mtaylor
Moderators
Everything posted by mtaylor
  1. I worked with guy who was a welder who only needed to look a plan once for a particular job. The third time someone asked him about which plans was he using and he responded "I don't need no plans" got him fired. It was an Army project and the army inspector had him fired on the spot for not having the plans. Funny thing was... what he was welding was perfect. So yes, read the plans, put them on your workbench in case someone asks.
  2. Now I'm confused.... one asks a question and the other says "Yes, I got the answer.". I think I need more grog. BTW, do start a build log in the kit area. It's the best way to get help.
  3. Yep.. I'm here, not sure where the others are though. I've found the grog and am just kicking back waiting. At least now I can share instead of drinking by myself.
  4. Welcome aboard, Jerry. I'd suggest you do your introduction here: https://modelshipworld.com/forum/3-new-member-introductions/ but instead of this topic, create a topic of your own. It will get you more "eyes" on your intro than this corner. Lots of folks around to help so do a build log when you're ready.
  5. Just add, I've read where even the cannons would be moved or at least rotated sideways on many ships. As others have said... just about everything could be and would be moved.
  6. Eric, your post needs a thousand "likes'.
  7. Part of the instruction problem is with the older kits. Many of the new ones like Syren, CAF, Vanguard just to name a few, have very good instructions. Many of the older kits from companies like AL will never be upgraded or improved.
  8. And the first time you revved up the engine and dumped the clutch.. the body would quickly look like a corkscrew. I learned that hard when I was putting small block motors in a Chevy Vega. Need to stiffen the frames up.
  9. AzLandLover, I daresay that all of us have been where you are. A log may seem embarrassing but it's really not. It's a learning tool, not just for you but others doing the same model. So, my advice is jump in.
  10. Welcome to MSW, Pipe Major. Louie da Fly gave the best advice. I hope you'll take him up on it.
  11. Done. No arms were twisted here. Just somewhere between left field and 1st base.
  12. My bad. I've been buried in other things. I guess I need to get one ordered.
  13. Is it possible that all these terms are for the same ship? And also, the style of the art. It wasn't it until much later after this period that true dimensional artwork came about. Before that, very stylized as some of the pictures show a minimal amount the hull in the water. I'm not an expert but it does seem that the artworks progressed in detail and the way the ships appear. The alternative is that they actually did look and float like that and were very tiny given the size of the passengers. I am enjoying this conversation (as well as on the other builds of this era) and am learning a lot.
  14. Not sure where to point you too since there's so many kits with different or slightly different rigging plans. Use the search feature and search for Cutty Sark. You should find lots of logs.
  15. If you can only find the primer/paint in spray cans but want to brush it on, there is a method called "decanting" or "decant". I'm not sure how to do this but many of plastic experts do it all the time. Maybe Googling will give you some idea on how to do it.
  16. Welcome to MSW, Tom.
  17. Hi Seaforth, Welcome to MSW. As far as your current model, there's quite a few builds of the ship in the kit area and and index here to assist: https://modelshipworld.com/forum/150-index-of-all-kits-by-brand-and-subject-coming-soon/ Also, do give some consideration to starting a build log. Here's how to start a log:
  18. Welcome back "home".
  19. Hi Gazzarian, Welcome to MSW. For a first effort, it looks pretty good from here. All of us have probably gone through this and with results we were less than pleased with. I'd like to offer a suggestion, instead of HMS Victory, pick something a bit smaller with maybe two masts this time. The learning curve for Vic will probably have you pulling your hair out so something a bit easier. I'd suggest giving some thought to the Syren. There's lots of build logs to help you get through it. Also, do start a build log. It's really the best way to get help, advice, and meet people. Also, open a new topic to introduce yourself. Good luck and have fun as the fun part is the best part.
  20. Welcome to MSW, Patrick. When you start the model, open a log in the kit build area as it's a great way to get help and show your progress. As for tool, we do have a tool section and a jig section which might be of some help.
  21. Hi David, Welcome to MSW. Hopefully you'll tell us a bit more about yourself. As for the bulkheads, do a bit of searching here: https://modelshipworld.com/forum/14-building-framing-planking-and-plating-a-ships-hull-and-deck/ You will probably find many ways of doing this. Also, if you go here: https://modelshipworld.com/topic/17023-quick-find-indexes-to-build-logs-for-kits/ , you'll find indexes for all the kit builds. Should be quite a few on the Syren.
  22. Welcome aboard, Andre. For a first model, that looks impressive and shows way beyond beginner skills.
