Posts posted by Paryzek
I report further progress. The first layer of lining is ready. I used wood putty on the small bumps, sanded it smooth. I will apply some thin wood glue and I can continue. Linden is a fairly soft wood. I had to grind carefully. It would probably be better to use a stronger profile. At least 1.5mm. But the second layer will strengthen the whole thing.
I've been following this build since the beginning. It's absolutely amazing what you can do. Thanks for sharing. It is very enlightening.
- Keith Black, mtaylor, archjofo and 4 others
- 7
It looks very good for a first model.
I'm starting to plank the hull, it will go slower now. I was thinking about using my own material instead of the linden from the kit. 2x4mm spruce beams. But it was really a problem to bend them in the back so that they fit properly. Very stiff material for such an arch. So I'll trust Chris that the linden is fine.
What the hell is the translator doing? I entered the text in English, and he returned it to me in Czech. (automatic translation in google chrome)
- Cirdan, Ondras71, Knocklouder and 5 others
- 8
I prefer to grind by hand, so you can monitor the line better. Machine sanding saves a lot of work, but can make more mistakes.
- mtaylor and CaptnBirdseye
- 2
3 minutes ago, Ondras71 said:
Rád tě vidím zpátky v plné paryzkovské práci. Dobrá práce!! Ondráš
Thank you, I am trying. The wife helped significantly financially to buy the kit. A belated 50th birthday present. I process the model very well. So I hope it goes well. I follow your work. 👍
- Cirdan, James H, Knocklouder and 4 others
- 7
- chris watton, Haliburton, Peta_V and 12 others
- 15
I'm glad it's going well. I'm watching from the front row.
- Blue Ensign and mtaylor
- 2
Very nice, it has style.
- mtaylor, Ondras71, Rock_From_Korea and 3 others
- 6
Jak koukám na fotky, budu muset přelakovat matným lakem, červená je moc lesklá. Zvláštní, barva je normálně matná.
Maybe it's the light, I'll see in the daylight.
- Ryland Craze, James H, BenD and 1 other
- 4
- BenD, hollowneck, James H and 7 others
- 10
- James H, KARAVOKIRIS, hollowneck and 7 others
- 10
- ccoyle, Knocklouder, Cirdan and 8 others
- 11
This is my first build log on MSW so please bear with me.
My English is bad, but with the help of a translator I can understand. The building kit probably needs no introduction. Chris did a perfect job. (I bought through the Czech supplier Astra models)
The start of construction has been here several times, so the current status so far. I hope my work will interest you.
(I can't take photos very well and I only have a decent mobile phone. sorry for the poor quality of the photos)
- hollowneck, Ondras71, JeffT and 16 others
- 19
Hello Alex
Beautiful model, fantastic work. Congratulations.
It may be somewhere to store photos in a larger format and insert a link? ,I would like to inspect details. Pictures on the forum are small.Pavel
Ah yes, I understand, so let thrive.
Would not it be better it throw out and start again?
This will probably also shoot it? Perfect.
HMS Sphinx 1775 by Paryzek - Vanguard Models
I continue with the planking of the second layer. Unfortunately, little free time. Nice weather outside. .
