                Posts3,498
Everything posted by captainbob
	WOW! I was beginning to think that I would never get to build this lovely little yawl. Ah retirement, you have no demands on your time and can do whatever you want whenever you want. Yah, right. Anyway, I finally got started. I bought a set of steady plans which gave me the lines, sail plan and brief construction plans. Using DraftSight I traced the station lines into the computer then offset for the planking and the frames. I printed what was left onto label stack and stuck that to some 1/16” basswood. After cutting them out they were glued to balsa blocks that were cut to the station spacing. Everything was then glued to a building board. Cross pieces of scrap wood were glued to each station at the sheer line as a locater for the sheer strake. That’s where It is now. Hopefully more soon, Bob
	I've enjoyed reading your build log. Well done on both the boat and the tool cabinet. Bob
- 125 replies
		- swift
- artesania latina
	Michael, Saw that first picture of the cutter on the floor and My mind saw it as a 1:48 scale and I thought 'What a great diorama of a work shop with miniature power tools.' Bob
- 2,207 replies
	  SS Vinal Haven by TBlack - FINISHEDcaptainbob replied to TBlack's topic in - Build logs for subjects built 1851 - 1900 Nice pilot house, and furniture. Well done. Bob
- 326 replies
		- vinal haven
- steam ship
	  Gripos-kaiki by Giorgos - FINISHEDcaptainbob replied to Giorgos's topic in - Build logs for subjects built 1851 - 1900 Very fine craftsmanship and great detail. Bob
	Michael, These deadeyes are much better. 1/16th steel cable is not easy to work with but you did a fine job. Bob
- 2,207 replies
	Yes, it's a beautiful little boat and the green antifoul paint sets it off very well. Bob
	Michael, I was going to comment but then Druxey and John said it for me. You're defiantly on the right track. Bob
- 2,207 replies
	If you don't mind the shine, Pledge floor finish is clear acrylic. Bob
- 135 replies
		- willie l bennett
- model shipways
	Daryl, Ah, a real steamer. I love 'em. The hull has a nice shape, it should make a nice African Queen. Bob
- 16 replies
		- river queen
- finished
	I'm with Augie. The running backstays are great. But I can't imagine going downwind and having the backstay on the side of the sail loose and laying all over the deck. That could be a mess. As always, beautiful work. Bob
	Richard, Good color choice and nice paint job. Bob
- 135 replies
		- willie l bennett
- model shipways
	Robbyn, I agree with the rest. It doesn't matter what others think, If it doesn't feel right to you, do it over. Bob
- 773 replies
		- san francisco ii
- artesania latina
	Such a nice era, sail to steam, when they didn't trust the steam so they kept the sails. Bob
	Walt, Coating the inside of the hull is a great idea. In my experience every boat it the water gets water inside, even the plastic boats. So after the sail you need to open the deck to allow the insides to dry out. Have you been following Michaels build of his pilot cutter? Here's the site. http://modelshipworld.com/index.php?/topic/74-bristol-pilot-cutter-by-michael-mott-18-scale-pof/ Also have you been contacting any of the guys in the RC Kits & Scratch building - Questions and reviews You should be able to get some good information on rigging and sail control from them. Bob
- 208 replies
		- meridea
- repair ship
	Michael, Yes the big question, what do I really want this model for? And this cutter in the water will be beautiful. Getting to and from the water is the problem. For transportation you will have to remove the mast. Have you decided how, with all the rigging you will do this? What you've done and what you are doing is great. Now I'll be quiet and watch. Bob
- 2,207 replies
	Anya, You have seen it here on MSW but usually it is not named. Make a solid hull and remove the thickness of the planking and sometimes the thickness of the frames, what is left is what is referred to as a plug. Now you lay the planks, or frames and planks over the plug. When you remove the plug you are left with just the hull. If you planked the plug without the frames, you now have to add the frames to the inside. You frequently see this on small round bottom boats like ships boats or gun boats. Bob
