Thanasis
Everything posted by Thanasis
  1. Well, in fact there is a way to correct a mistake and remember it without feeling bad...Change its artistic presence.... Thx https://modelshipworld.com/topic/4157-my-greek-state-of-mind/?tab=comments#comment-118069
  2. This is really nice work. Clean painting lines, nice hand crafts and impressive bow ornament. Congratulations. Thx
  3. You're right George. There is a transom in the stern although the bow follows the shape of a typical trechantiri's hull. Well, it was not common but yes there were cases where in Gr. traditional shipbuilding, transformations appeared in a typical shape of a hull. These hulls-boats were called "Bastards" or "Mule" and were being built for certain use purposes ... However I haven't hear or found anything about a Trechantiri with transom in Aegean Sea. So I can only guesses for what reason this occurred in some Gr. boats in Tarpon Springs. One could be that it's been kept the transom from the original Symi's hull Skaphe, avoiding the narrow bow of her (as it was "Tserniki" hull with pointed prow), gaining this way space. Another one could be the adjustment in the local sea conditions. After all, you know the Gr. innovative spirit... As about the rigging and although must be an engine in the boat, it's been kept Skaphe's mizzen. I guess again for the same reason as the initial one, where when a diver was at the seafloor, the captain (the boat) had to follow him by skillful handling of the tiller and the mizzen... Thx for the rostrum...
  4. Hi George. To secure your confidence on where a mizzen sail could be placed, allow me say this in short... Once when I was dealing with a model of a peculiar Gr. sponge fishing vessel from Symi Island and seeing old models and engravings where the mizzen sail was set on the handrails of the stern, I had the same doubts as you. It was after a few years when some photos from Tarpon Springs and the sponge fishing boats of the Gr community, revealed the truth. The shipbuilding tradition was transferred there and had been kept until recently. Ps: The model of Skaphe is not mine… Thx
  5. About the "trincarino" and the frames, it's ok Gb. I have been also through these misjudgments and as my teacher used to say: "I'm sure you will remember it in a next model".🙂 Well, my idea for representing of hairy cup-cover on the steampost is simple but I think quite effective. Take a pipecleaner and make some loops on a rod close to the stempost's dimentions... You can leave it this way, or you can cover the rod with thin paper, place some white glue and make the loops . If you don't like the usual color, you can use water colors and a paintbrush to make some black highlights. Thx
  6. Gb, sorry for the space abuse but just for the knowledge. http://www.veniceboats.com/trabaccolo-pelliccione.htm Thx
  7. As far I can remember there was such a discussion (lost with Msw1) about that fleece, in which the main viewpoint was that it used to be set there, to protect the sails from the long stempost (?) @Gb If you follow the "curly hair" version on the stempost, I have a very good Idea. Thx
  8. Take a look there: https://www.cherini.eu/etnografia/Italia2/index2.html at no 117 and in the next page, from no 188 to 202. But I'm sure you will find interesting all the sketches... Thx
  9. Hi. There's no need to place more frames... In fact, I think that pair in left and right of the stempost are not required but you may leave them as supporters of the gunwall and inner structures. I can't see clearly, so I guess the same happens at sternpost. But I I think an image speaks better... So see the correct installation of the frames that are facing the central axis. You should think that if they were real frames, they already would have been installed vertically on the keel... Trincarino is the Italian term (Trepetee or courzeto in Gr) for a kind of margin plate with cuts, that locks the frames at the level of the deck. Depending on the method that a modeler builds a hull, is usually placed on an already finished deck and before the false frames on which they step... See the links (needs translation even it's not accurate) Thx https://www.treccani.it/vocabolario/ricerca/trincarino/ https://nautipedia.it/index.php/Trincarino
  10. Nice work Though, I think it would be more accurate, if the frames at stem and stern post, had been placed (or been trimmed) facing to the central axle of the hull. Aren't you going to place a margin plate (trincarino)? Thx
  11. Hi. Unless you have already think about, I would suggest to reconsider those formers you have placed to have curved deck. Being glued only in three points, you might have unstable parts of the deck, when you cut openings, since you will cut also part of them... Just a thought. Thx
  12. Hi. You might find helpful to see old photos of Malta’s – Gozo boat or dghajsa or Tal-latini (all names for the same boat) Thx M
  13. I would be pretty fortunate if there was any relation with any Malta's boat, since I'm searching for this.🙂 However, I'm afraid that the two masts in sequence (spritsails) do not suggest either Luzzu or Speronara (Xprunara) Maltese boats. Many thanks
  14. Hello. The below photo was taken in port of Chania (Crete-Greece) at early of 20th century. Is there anyone who might have come across this kind of rigging from Black Sea to Mediterranean. Many thanks
  15. Hi. I'm not familiar with Greek ancient ships but I collect whatever seems rare and useful for others... So take a look there https://www.scribd.com/document/249688135/Georgio-u or you can make a search with the term "BRONZE AGE SHIPS AND RIGGING pdf". Thx
  16. Thank you all. Shooner. I buy tools only when I have exhausted all my other options. Ship modeling should be something joyful, rather than stressful... Thx
  17. Hi all. Here is my method that I used to follow in the days of MSW-1, when I was younger and more passionate... Thx
  18. I have two sketches-ways in my library, that might help you a bit. Sorry but I haven't kept the source... Thx
  19. Beautiful, precise and clear work. Well done Γιώργο (George)... Thx
  20. I reply myself from another post... You could try by visiting a local repair store in which, a non functional CPU might be given for free, related fb pages where you can find them also for free or by an exchange and finally from the ebay starting from around 2 euro-dollar. Thx
  21. Hi Glenn. I don't see any blasphemy. I prefer the shortcuts whenever I can. Proper shortcuts is another kind of skill...🙂 So, every old processor (CPU) can give you many tiny nails with round head. Depending on the possessor you can have different sizes. It might help you if you decide not to make just pencil marks. Thx
  22. Μιχάλη Καλώς ήλθες... Michel Welcome aboard... Thanasis Thx
