Bob Legge
Posts posted by Bob Legge
Slocum's SPRAY:
I remembered this article
https://www.boatdesign.net/threads/slocum-s-spray.30617/page-26
and
https://en.wikipedia.org/wiki/Sailing_Alone_Around_the_World
See Reference link.
Bob
There is a plan in the NMM.
Belle Poule fl.1780 (French, captured) ZAZ3117 J6627
An image can be seen here:
https://collections.rmg.co.uk/collections/objects/82908.html
Sister Ships DÉDAIGNEUSE 1776, AMPHITRITE 1768, TOURTERELLE 1770Also:
Catalogue des Plans - Les Archives de la Marine
2030 Page 176 Frégate << La Belle Poule >>. << Construite à Bordeaux en 17.. par M GUIGNACE. L'Enphitrite & La Tourterelle ont pareillement été faites à Baux par le même ingénier .. Non signé ni daté [vers 1764].
Tracé des formes de la coque : pl. vertical. Encre noire. Dim. 0.53 x 0.40.
2G4.3, no 65
Regards,
Bob.
A hint on serving:
"Worm and parcel with the lay,
Turn and serve the other way."
From Longridge page 209 - SERVING AND WORMING.
Bob.
Egyptian Oars and Vessel:
Jenkins, Nancy, The Boat Beneath The pyramid (King Cheops' Royal Ship), 1980, Thames and Hudson Ltd., London, ISBN 0-03-057061-1
The reconstruction of a dismantled complete vessel which was found in a large covered stone pit at the base of the great Pyramid in 1954.
Length 43.4 metres, beam 5.9 metres, depth (aft of midships) 1.78 metres, draught 1.48 metres.
Bob
- thibaultron, EJ_L and mtaylor
- 3
I Like your books. Especially Witsen, Tasman Ships and Dutch Merchant ships (Text and plans).
Regards,
Bob.
Rigging sizes
Noel C L Hackney in HMS Victory Classic Ships No 1 by Airfix, 1970 gives a variation on method of calculating sizes (counting rather than measuring).
He made marks on a pencil 1 inch apart. He then wound the line around the pencil, counting the number of turns to fill 1 inch. Calculating back (or using a small spreadsheet) gives the circumference.
His results as printed for Airfix Victory - Scale 173
Thread or line size TPI Rope size (inches) Scale 173
12 lb 3-strand nylon salmon line 38 14
No 12 Super Gimp 40 13 1/2
No 50 synthetic 60 9
No 24 merc cotton/No 70 synthetic 70 7 1/2
No 90 synthetic 80 7
No 16 waxed 85 6 1/2
No 24 waxed / No 36 merc cotton 90 6
No 40 merc cotton 100 5 1/2
No 110 synthetic 104 5 1/4
No 120 synthetic/No 120 spun tereline 110 5
No 60 soft cotton 115 4 3/4
No 140 synthetic/75 denier teryline 120 4 1/2
Monofilament nylon fishing line 0.2 mm 4
Monofilament nylon fishing line 0.175 mm 3 1/2
Monofilament nylon fishing line 0.15 mm 3
Monofilament nylon fishing line 0.1 mm 2
He first states "the diameter of threads ... is not related to the thread number shown on the reel except in the most general way. That number is simply the count of how many hanks of that thread of a given length are needed to total a given standard weight, and it therefore follows that two threads of the same number can differ considerally in thickness if their basic material (cotton/man made fibre) of their treatment (waxed / mercerised) makes a variation in their weight per yard. Thus the standard No 40 cotton, No24 waxed thread and No 110 synthetic are almost the same thickness".
Regards,
Bob.
- archjofo, billocrates, AON and 1 other
- 4
The voyage pattern changes at different times of the year. One of the major concerns are the currents. They can assist or slow a vessel. See 9.42.02 Brazilian coast. The vessels follow the sailing directions below.
The follow is from:Ocean Passages For The World; Third Edition 1973; Published by the Hydrographer of the Navy; NP136; To be obtained from the Agents for the Sale of Admiralty Charts. Taunton.
This book and attached charts contains directions for Power Vessels, and Sailing Routes.
Chart 5308 - World Sailing Ship Routes.
Chart 5309 – Tracks followed by Sailing and Auxiliary Powered Vessels.
Direction from the Book
Page 149
9.44 From Canada and east coast of Untied States.
9.44.02. For Capetown and Good Hope.
Having crossed the Equator as recommended, stand across the South-east Trade Wind on the port tack, even should the vessel fall off to about 260deg, for the wind will draw more to the E as the vessel advances, and finally due E at the S limit of the Trade. When in the vicinity of Penedos de Sao Pedro e Sao Pedro, frequent astronomical observations should be made, the current should be watched and allowed for, and a good lookout should be kept, as these rocks are steep-to and can only be seen on a clear day from a distance of about 8 miles. The same precautions are necessary, if passing westward of Ilha de Fernando de Noronha, when approaching the dangerous Atol das Rocas.
