marktiedens
Posts posted by marktiedens
  1. A little update - I got the stern & bow filler blocks shaped & bulkhead edges beveled in preparation for the first planking. Also added a support on the lower gun deck for the mizzen mast. I will fasten the keel & stem before planking - have always done it that way. I will plank from the main deck level down to the lower gun deck so I can locate the openings for the gun ports following the lead by Vince P on his RW build. I also tapered the stern keel former down to 5mm so the planking will go up against the keel properly.
  2. Thanks Jason - welcome aboard.
    Rob - what I did was run some medium CA glue down the joints to hold the bulkheads in place. I plan to add some regular wood glue to the joints to make sure they stay in place. I do not plan to show any cut away for the interior - I will just use the false cannons for the lower decks. Unless I put lights inside it would be hard to see any interior detail & I am not adding lights.
  3. Hi all - proceeding along without any more bumps in the road so far. After dry fitting the bulkheads & decks I left the decks in place & glued the bulkheads - they all lined up nicely with the decks in place. Almost no adjustments were needed to the deck slots. I also left the decks in place when gluing the stringers in place. Extra supports were added between the bulkheads which made the framework very strong. Then I glued the lower gun deck in place along with the stern blocks - I hope they are in the correct place - it would have been nice if they would have given some kind of measurement as to their placement. I also added some bracing to the top of the stern frames as it would be very easy to break them at this point.
  4. I thought I would dry fit the false keel & stem before gluing the bulkheads & ran into a little problem. First the stem was broke in 2 places which was not a big issue - just glued it back together. The breaks were not in a spot that would be easily visible. Second - the false keel & stern post are 7mm thick but the stem piece is almost 8mm thick :huh:. After some work with the disc sander & a sanding block I got it down to the correct thickness.
  5. Thanks guys. I have been following the other logs & am aware of some of the issues. I dry fitted the bulkheads to the keel former & found I had to make a few adjustments to the slots in the forward bulkheads like the rest of you. Also frame F is a little short at the top - will need to add a shim across the top. After making those adjustments everything lined up nicely.
  6. Hi all - this will be my attempt at building the Royal William from Euromodel. I say attempt because I consider my skills as just average. Upon opening the very heavy box I took a few pictures of the contents.All the bulkheads & the keel former are nicely laser cut. The keel former is good & straight but some of the bulkheads are warped a little. The contents include the usual fittings & a lot of cast metal pieces - most nicely done. There are 17 sheets of very nicely done 1:1 plans & a lot of strip wood which seems to be good quality.
  7. Thanks Frank - yours & all the other Vasa builders were my inspiration to improve many of the aspects of this kit. As far as the flags go - they are the flags that came in the kit. I simply pinned them down in a ruffled position & wetted them with water. After drying they pretty well held their shape. I don`t know if they are the correct flags for the period but they are good enough for me :).
    /Mark
  8. Keith - thank you very much. As far as what`s next,I haven`t decide yet but am leaning toward the Royal Wm. or Nuestra Senora from Occre. I have several others in my stash including Constructo`s Prince & the Model Shipways Vanguard. Maybe I`ll try working on 2 at once :o.
    Brian - thanks very much.It was a a long haul but worth the time.
    /Mark
