Everything posted by wefalck
Some years ago I got myself a hot-air soldering station as used in electronics. Together with soldering paste, it allows the 'touch-less' soldering of delicate set-ups. As the air temperature can be pre-set between 100°C and 470°C it is useful for other applications too. It cost around 50€ incl. shipping.
Well, as was discussed in the other thread on this subject, if you can push more than the thread itself through the blocks, the holes in the block are too large, or the thread is too thin for the size of block. The sheaves were made a tad wider than the rope and the slots in the block-shell was just a bit wider than the sheave to have the sheave running easily in it. If the sheave and slot were wider, there would be a risk of the rope jumping out of the sheave and jamming in the block. Both, the sheave and the shell have to guide the rope. So, the best thing is to just stiffen the thread with a bit of fast-drying varnish (e.g. nail-varnish). You can also smooth the hole with a fine jeweller's broach - depending on the size of the block, you may want to round the edges of the drilled hole with a very fine round file in order to simulate the sheave.
Actually, some white glue or fast-drying varnish might be better ... also for the fingers . Not sure, why I wrote 'CA', as I don't really like the stuff anyway.
Somehow, I didn't see this before ... not my scale and period, I guess. The printing material is acrylic, if I am not mistaken. So either dichloromethane, a special cement for acrylic glass, or ordinary 'plastic glue' (which typically contains dicholoromethane as solvent) should do the job. With the pure solvent, dichlormethane, acrylic parts can be welded together seamlessly and without traces.
Perhaps the Chinese are not so used to Imperial measures and don't have the right gauges. I never systematically checked my drills, but doubt that the metric ones would be off by more than a few 1/100. On the other hand, I tend to buy 'professional' stuff from workshop clearance sales on ebay - needs patience, but when the opportunity arises, I stock up.
That is some artisanal talent 👍 I also would have thought of how to do this on the lathe. BTW, I had seen the 'pulling threads' somewhere before and think it gives better results than sewing on the sails. I was wondering, whether one couldn't splice the thick thread to the end of one to be pulled or to twist them together with some CA glue to make them easier to pull through, than the double thickness of the thicker thread
You may have to post this question in the digital modelling section of this forum. In order to show a geometrically correct projection of the spiled planks onto a 2-D-plane, your program would need to be able to calculate the distances between e.g. the frames and the angle at which the spline-curve of the outside shape intersects with the frames. TurboCAD does not have such functions. You would need a specialised CAD-package for that, but I don't know which one would do it. I gather one could do it the 'pedestrian' way in TurboCad too. You would need to measure the lengths (in 3D space) of the upper and lower edge of the planks between each frame and the height of each of the intersecting points above a reference plane. You then can draw the respective sections of the edges, starting from the middle, in the right orientation as projected onto a 2D surface. Not sure though, that you would be able to achieve sufficient precision that way.
A lot of French ships of that time did have half-lid gun-ports and stowed their guns that way on the upper deck. Below is an image of the BELLE POULE (1834) in the Musée de la Marine in Paris that shows the same arrangement (sorry for the pixelated image, but the lighting for conservation reasons was a bit dim): And indeed, the model of the CRÉOLE in the same museum has this arrangement. It is not Johann's invention.
I wouldn't buy these old-fashioned plates with many different thread-sizes on them. They are ok for cleaning up threads on used screws, but what do you do, when some of the more frequently used sizes get dull ? These drill-tap combinations are meant for on-site fitting jobs involving short through-holes. For sort of engineering applications they are not really useful. Down to about M1.0 or the Imperial equivalents one distinguishes between hand-taps and machine-taps. Hand-taps have a longer tip with partial threads to provide a better guidance when cutting free-hand. Hand-taps also normally come in sets of two or three with differing depth of the thread, so that one doesn't cut the full depth of the thread in one go - this improves the quality of the thread and reduces the risk of tap-breakage. Machine-taps also come in versions for through-holes and as so-called 'bottom-taps' for blind holes. The latter have a very short tapering of only two threads or so. The best taps (in my opinion) are the ones that have spiral flutes, not straight ones as most taps have. They only seem to be available down to M2.0. The spiral flute seems to leave more 'meat' in the core, hence, they are stronger. They also jam less, as the swarf is moved upwards like for a spiral drill. Industry offers dozens of varieties of taps that are optimised for different types of materials, but these are generally only available from M1.0 or even M3.0 upwards and tend to be very expensive. In both the metric and the Imperial thread systems each tap has a related drill size. However, I tend to make the holes 0.1 mm larger than required in hard or tough materials, if the screw does not need particular holding power. This reduces the likelihood of tap breakage. BTW, jewelers thread sizes are a matter of their own, they don't fit into neither the metric nor the Imperial system, and date back into those dark pre-norm ages. When tapping, I tend to start the tap manually in a machine in order to ensure that it is started concentric to the hole, but finish the tapping by hand, holding the tap in a drill-chuck or pin-vise. It is also a good idea to work the lathe by hand, when tapping or doing external thread-cutting. Most small machines are not strong enough for this and don't have propper stops or clutches to disengage the tap when a certain torque is exceeded. I fitted my lathe spindle with a hand-crank for this purpose. Unless you really buy a well-known brand, there is no guarantee these days that you get quality. As someone noted above, Asian manufacturers flood the market and European/US American dealers buy from them the same stuff that small Asian traders near the factories sell through ebay. So I am getting my needs from these sources now. I don't have that many threads to cut, so that the expense of a branded tool would not be economic. Sure, you may feel the difference, but is it worth paying five or ten times the price for a hobby application ?
