Everything posted by Niklas
Always liked the look of this ship. Will follow you're journey 😀
- 3 replies
- Nuestra Señora de las Mercedes
- OcCre
That looks very good! Have you got yourself a scroll saw yet?😀
- 99 replies
- ancre
- La Mahonesa
Interesting project, will follow you all the way.😀 Niklas
- 99 replies
- ancre
- La Mahonesa
Very nice model, congratulations! I have also built Caterina but in a larger scale and - as it turns out - with the antenna upside down... Niklas
- 61 replies
- ancre
- Santa Caterina
Very nice build! The oars came out great. I recently made my first oars and found it to be more tricky than I expected. Niklas
HMS Bounty by AdamA - 1:48
Niklas replied to AdamA's topic in - Build logs for subjects built 1751 - 1800
Very nice. Following your build with great interest! Niklas -
Hi Mike! Been following your display case build and I am very impressed! Now looking forward for some Cromwell! Niklas
- 969 replies
- hahn
- oliver cromwell
ancre Le Rochefort 1787 by Niklas - 1:36
Niklas replied to Niklas's topic in - Build logs for subjects built 1751 - 1800
Hi Finally found some building time on my Rochefort. I made a promise to myself to do all the frames before summer ends and have only two left (not including the scary ones at bow and stern…) After that there will a lot of faring to do. Here’s some quick pics where I am right now. Niklas -
Ken, have followed your build all summer. Very impressed!
- 424 replies
It all looks very good! I'm also impressed by the building speed, and still so accurate! Niklas
- 424 replies
Tony, all four are interesting projects. I`m enjoying the Rochefort even if it´s a little more than I can handle, still I understand that Naiad is tempting. If I had the skill I'd might go for that one, but it's your choice. Don't know if this helps: I use my small scanner when I need copies for frames etc, but took the original plans to a professional copy place that printed out unfolded copies. Perhaps not super accurate but I can live with it. Your way of doing it is of course the best way to get it as perfect as possible. Niklas
- 132 replies
- triton cross-section
- cross-section
Very nice, Tony! Now looking forward to your Brixham... Niklas
- 132 replies
- cross-section
Hi! Slow work but have finally found a way to build the frames. I've seen others doing the lower parts first and it makes sense. Here's some first results: -
Yes, a very nice work place (hopefully the printer don't mind some dust...) I will follow this build with interest!! Niklas
- 424 replies
ancre La Salamandre by tadheus - 1:24
Niklas replied to tadheus's topic in - Build logs for subjects built 1751 - 1800
Catching up on your build. Impressive!!! -
Thanks. Good to be back, again...:) -
Hi all Had to take a brake from building but now I appear to be back again, hopefully with some more regular updates. Finally done with the keel. Now on to do some frames! Niklas
