Posts posted by JamesT1
On 12/2/2021 at 4:55 AM, Henke said:
Hi Jim,
Your build looks very nice indeed. Just one little detail. It looks as if you have switched the bulwark patterns 61 and 62. I did the same mistake. I am sorry if my build log have misled you because I did the same mistake. The grooves towards the stern shall face inwards towards the stern gallery.
Anyhow, a very nice build and a new approach to the gun port openings compared to the way it is done in the instructions. Thanks for posting, Jim!
Best regards
Henrik
Hi Henrik
Many thanks for the information,,, your excellent build and reports helped me immensely with the placement of part 61 and 62 however putting on the wrong one was purely down to me not paying attention when I attached it/// I just picked up the wrong one without noticing...... I'm calling it a senile moment,, my wife calls it something else...
Having built models for many years,, this is my first time trying something like this and having read many articles and watched numerous videos I decided to built it the way I like to built,,,, adding detail and trying different things,,, I started the main gun deck gun ports using the locations for the backing plates for the dummy guns,, and worked from there... once the planking and copper plating is complete then work on the interior begins
my main building interests are modern British armour and none of them are build "straight" from the box...
Many thanks for your kind words and help....
Regards
Jim
11 hours ago, Henke said:
Hi Trent,
I have chosen not to glaze the windows. There is black plastic with the kit for glazing but I have chosen not to use it. The window frames are airbrushed white which gives them a sharp a clean look. The inside of the galleries is painted dull black. You have to look very close to see there is no glazing. There is also a risk you mess up the window frame painting by adding glazing. I think it looks ok as it is. I am the type of modeller who thinks it is more important to have the look and feeling rather than trying to replicate every detail exactly. I call it artistic freedom 🙂 but I also have the greatest respect for modellers who think differently.
Best regards
Henrik
Henke,,, your model looks absolutely fantastic,,, your windows look very very nice and in my opinion don't need the plastic windows... if it wasn't for "artistic freedom" there wouldn't be models or art.....
- BenD, Henke, GrandpaPhil and 3 others
- 6
Good evening all
Lights are wired in,,,, then noticed I had missed one in the middle of the gun deck,,, so this will be spliced in tomorrow
After that ..... now to start the planking
Does anyone know where I can find drawings or plans for the aft section of the Upper Gun deck,,,, I'm specifically looking for the layout of all the cabins and berths,, including the Captains Cabin
Many thanks
jim
- AJohnson, BenD, GrandpaPhil and 1 other
- 4
Good evening all
Had to put my Aggy on the back burner for a few months,, turned into a couple of years,,, but back on it again.....
My plans are to put lights into the model,,, to that end I have been working on the gun deck... whilst this area will be enclosed some of the details should be seen through the gun ports (he said hopefully),, I also decided to practice my deck planking here where all my mistakes would not be seen (again he said hopefully),, one very obvious one if the bleed through at the ends of the planks..
The model supplied bulkheads have also been opened up,,, along with the bulkheads where the stern galleries are
- CaptnBirdseye, mort stoll, Henke and 2 others
- 5
As per the guide, the first parts to be assembled were the attachments of the 'Bow', the ‘Keel’ strips and the 'Ruder Post'.
The first thing I noticed was the bow was not a snug fit,, there was a gap of about 2mm in the centre of the pieces when lined up with the main keel. To compound the issue the bow would move In both the vertical and the horizontal plain.
This lead to the question: Do I trim the Bow and if so , in what plain do I trim it to fit….. whilst thinking about it I decided to look at the Keel strips and the Rudder post,, when dry fitting them I noticed they were a nice fit so decided the best plan of action was to fit from the rudder post forward…
This led to the bow fitting nicely at the top and at the junction with the keel strips this was glued in that position with the gap filled the following morning
- GrandpaPhil, Edwardkenway, zappto and 2 others
- 5
Good afternoon all
Well after reading so many excellent logs for some fantastic models, I have decided to build my own and share the experience...
After a lot of reading research I decided to go with the Caldercraft HMS Agamemnon in 1:64 scale, please don't ask me for a reason,,, whilst reading through a lot I really liked the look of her, the more I read the more I liked,,, in addition I also liked the look of HMS Diana,, Diana will come later...
Whilst I am not a beginner when It comes to modelling, I am a beginner when it comes to wood and ships, so please shout out when you see where I may be going wrong… This log hopefully captures my experiences both with kit and what I do to resolve any issues, I create and resolve
So here goes,,
These are the photos for the checking of the main keel and the bulkheads. As I planned on cutting into the bulkheads I required them to be fairly easy to put on and take off
Two beautiful ships Chris,,, is the smaller one the Agamemnon
Many thanks
Jim
- FrankWouts, Elijah and mtaylor
- 3
Good evening Christian ,,,, I have been following your build of the USS Confederacy for a while and can I just say the quality of your work is outstanding..
