Bedford
Everything posted by Bedford
  1. You just stick with us mate, we won't lead you astray, fair dinkum!
  2. Very nice thinking outside the square, I would never thought of a knurling tool, I have one but it's diagonal, guess it would make nice helical gears
  3. I agree that the launch would be a beautiful model, even better in full size!
  4. I've just found this build and have to say it's very impressive. You've got a very nice machine and tooling setup too I'll be keeping this build for further reference.
  5. The tiller is large enough that used with the outrigger stowed my hand will rest over the top and sides without really touching the device.
  6. I still haven't found buoyancy that I'm happy with but I reckon since I'll be sailing her single handed most of the time I'll need a third hand, a way of holding the tiller for a few minutes now and then. I milled a piece of scrap brass left over from turning another part to make up a sliding jamb, I'll run a line across the boat via the tiller "lock" The mill in the first pic is 10mm diam with a 2mm external radius, I used it for the edges of the brass and the fair leads in the though block Simple 3 piece brass assy and you can see the fair lead in the right hand block Fitted to the tiller, I mounted it on the boat and it seems to work well, the only concern is that the wedge may slide back accidentally causing friction while steering but if that happens I'll slip a couple of magnets into the woodwork to hold it in place.
  7. Finally she's a sail boat, almost, still fine tuning to do and buoyancy to organise. It's getting crowded on the centre board case
  8. It's looking very nicely jury rigged, well done and good luck!
  9. Valeriy I've just caught up several pages of this build and all I can do is repeat the praise so many have given. As for soldering, I'm always trying to convince people that it is not the demon they think it is. I've been doing it for years. I must admit that I thought my 1/8 scale bullbar was pretty good but you're making me look very amateur. This was all done with 40/60 resin cored solder and a 40 Watt soldering iron and a small gas torch.
  10. Mark the tack and clew are made off to each end of the boom leaving the foot free while the head is secured along the full length of the gaff. In the pic above you can see the two empty holes in the gaff yoke and there is a hole through the other end of the spar to tie it off to, the boom is the same.
  11. That's an interesting challenge Mark Just a thought, perhaps set the sails in front of a fan and spray with dilute PVA or perhaps even spray starch, I know it's available, not sure if it would hold.
  12. A little more progress on the spars, both yokes are leathered now and some rigging done, I've even had time to make a boat hook out of left over spruce.
  13. Hi Paolo, I'm just over the hill near Camden. Welcome aboard, there's lots of helpful knowledge here.
  14. Hey Keef, what he said!
  15. John, somehow I've missed all that's been going on in your life but glad you're back on deck
  16. Yes the leather will have to be sealed with dubbin polish and greased with something. The plans call for leathering both yokes, the gaff because it slides up and down the mast and the boom because it's height is set by the tension between the luff and a downhaul that circles the mast to a thumb cleat below the boom on the fore face of the mast. With the boom moving up and down with the setting of the sail it's more convenient to leather the yoke than the mast.
  17. Work is progressing slowly on the sail rig Boom yoke in mahogany Gaff yoke in mahogany Finally the mast is rigged and standing It's been about 40 years since I did a little leather work in school and one of the few things I remember is to wet the leather, kangaroo in this case and it shaped very nicely
  18. Wow Joe, that kit is very interesting. Just a side thought on the ship itself, she has tiller steering and having had the helm on the Bark Endeavour which is a 6ft diameter wheel that acts on the tiller I have to say she would have taken a strong man or two to steer because with two on the wheel of Endeavour she was hard work at times!
  19. Thanks so much Joe, I'll have a look at both. The Caroline is going to be bit of a challenge as I need to be in the right place physically and emotionally to undertake that build but one day I'll do it. I've always planned to have a portrait of my girl hanging in the Kings cabin.
  20. Michael, I think most of us with the best aptitude for this kind of work don't have the aptitude for standard education techniques, I certainly didn't do anything stunning at school with the exception of anything that involved mind and hand, in which case I did quite well.
