Everything posted by mtaylor
18th Century Harbour Crane by Ekis - Shipyard - 1/72 - CARD
mtaylor replied to Ekis's topic in Completed non-ship models
Beautiful work and hard to believe it's card. A diorama at some point would really make it pop. -
Quick find index
mtaylor replied to Jeff5115's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
Mark your log as finished and also add finished to the "tags". Both can be done if you go back to the first post in your log and edit it. . Currently, one of the moderators goes through and picks up the finished logs for the index. We hope to have it automated at some point. -
Bone models are fascinating. We had a builder who started a scratch log using bone but he never finished. Not sure what happened to him.
Welcome to MSW, Jim. I hope you will start a build log as it's the best way to get help and make friends here.
Greetings from Chicago and winter is coming
mtaylor replied to ThirdCoast's topic in New member Introductions
Welcome to MSW, ThirdCoast. I"m not sure what the third coast is but not knowing your name that's what we'll use. -
Byrnes thickness sander vs Micro Mark's
mtaylor replied to twintrow's topic in Modeling tools and Workshop Equipment
I haven't been using it actually thickness but just to get rid of the sanding marks from a former (not Chuck) supplier. I had planned on it though but maybe later on this year I'll see what the problem really is as I do have some wood to be thicknessed. I suspect part of it is the rubber insert the sanding sleeve goes one. -
I've been thinking of it even though the thickness sander I have is seldom used. -
Two questions... Mast and rigging related.
mtaylor replied to Jorge Hedges's topic in Masting, rigging and sails
There's been a lot of discussion on this. Try searching this sub-forum for "rigging" and "tools". Many of us use surgical type tools as well as things like clothes pins to hold the rigging tight while being secured. The other place to look is here: https://modelshipworld.com/forum/17-model-tips-and-tricks-and-making-jigs/ -
I see you posted that question in the proper forum and you'll have good chance if getting an answer there. Also, use the search feature and search for log. They'll have a ton of info.
Welcome to MSW, Aaron. Feel free to post some of your work, here. We also have sections for build logs, etc.
New Member - Ranger, Spruce Goose, Tippecanoe, The Dinghy
mtaylor replied to Chuck L's topic in New member Introductions
I remember doing those "float boats" as a kid. Had a lot of fun. The only time you'd use "Finished" in a title is for a build log. As for the signature... top of the page where your name is, there's a little upside down triangle. Click it and pick "Account Settings". The Signature topic is located on the left hand side. Click and you'll find it. Hope this helps. -
This has been a wonderful build and very well done. Thanks for letting us follow along.
- 124 replies
- longboat
- Chaloupe Armee En Guerre
Looks great, Steven. Just wonderful. I go along with Mark P. maybe trimming the sails?
Basically the MM is the same way as far as adjustment for the Byrnes. However, I've noticed that the tolerances are bit off or maybe it's the rubber axle for the sanding sleeve so the board being sanded ends up with one side being "short" and the other being "long". The only fix I can find is to run the wood through once and flip it over. Alternating back and forth. A PITA though. -
The problem I see is look at the two blocks, one at each end. On the right side just past the yard is a vertical line.. that's the end of the yard. The next two parallel lines are for the dimension. I think the yard as is, is spot on or darn close.
I've just now found and wandered into the shop.... The jig alone is a project. Looks like everything is going well, from here. I'll get a seat for this.
- 312 replies
- enterprise
- caf
I don't know if you have them where you are, but many lawn and garden stores carry square vinyl fence post covers that around 4 to 6 inches square. I've found them ideal for storing wood as they stiff and I can stack them high. I do use the longest ones I can find and cut them half so I have two pieces for storage.
kit review 1/50 Viking Longship – Drakkar, by Amati
mtaylor replied to James H's topic in REVIEWS: Model kits
Try contacting Amati would be the best bet. They do have a website and a "contact us" area. -
Generally speaking, the studding booms were moved inboard on the yard. You might look at some of the builds in kit (wood) and also Google is your friend also. Google for Cutty Sark and add various words such as yards, studding booms, and see what's there.
Messerschmitt Bf 109 E3 by ragove - Matchbox - 1/32 - PLASTIC
mtaylor replied to Papa's topic in Non-ship/categorised builds
That's a very common excuse, Phil. But it may be valid as some do have an attention deficit problem. Or, maybe it's just fear of messing up badly.
