JanV
Everything posted by JanV
  1. I just noticed your log. welcome to the group Vasa builders. I am building the Corel kit both are indead the same scale although the Billing Boats kit apears to be more accurate and based on newer information.
  2. Continued with the preparations of the mast parts, all fits in dryfit now next step will be the additional blocks beneath the platforms
  3. I fix those knots with a solution of 75% white wood glue and 25 % water. I tried first 50%/50% but then the fixation was not so good I made first 2 double knots with a very thin line above the block and then fix this with a pensel.
  4. Some modifications on the mainmast according the original
  5. started with the canon rigging I have no to figure out n correct methode to complete all other canons
  6. Did you consider to use a mixture of the white wood glue with water (50/50%) and then fix each knot with a small drop of this mixture using a small old brush consider that CA might break after several years and this is a very hard glue connection which can also break after touching once you are finished. this is my experience as well from several experienced builders in the Netherlands, we try to not use CA on shipmodels except when all other glues cannot be used I am using CA only to make a needle from the beginning of a rope so this makes it a lot easier to have the rope in small openings from blocks etc.
  7. Started with the strops for the blocks This is the 1st batch of the double 3mm blocks for the canons
  8. Hello, I noticed your log today for the first time good to see that another Corel Vasa builder started. first impression of the pictures is very good.
  9. I am following the drawings of Corel to prepare the masts. My builds are now in a slow speed due to work and private issues. I hope that the book Vasa II will be issued this year so I can correct some high visibel parys in the rigging
  10. Started with the bindings on the two masts
  11. Thanks for these pictures, I will save this information when I decide to mae the sails also.
  12. Looking forward now to see the sails on your model Sjors
  13. Sjors I have to search my files, as I am sure I have this somewhere on my harddisk. Send me a pm with your email then i will forward this
  14. This looks very good Matti. We are making a new standard all together with our Red Vasa's Your Vasa does almost get the same level as the models in the museum. Once Fred has seen this model........ I assume you are also waiting for the Vasa II book in order to start with the other rigging. For the completion of this part it is not a requirement. Let's hope it will be ready after you finished your 3000 knots
  15. Nice to see your second Vasa here Mark. As all good things you should do them twice to learn with the figures you are correct, you should handle these very carefull, special the figures you have to remove from their supports. you have noticed in the other builds of the Corel kit of course already several mistakes. maybe we can together inform Corel how to modify this kit for the future so that all new generation Vasa builders can finally select more kit manufactures with correct kits. how difficult can this be with a great example in Stockholm
  16. Today I received the blocks in 3, 4, 5 en 7mm I orderded these by clasicmodel.com first impression looks very good so I can now continue
  17. Happy Birthday Matti I noticed your post concerning the VASA II book, any updates?
  18. great to see another Vasa here. I keep following your build
  19. a dry-fit for the masts. I will fix these the next step.
  20. Thanks for your reply Michael.
  21. this looks very good Michael. just one question, what is the size of the blocks you have used?
  22. First I would like to thank all those who liked my previous posts I finalized today the stairs, I used the originals from the kit which have been sanded to make them smaller further I made the hings for the doors oops I do not like the macro on my camera
  23. Sjors; relex and have a good whiskey and try a new attempt tomorrow
  24. the last days some small points done, today I painted the doors
