Posts posted by CaptainSteve
- GLakie and Captain Slog
- 2
Denis,
I've just discovered your brilliant log and have decided that this kit is going on my Wish List.
With regards doing your rat-lines, in the past I used two combs.
I'd hold the first comb flat (horizontal), tie a single rat-line in place with loose knots, then push it down into position with the second comb. The shrouds/stays will fit between the tines of the combs.
Tighten the knots with tweezers.
Hope you find this helpful.
Arr !!
I had a visit from my old mate, MrCritic, last night.
As these meetings usually go, razor-knives were drawn. By the time we were done, the half-moon hatch from the recently rebuilt whale-boat had been mortally wounded (read "removed").
It won't take me too long to re-make this.
I have to admit, though, he was right. That hatch-cover was at least 1mm too big - and maybe even as much as 1.5mm - so it HAD to go !!
Once they are finished, then some oar locks (tholes), the rudders and furniture.
And then I should finally be ready to re-create that picture of yours from so many months ago, Geoff !!
Having noted what you said about cutting back on furniture, I have been giving the matter some thought.
Here's what I've come up with (not set in concrete):
Captain's Gig
1 furled sail
2 bunches of two oars (tied)
2 coils of rope
Rudder mounted
Whaleboat 1
3 bunches of oars
Coiled rope around winch drum
(leading to harpoon at prow)
2 Winch-poles
2-3 Coil of rope
1 bucket
Rudder mounted
Whale-boat 2
AS ABOVE EXCEPT
1 bundle of 5 oars
Rudder stored on-board
Pinnace
1 bundle of 7 oars
2 Boat hooks
2 furled sails
1 bucket
3-6 coils of rope
Also, I've had a re-think on the cap-rails for these two boats.
I happened to acquire some sheets of veneer-thickness wood from a business I visited the other day. To them, it was just scrap left-over from a job - to me, it was 1.5sqm of trim, detail-strips and cap-rails !!!
As the grain was a bit loose for small scale stuff, I coated one sheet with PVA, and sealed by pushing the glue into the grain, then left it to dry with a pile of books sitting on top.
Once ready, YET ANOTHER tracing of the cap-rails taken from the plans and glued onto the veneer ...
Just a quick update after a very busy weekend of work (I drew Saturday shift this weekend), last-minute Christmas shopping, present-wrapping and work functions (well, only the one).
Even managed to re-construct an old dart-board cabinet - that one is for my brother-in-law.
Somewhere amongst all that, work continued on re-creating the hi-jacked whale-boat.
Almost there ...
- Tom Schongar and GLakie
- 2
Dave !!!
A brilliant thread, seeing as I'm only just embarking on my own cruise with Connie and - from the beginning - had planned to light her up.
You clearly know what you are talking about, whereas I lack any technical training in electronics. I'm anxiously waiting to see your finished work.
Initially, I had planned on using LEDs, along with a Flickr3 circuit-kit which I had purchased, for my build. However, now I am seriously considering switching to optic fibre. This brings up a question: Will my Flickr3 still work with optic fibre ??
One concern.
Seein' as I am working with wood for my own build, then I must confess to being a tad TERRIFIED of any significant increase in heat !!
Finally, a suggestion which you may/may not wish to consider for your overall design ...
Primarily to reduce power usage, you could possibly incorporate a light-level detector which would switch the rest of the circuitry (lights/flickering/etc) on only when it was night-time.
Thanks Glider.
Nice start you've made there.
Thanks Keelie,
Really, it has come down to me currently having very limited space - and time - to work on my build.
Thus, I have chosen to work on the smaller sections of this kit for now.
I can understand if some would suggest my OCD kicks in a little too frequently !!
- IgorSky, usedtosail, ronald305 and 5 others
- 8
Ulises,
I think your Vasa build is stunning !!
In particular, I was extremely impressed with the doors made from round toothpicks.
Could you please add those pics (with a quick explanation) here ??
That idea is brilliant !!
(And perfect for this thread !!)
No real updates for this weekend, folks, though work does continue on my boats.
Some spare time the other evening saw me put together a few ideas, and hence, I've created a little forum here on MSW which I'd very much like people to check out. After a change to the working title, it is now called "The Kit-Basher's Guide to the Galaxy."
