as the flags go - they are the flags that came in the kit. I simply pinned them down in a ruffled position & wetted them with water. After drying they pretty well held their shape. I don`t know if they are the correct flags for the period but they are good enough for me
/Mark