In the mean-time I had a go at it and experimented with various papers. While it is easy to get the toner to stick to the brass, getting the paper off is another matter. We don't seem to have here in Paris the kind of advertising papers, so I experimented with other other types of papers from my stock. I tried a heavily sized paper that took on the toner well and resulted in crisp print-outs, but desintegrated poorly, so that I could not get off the paper. I then tried very thin silk paper (as used, for instance, for wrapping china for removal packaging) that seemed to disintegrate better, but found that it still sticks heavily to the areas with the toner and does not come off cleanly. Did you actually use parts of your advertising paper that was printed on or only clean parts ?
It seems that the proportions between lower mast and pole where changed, lowering the point where the shrouds/stay attaches. I gather there may be at least two stops on the pole, namely one where normally the lower topmast would end and then another one near the top to provide a rest for the respective stays and backstays. I didn't around to do this, but I wanted to sift through my literature a bit more to see, whether one can find some more data on this kind of masting. It was very common to mast steamships as two- or three-masted topsail schooners, or as barques that had fore- and main-mast with poles.
This discussion actually concerns an interesting paradigm (shift) in shipbuilding that occurred twice during the 19th century in commercial shiipping, namely the function of the hull and where it actually ends. As a lay-person one would instinctively think that the hull should end with the top of the bulwark. However, when one carefully looks at the way how ships were constructed, the hull as a structural element ends at the upper deck and the deck itself is not merely something dropped in, but is a structural element in itself. It seems that shipbuilders conceived the hull of commercial ships in the 19th century as a closed and (almost) watertight space. In consequence, anything above deck-level did not contribute significantly to the buouancy and seaworthiness of the ship and could be (and was at occasions) knocked away. Raising the frames above deck-level, which was done frequently in smaller and coastal vessels is a change in construction philosophy. In a way it also exposes the upper part of the frames to the forces of overcoming seas, which could structurally weaken the hull. Of course, the pre-19th century ships, particularly naval vessels, did not have this sort of sealed volume of buoancy the flush-decked commercial vessels had. With iron- and steel-ships that were subdivided with water-tight bulkheads this construction philosophy disappeared again.
Ilhan, for the moment I don't see any solid bulwark that may require stanchions. Much of the deck seems to be surrounded by rails. Only the forward area seems to have some sort of half-high bulwark. The cross-section drawing seems to indicate that frames are lead up to the raised after-deck level. As the level of that deck coincides with the top of the half-high bulwark, I would conclude that the frames are actually forming the bulwark stanchions (perhaps not all frames, but only every second or third). So there would be no need for stanchions to support the bulwark.
I didn't read the caption on the drawing carefully and didn't realise that this is actually a drawing after an etching by Baugean. Baugean's etchings have been published over the last few decades several times and an annoted edition (which is on my bookshelves) is this one: HARLAND, J. (2000): Ships & Seamanship - The Maritime Prints of J.J. Baugean.- 208 p., London (Chatham Publishing). I quickly looked through the book and found several instances where such gaff was depicted, namely images no. 18 (A French Frigate with yards-a-cockbill - in mourning), 24 (American Frigate), 38 (An American Armed Schooner), 112 (A Dutch? Galiot), and 171 (A French? Brig). In all cases it is clear that sails are bent and not flags. Harland refers to them simply as 'gaff top-sails'. And then I dived into the resources on my own Web-site and found the following two images of models in the Altona Museum in Hamburg: Ship JAVA (1852) Medium clipper TRITON (1858) It must be noted, however, that these models are not from the time, but were built by shipwrights/sailmakers around 1890 on the basis of drawings and paintings in the museum.
Baugean's drawing in the first post clearly shows sails on both gaffs on both masts. You can see the rope with which the sails are bent to the mast. Looks weird indeed.
A yard is suspended at some point along its length, while booms or a gaffs are suspended/pivoting at one end. So the item in the above image is not a yard.
True, but Beaugean shows actually sails bent to them ...
My preference is nitrocellulose lacquer or its 'filled' version, sanding sealer. The solvent is also a solvent for the wood rosins so penetration is good. One coat may be sufficient. I rub it down with steel-wool, which gives a nice satin finish. A treatment like this does not add any appreciable thickness, it is more in the surface, rather than on it. If you prefer something a bit more glossy, you can polish the surface with a soft rag - on a model you can do this also with cotton sticks all-over or just at places that would become polished by hard use. Different grades of shine create some interest in a surface and also look more realistic.
