druxey
Everything posted by druxey
  1. Well, I wouldn't like to see one coming at me from the angle in your last photo! Joking aside, casting that quantity of bronze must have been quite the operation back then.
  2. Sweet result! Getting a nice tight joint with the bolster is tricky and you've done a lovely job.
  3. Try to put elastics-etc, over the frames, or the planks will be distorted! Easily fixable by dampening, though.
  4. Neither, Allan. The cut pieces strip off the backing easily and remaining rubber cement removed with a piece of crepe rubber or finger.
  5. I thickness a sheet of wood, rubber cement it to a sacrificial backing of either basswood or illustration board, then run it through the table saw using a slitting blade. 1/64" square in holly or Castello is no problem.
  6. Is the difference in leg length related to the deadeye on the long strop (your original post, photos 2 and 3)?
  7. I can't keep up with all the reading that you are supplying, Bruce! This is fascinating stuff. Thank you.
  8. Much more like the contemporary models with the rail abutting the step!
  9. Hopefully we can answer your questions, Mike.
  10. Now, those are crowsfeet! Well done. At the risk of being a pain, can you shape them mouses a little more mouse-like? (Hint: stays go over the shrouds. See photo.)
  11. You have the right idea. The lower deadeyes still have their laniards in place in your last photo. The upper deadeyes were attached as you see them, with a metal sheerpole lashed just above to keep the upper deadeyes from twisting around. The longer stropped lower deadeye must be for something else; perhaps a topmast stay? The shroud pair was looped over the mast head and this appears to have the lashing below the loop still in place. There are remains of the ratlines still there, so that will act as a pattern for spacing the replacements. I imagine the rigging is now brittle so should all be replaced. An interesting project!
  12. Very informative. Thank you, Bruce!
  13. This from BBC: https://www.bbc.com/future/article/20220426-battle-of-the-aegates-the-shipwrecks-rewriting-roman-history It's quite a story of the discovery of the site of this battle and recovered artifacts.
  14. Lovely. Good luck with the cathead supporters. Those are the hardest pieces in the ship to make!
  15. Looks a bit like convolvulus. However, a botanical expert may know better!
  16. The issue with square-hole drawplates is that they are designed for pulling metal wire through. It essentially squeezes metal; it doesn't cut. Wood needs to be cut or shaved; it really doesn't squeeze well! That is why a drawplate for wood, such as the Byrnes' is of a different form than a traditional jewelers' drawplate. I don't know of such a square drawplate design on the market.
  17. As Allan wrote, you can edge bend, but within limits.
  18. Much grist for your mill, Sam!