If I may ask a question,,, what wood did you use for the decking
Many thanks
Jim
Good evening all... I hope everything is well with you...
Can anyone tell me if they have used a glue called Titebond,,, if so what are their thoughts on it... and what one did you use,, The Original,, Premium or Ultimate
Many thanks
JT
Good Morning Mark
Not yet,,, it will be a couple of weeks before I start the model,, so not too much of a hurry...
The general consensus is for a light wood, so in addition to the wood supplied with the model and the Basswood I have ordered some Obeche Stripwood to look at...
I have book marked some Beech, Cherry and Pear Stripwood... just In case I'm not too happy with the others.... although the Cherry and Pear look to be a bit dark for my needs...
I'll keep you updated...
Many thanks
Jim
Many thanks for the answers guys,, ... the kit looks really nice,,, after modelling for more years than I care to remember,, mainly, 1:35 modern British armour, in multiple mediums,, I've decided to try something different,, long term as I retire in 4 weeks,,this will be my first large scale wooden model...
As part of my hobby, I find it enjoyable to carry out as much research as possible,, my wife says I'm too much of a perfectionist,,,...After reading a few of the excellent logs on MSW,,, I thought I would ask the question about the wood for decks,,,...
The kit came with1 x4mm Tanganijka strips for the decking,,, it looks OK,, however I was just wondering what type of wood would look nice... and authentic... I find in the plastic model world,, manufacturers can make things over scale,, or miss out the finer details,,, but part of the fun is putting it right... it would be boring if you just opened a box,, and glued it together in a couple of hours,, etc...
The kit also comes with Limewood and Walnut for the 1st and 2nd planking
pontiachedmark, I'm from sunny Scotland,,,,,I recently bought some basswood... sheets and strips to have a look at that,,, I was also looking at pear wood …...
Many thanks
Jim
Good afternoon all
I'm planning on starting the Caldercraft HMS Diana shortly.. What type of wood is recommended for decking a 1/64 scale ship.
Many thanks
Jim
19 minutes ago, Cabbie said:
Well if that's the case Jim. "We won't speak to her."
So you go right ahead and have a ball doing lots of modelling.
And welcome to MSW
Thanks Cabbie,,,, let me know how you get on by not talking to her,, I've tried that over the years,,, just gets worse for me...
Hi everyone.. just to say hello... been building models for many years,, but not anything that travels on water,,,,,
retiring soon and looking for something different and long term,,, always liked working with wood..built a couple of small wood models recently getting to know the medium,, I will be starting a long term project soon
although if you speak to my wife.. she has other plans for my time...
Anyway good morning and happy modelling
Kind regards
Jim
3 hours ago, davyboy said:
Hi Jim,
There is a huge difference,Basswood aka Limewood is fairly soft and it's difficult to get a sharp edge on it. It'sOK if you're double planking. European Boxwood (Buxus Sempervirens) is very hard,hard to find and expensive. Most of the references on the forum to Boxwood are refering to Castello which is a South American timber misnamed Boxwood,very nice timber but not the real thing. Also hard to find in Europe and not cheap. AFAIK most kits supply Walnut for planking etc,OK but grainy. Personally I use Pearwood,nice colour and showing little grain,also readily available in Europe
I can't speak for UK timber dealers as I buy my wood from a German dealer. However I'm sure there are UK timber dealers around on the internet. Maybe some of the British members could help there. TIP :- If you wish to buy wood in,don't buy strips. Buy sheets and cut your own planks etc from them,much cheaper.
Dave
Thanks for the tip davyboy… I have been looking at strips and ordered a couple of basswood strips earlier just to have a look at them,,, think I'll start to look at the sheets from now...….
Many thanks for all the help and advice folk,, much appreciated..
James H... Apologies for posting in the wrong section...
No Idea & Morgan,,, many thanks for the links,, now I know where to look in the UK.....
My real boss,.,, sitting watching her soaps at the moment is dreading this,,, she has other plans for me,, at the moment
Happy modelling folk
JT
Hi Guys
Been building models for many years,,, no ships,, I am looking at a change when I retire in a few weeks,, so long term build,,, always liked working in wood and have built a couple of small models recently to get used to working in this medium...
I've been looking through a lot of build logs recently... and notice a few talking about boxwood... in the UK I can get some basswood but not boxwood...what is the difference between boxwood and basswood..
Many thanks
Jim
HMS Agamemnon by JamesT1 - Caldercraft - 1:64
Gun ports on the Starboard side completed with the 1st planking