(Douglas Adams ?? No ?? Never heard of him !!)
JEWELLERY - Cheap lengths of chain are ideal for numerous uses, depending on the size of the links and your model's scale.
Here, I have taken links from the chain on the left, cut them in half using nail-clippers, and used them as oar-locks on my
Captain's Gig (1/76 scale).
(Incidentally, be VERY careful not to cut up the Admiral's necklaces without checking with her first - note my eye-patch!!)
- John Allen, dgbot, Marcus.K. and 5 others
- 8
SANDPAPER STRIPS - Cut thin strips of very fine sandpaper to simulate leather strips, such as used for straps.
The texture of the sandpaper is guaranteed to produce a few extra "Ooohs" and "Aaahs" from people who view (and touch) your model.
(For these straps on my half-moon hatches, I have used black wet-n-dry sandpaper.)
ALUMINIUM CANS - Cut strips from a flattened-out can to the scale size of flags for your ship/boat. Using transfers or by painting, glue your flag design to both sides of the aluminium. Remember to reverse the design on one side.
Then crumple the aluminium piece slightly. Let the glue dry completely, and then very carefully peel your flag away from the aluminium piece.
Hopefully, you will be left with a flag that appears to be permanently flapping in the breeze !!
(This idea came to me from fellow USS Constitution builder here on MSW - the eminent modeler12)
- John Allen and Per
- 2
- Mike Dowling, Mirabell61, IgorSky and 16 others
- 19
XMAS TREE LIGHTS - Recently, a string of about-to-be-installed Christmas lights caught my eye. These were only a cheap variety, but my immediate thought was: Cut the tips from each globe, drill holes of corresponding size in a strip of wood, insert former Xmas light, and you have a perfectly round porthole with a domed window pane.
(Observant viewers may have noticed the complete lack of snow in my part of Australia at Christmas time - it was 38 degrees Celsius today!!)
BEADS - There are thousands of different beads available. I strongly recommend spending a few hours browsing through the shelves of a good bead store, if you can find one. Otherwise, settle for a raid on the Admiral's sewing table. Try imagining each bead cut in half/sanded/sliced.
This pic shows a whale-boat (1/76th scale) I am currently working on. The central drum is a bead, with the wooden ends being former chopsticks.
CHOPSTICKS - To create winches for my whale-boats (1/76 scale), I cut the tips from a pair of take-away chopsticks. Minor sanding and shaping produced the final result. Some holes were drilled through the tips (0.2mm bit). Paint inside of holes black.
HOUSE RULES
To help with following this forum, may I suggest that you:
- CAPITALIZE the name of the object at the very start of your post.
- Please indicate scale with your suggestion, as various items could be used for different purposes in another scale.
- Separate posts for each item AND purpose will make it easier for people wishing to search this topic.
- Photos are actively encouraged !!
To get things rolling, here are a few suggestions of my own:
Arr !!!
CaptainSteve 'ere. Recently promoted to Apprentice Wood-Hacker (3rdClass), aboard the USS Constitution (under Cap'n 'ull, 'is ownself, no less).
Most all of us as ship-modellers, I suspect, strive to create as much realism as we possibly can with our models. Whether you class yourself as a kit-builder, scratch-builder (seriously, you guys truly are the Jedi-Masters of the model-ship universe!!), or something in-between; surely we look to make our models correct - aesthetically, technically and historically.
Myself, I have discovered that I am a kit-basher ... a term I had never heard of prior to my discovering MSW.
I unashamedly accept the title.
As such, I often find myself looking at everyday objects through the eyes of a modeller.
Fortunately, my job often sees me waiting in stores and various businesses, giving me golden opportunities to browse through their display stocks, whilst considering how some items could be trimmed/chopped/painted to become the perfect capstan/smoke-stack/cannon-ball or whatever.
As such, I would like to start a new forum based upon everyday items which could be tailored into ship parts to enhance our models.
[Please note that, with the recent change of name for this forum, I am familiar with the works of Douglas Adams AND have read his entire, brilliant "HHGTTG: A Trilogy in Four Parts"]
Landlubber Mike's technique for furled sails
in Masting, rigging and sails
Fantastic pics and tutorial, Mike. I'll definitely be re-visiting this post once I get up to doing the sails on my USS Constitution.
