mtaylor
Moderators
Everything posted by mtaylor
  1. Well.. got sidetracked again... Guns came into today, so I'll tell a few people to leave me alone tomorrow so I can take photos.
  2. Eberhard, Check a stationary store for cardstock. I've seen some very smooth and very thin stock in assorted colors.
  3. I do understand your view, Lou. You obviously know her well. I'm doing pretty good, Lou. She's where she needs to be and with the issues, I'm not about to go and stir those up again. I'm finding peace. Now that we've run this topic into another dimension of space/time....
  4. Glenn, Google is your friend... https://www.google.com/search?q=Pear+wood+filler&rlz=1C1ZCEB_enUS832US832&oq=Pear+wood+filler&aqs=chrome..69i57.2735j0j8&sourceid=chrome&ie=UTF-8
  5. Hmm.. 11 hours one way. I want to but do I dare? Haven't been to Oxnard in maybe 50 years. Seems about time.
  6. Lou, Consider a tandem bike. Between you and your lady, you be able to putt right along. It will take some work to get things to come together though. Janet and I used to have a tandem and for her it was perfect (leg amputee). Called ourselves the 3-pedal tandem team. I miss those days and miss her, but such is just the way it is.
  7. Thurston made great blades (I'm still using them) but when they closed they recommended here; https://www.malcosaw.com/ If you're using a slitting saw, there's no offset to the teeth so that is a constant source of heat build up. I've found to not get into a big hurry... cut a plank, check the blade, if hot... wander off to get some coffee.
  8. Phil, Take zu Mondfeld's book iwth a grain of salt. There are errors in it. I use it a lot but as a starting point to confirm or deny that I'm on the right track.
  9. Here's the results from a quick search.... https://modelshipworld.com/search/?q=coffee sticks&quick=1 Yes, modelers do use them.
  10. If the blade is moving from side to side it sounds like something is out of alignment. You could also clamp a sheet of wood to the top with smaller diameter hole for the blade. Might be faster and easier to do that. I took that darned fork off very soon after getting my scroll saw. Was too big and in the way for what I was cutting. Just have to make sure to put a bit of pressure on the wood being cut, a sharp blade and a slow and easy feed.
  11. Check the thickness of the blade Bob. I've found the thin ones really get warm on long cuts and do distort where as the thicker ones seem to work better. I agree with high speed and slow feed. You might also periodically try backing out of the cut an inch or so. Seems to help from I've seen with mine.
  12. Do be advised that any scanner will not scan at exactly 100%. This is done by all companies making them so as not to have their machines used in counterfeiting money. So it make take some fiddling with the scanning and printing to get a perfect copy. I stand corrected... the paper roll fed machines used by architectural firms for printing building prints are an exception.
  13. Hi Dana. Welcome to MSW. I hope you'll start a build log as it's a great way to get feedback as well as meeting other modelers.
  14. Denis, when you make your new insert for the saw, try to get the hole for blade as small as possible without interferring. It helps when trying to cut thin wood and/or small pieces. Also, if you have different (I'll call it width) blades due to tooth count, make different sized inserts.
  15. My father and his brothers were all in the Air Corps during WWII and in B24's. Except for one.. he was odd ball and joined the Marines, but I digress. The stories those brothers told when I was kid, made me wonder how any of them came back. The uncle was squadron CO and (according to the story) took his men and planes out on a training mission in England. He had them follow him while and do what he did, loops, rolls.... etc. When they got back the manufacturer reps and the overall CO had a fit as "heavy bombers aren't supposed to be able to do that". During one mission, flak flipped his plane upside down and they couldn't re-right it do to damage. So they flew it back towards England that way. Once over the Channel, everyone bailed out. According to the legend, some B-17's also pulled the same thing with much angst amongst the brass. Both the B-17 and the B-24 were tough birds and could take a lot of damage. The heavies didn't have dive brakes and I don't think the mediums did either.
  16. I can't imagine why? Then again, I preferred him also. Nevermind... I know why.
  17. Wow.. what a difference between the kit and aftermarket gun. I'm following to, as I've always liked the old warbirds.
  18. Er... issue. The flaps would be down or extended for take offs and landings. Needed for additional lift when the air speed drops below a certain level. But, on the ground, the flaps would have been retracted when parked or taxiing. Lovely work, Denis. I'm liking what your doing.
  19. I'll try to do an update tomorrow or Saturday. Don't expect much except a pile of olive painted parts as that seems to be the only color the USMC knew back then. But now with the wars in the ME, everything is painted "Sand"... <sigh>
  20. Nice work on the stern lanterns, OC. And that crewman looks great. I can see what you mean about magnification.
  21. Sorry to hear of your losses. Losing family and friends is never easy. The work you're doing is look A-1.
  22. Interesting project, Denis. Count me in for seat. It could have been a slaver as they ran slaves up until almost the end of the Civil (or Not-so-Civil) War. Also, a lot of slavers were converted over to blockade runners.
  23. Well, if they want to treat you like staff... insist on payment for meetings. But that will go over like a lead balloon.
