Everything posted by druxey
Well, I wouldn't like to see one coming at me from the angle in your last photo! Joking aside, casting that quantity of bronze must have been quite the operation back then.
Sweet result! Getting a nice tight joint with the bolster is tricky and you've done a lovely job.
- 589 replies
- le gros ventre
- cargo
Try to put elastics-etc, over the frames, or the planks will be distorted! Easily fixable by dampening, though.
- 34 replies
- first build
- Model Shipways
Glad you don't have to make that over after all, Marc!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Is the difference in leg length related to the deadeye on the long strop (your original post, photos 2 and 3)?
La Belle: Archaeology of a Seventeenth-Century Ship
druxey replied to bruce d's topic in Nautical/Naval History
I can't keep up with all the reading that you are supplying, Bruce! This is fascinating stuff. Thank you. -
Nicely and sympathetically done, with a great result!
- 71 replies
- great harry
- henry grace a dieu
(and 3 more)
Much more like the contemporary models with the rail abutting the step!
- 857 replies
- Sphinx
- Vanguard Models
Hopefully we can answer your questions, Mike.
Now, those are crowsfeet! Well done. At the risk of being a pain, can you shape them mouses a little more mouse-like? (Hint: stays go over the shrouds. See photo.)
- 542 replies
- Sphinx
- Vanguard Models
(and 3 more)
You have the right idea. The lower deadeyes still have their laniards in place in your last photo. The upper deadeyes were attached as you see them, with a metal sheerpole lashed just above to keep the upper deadeyes from twisting around. The longer stropped lower deadeye must be for something else; perhaps a topmast stay? The shroud pair was looped over the mast head and this appears to have the lashing below the loop still in place. There are remains of the ratlines still there, so that will act as a pattern for spacing the replacements. I imagine the rigging is now brittle so should all be replaced. An interesting project!
Woolwich Royal Dockyard archaeological investigations
Very informative. Thank you, Bruce! -
This from BBC: https://www.bbc.com/future/article/20220426-battle-of-the-aegates-the-shipwrecks-rewriting-roman-history It's quite a story of the discovery of the site of this battle and recovered artifacts.
Lovely. Good luck with the cathead supporters. Those are the hardest pieces in the ship to make!
Swan-Class Sloop by Stuglo - FINISHED - 1:48
druxey replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
Looks a bit like convolvulus. However, a botanical expert may know better!- 475 replies
The issue with square-hole drawplates is that they are designed for pulling metal wire through. It essentially squeezes metal; it doesn't cut. Wood needs to be cut or shaved; it really doesn't squeeze well! That is why a drawplate for wood, such as the Byrnes' is of a different form than a traditional jewelers' drawplate. I don't know of such a square drawplate design on the market.
Planking Primer.pdf
druxey replied to rudybob's topic in Building, Framing, Planking and plating a ships hull and deck
As Allan wrote, you can edge bend, but within limits. -
Much grist for your mill, Sam!