On approaching the Brazilian coast between March and September, when the wind is from the SE and the current near the coast sets N, it will be better to keep from 120 to 150 miles off the land until well S, and steer so as to be windward of the port of destination; but from October to January, when the NE’ly winds prevail and the current sets SW, the coast may be approached with prudence, and a vessel may steer according to circumstances for her intended port.
9.44.03. For South American Ports, proceed as for Cape Town (9.44.02) as far as 5deg S, and then follow the directions given in articles 9.07.04 to 9.08.02, as required by the destination.
Page 141
9.07.04 From the Equator southward.
(not copied)(not copied)
Page 229
11.129 Cabo de Hornos to San Francisco and northward.
For San Francisco, having rounded Cabo de Hornos as directed in 9.08.02, stand to the NW so as to cross the parallel of 50deg S between 80deg W, and 85deg W, and then due N to 30deg N. Thence keep off to the NW, running through the South-east Trades to cross the equator between 112deg W and 115deg W, being to the E, throughout the whole voyage from Cabo de Hornos, from September to November; and to the W from June to August.
After crossing the equator, steer so as to cross the meridian of 120deg W in 13deg N to 15deg N, where the route divides into two branches, according to season.
From November to February, make for 30deg N, 132deg W, and from that position, when the W’ly winds are met, curve gradually round towards San Francisco, making it to the N, and allowing for the current setting SE across the track.
From March to October, make for 30deg N, 137deg W, and from that position, when the W’ly winds are reached at about 35deg N; again allowing for the SE-going current across the track.
For Columbia River, Juan de Fuca Strait, or Prince Rupert, follow the routes given above as far as 30deg N; then continue to the NW, curving to the E on reaching, or nearing the parallel of 45deg N, to make destination, allowing for the current as above.
Also ARDENT (1764), BELLIQUEUX (1780), NASSAU (1785), RAISONABLE (1768) and STATELY (1784), based on the French FOUGUEUX according to Lyon.
Bob.
- Canute, mtaylor and uss frolick
- 3
In "The Bends of a Ship" by Thomas Fagge Circa 1700, the bends (frames) are assembled with chocks and scarphs. The scarphs being on all the top timbers, the fashion piece Bend 31, and on one of the stern half floors, Bend 28.
All the others are chocks.
Bends illustrated are Flatt, L, O, R, 1, 4. 16, 28, 31, and a half frame of a central bend used to illustrate repairs.
Bob.
I suggest you have a look at some Turbocad tutorials on youtube. These will give you the basics of using CAD and the reasons for doing so.
The link below is for a later version, don't upgrade, your version is more then adequate. The screen will be different though. It may be harder or easier to find what he is talking about.
TurboCAD Class 1 Orientation - YouTubeThese give a very good start to learning the CAD program. You can then make a decision on whether to progress further.
CAD software has developed over the years. The help is very good, and there are low cost tutorials available.
Bob.
TIMBERING PLANS THE 74-GUN SHIP The 11 timbering plans (1/72 or 1/48) with a color 24-page booklet with a series of photographs illustrating the implementation of the framework.
The essential complement to your 4 volumes
http://ancre.fr/en/ouvrages-de-base-en/73-plans-de-la-charpente-du-v74-canons.html
Two possibilities of substitution of decoration are offered: the 1782 CENTAURE and the 1785 SUPERBE.
Ancre now produce the above for the 4 volume book Le Vaisseau de 74 Canons - it is available in English, French and Italian in 1/72 and 1/48 scale.
Hubert Berti who produced the Ancre books has died and the Publisher is now run by his son, D Berti. We are greatly indebted to both Jean Boudriot who has also died, and Hebert Berti for the production of these books. The collection is of great historical importance. Many of the books in the collection were written by them.
Bob.
For further information see:
Lloyd, Clive L.; A History of Napoleonic and American Prisoners of War 1756-1816 Hulk Depot and Parole; Antique Collectors Club, 2007; iSBN 978-1-85149-528-3
Lloyd, Clive L.;The Arts and Crafts of Napoleonic and American Prisoners of War 1756-1816; Antique Collectors Club, 2007; ISBN 978-1-85149-529-0
The volumes include the POW camps as well as the hulks.
The second volume has photographs of all the crafts which were made and sold at the markets. Two superb volumes.
Also
Campbell, Charles; The Intolerable Hulks British Shipboard Confinement 1776-1857; Fenestra Books; Tuscon; 2001 (3rd Ed) pbk; ISBN 1-58736-068-3
Mainly about convicts and transportation - Australian connection.
Regards,
Bob.
The Elements and Practice of Rigging And Seamanship, 1794, by David Steel
Is on line at the following:
OR
http://archive.hnsa.org/doc/steel/index.htm
The book is all there including the Plates in High resolution.
Regards,
Bob.
Looking for plans or possible models of Magellan's ships.
in Nautical/Naval History
For Gilberto Penzo's book
Google Type gilberto penzo select gilberto penzo shop from list
SELECT
Gilberto Penzo - Venetian Boats and Ships
Select Go Online
The book is still available and the plans can be perused.
Bob.
