pete48
Everything posted by pete48
  1. Thank You, Lawrence, Welcome aboard, I will be opening up the Sail loft and she will carry a Main and working Jib, I have not decided whether it will be self-tailing or not. BTW beautiful job on your African Queen Thank You, Gerty, Thank You, Piet, I think she may be the Crown Jewel of my fleet Thank You, John, I originally saw the white on the Spreaders and Masthead in a WoodenBoat Article, " the bees knees" thats great. I hope she finishes strong Best Regards, Pete
  2. Today, I started by sanding the Coamings, starting with 400 grit sandpaper and working my way up to 800 grit sandpaper. I then applied the third coat of varnish. IWith 4 coats of varnish on the Mast and Boom, I turned my attention to finishing the Mast by painting the Masthead and Spreaders white. Next will be to finish the Cockpit coamings and start making the Sails. Here are the results
  3. Nice work Patrick, Amazing details, Looking good Best Regards, Pete
  4. Beautiful Boat Chuck, She looks very sweet. just gorgeous Best Regards, Pete
  5. Hi Yves, You are very kind, it was nice to see the picture, I had to show it to Kate, she loved it and likes your house. Best Regards, Pete
  6. Hi Nils, The prototype looks good, the wider strakes do stand out more than on the pre-cast lifeboat. I am sure whatever you choose will be Amazing Best Regards, Pete
  7. Hi Keith, Coeur d' Alene is a beautiful part of the North West. The Deck is looking good. The way to add all references to your posting is done in the Signature. go to your profile page and hit the edit my profile button in the upper right corner, Then on the left side select signature, it will then display " my current signature" scroll down and in the edit signature, you can set it up however you like. I hope that helps Best regards, Pete
  8. Thank You, Michael, I am sure that yours will look Amazing ( it already does ) Thank You, John, She is almost ready to be fitted out Thank You, Elijah, I am just about ready to round the top mark and head for the final leg of this build Thank You, Nils, I appreciate the compliment Thank You, Cap'n'Bob, she's getting there And thanks to everyone that hit the like button Best Regards, Pete
  9. Hi Keith, The deck looks good, Nice work Best Regards, Pete
  10. Hi Yves, I just discovered your build, Very nice, She's looking good, I will have to follow along Best Regards, Pete
  11. Today, After another coat of Varnish was applied to the Spars ( Mast and Boom ) I turned my attention to installing the Cockpit coamings. I started by finalizing the fit. I then made the brace that fits between the Coamings on the forward bulkhead. Next, I made the forward Coaming block, I ( once satisfied with the fit ) I installed the coamings brace and block. I then stained the block and brace cherry red. Next will be to varnish the Cockpit Coamings. Here are the results
  12. Thank you, Mark, I appreciate it Thank you, Piet, She has a nice shine Best Regards, Pete
  13. Thank you, Elijah, I am very pleased with the finish, Epifanes makes a great product Thank you, Patrick, there is no trick, Just patience and taking your time ( lots of sanding ) She is easy on the eyes ( lol ) Best Regards, Pete
  14. During this week, I have been sanding and varnishing the Hull, rub rails and toe rails. for the sanding. I started with 400 grit sandpaper and worked my way up to 800 grit sandpaper. I then would apply varnish wait 24 hours and re do the process. ( sanding and varnishing ) there are 6 coats of Epifanes varnish now on the Hull. I am pleased with how the varnish turned out, Next will be to complete varnishing the Spars ( mast and boom ) they currently both have 2 coats. Here are the results
  15. Very Nice Vaddoc, the ropes look great, Beautiful Boat well done Best Regards, Pete
  16. Nice layout work Keith, She's taking shape, well done Best Regards, Pete
  17. very nice, Piet, Looking good, nice work on the carvings Best Regards, Pete
  18. Hey Patrick, The Jet Skis look great, beautifully done, do I need to pack a lunch or is the galley fully stocked? Best Regards, Pete
  19. Thank you, Chris, That is correct, down to 2 projects, I have many more planned Best Regards, Pete
