Everything posted by druxey
Harold Hahn method
druxey replied to Essayons's topic in Building, Framing, Planking and plating a ships hull and deck
"Chacun à son gôut" - Each to their own taste. We build models to please ourselves. There is no absolute right or wrong. -
Consider using tick strips and divide the space with the strip laid flat - it's a lot easier! I gave up using compasses, dividers and proportional dividers years ago. Also, thread attached with white glue dots instead of battens are much, much easier to use. Check the planking tutorials on this site. for details.
Normally beams rest on the deck clamps. These are ledges that run longitudinally inside the frames. Beams are placed where needed to frame deck openings etc., and are independent of the framing. I recommend you look at either Londgridge's The Anatomy of Nelson's Ships, Goodwin's The Construction and Fitting of the Sailing Man of War 1650 -1850, or the series of books on the fully framed model by Antscherl.
A very nice model indeed. Maybe Chris would like to tackle a Thames barge sometime.
- 29 replies
- well smack
- Vanguard Models
Another sceptic converted! Very effective, Rob.
- 3,560 replies
- clipper
- hull model
NAIAD 1797 by Bitao - 1:60
druxey replied to Bitao's topic in - Build logs for subjects built 1751 - 1800
Lovely! -
Looks very nice, Siggi. Had you thought of painting the decorations on paper off the model and then gluing it on? Much easier than fighting gravity and getting into the inner corners!
Greetings MSW , from Montreal Canada , new novice member .
druxey replied to AlleyCat's topic in New member Introductions
Welcome aboard et bienvenue Rick! -
HMS EURYALUS by Matiz - FINISHED - scale 1:56
druxey replied to matiz's topic in - Build logs for subjects built 1801 - 1850
Nice detail on the chain pump return tubes! -
Coming along well, Kevin. Hint: always rest a plane on its side. Sole down on the bench as in your photo leads to dulling the blade faster with grit and debris on the bench top.
- 1,136 replies
Perhaps tone down the white a bit? Hard to tell from your photo - you might already have done that.
- 740 replies
- Tudor
- restoration
(and 4 more)
SOLEIL ROYAL 1669 by michel saunier
druxey replied to michel saunier's topic in - Build logs for subjects built 1501 - 1750
It is indeed sad that we have lost such a talent. I was wondering if another expert French model-maker might pick up the torch and complete this masterwork, if his family is amenable to the idea. -
spile from here to here
druxey replied to rudybob's topic in Building, Framing, Planking and plating a ships hull and deck
Before you do that, I might consider tapering the garboard back a little more. If you don't, plank widths will get 'squeezed' or tapered too much into the bow. Take a look at "A primer on planking" to see what I mean. -
An excellent result, although personally i'd like to have seen a little more 'sea-room' fore and aft of the hull. But, it's personal preference!
Festool shop vacuums - a quieter option
druxey replied to druxey's topic in Modeling tools and Workshop Equipment
The Festool will cut out when the bag is full. Is that the problem?
