mtaylor
Moderators
Posts posted by mtaylor
  1. Hi Gary, here's my view.  Others will most likely add their experience.
    Glue:  There are as many answers to the "right" glue as there are builders or so it seems.  Experiment with some scrap and see what works for you.
    Bending:  I use a curling iron and a tub of water.  Dip the plank in, and use the iron to heat.  When the bending gets harder, reapply water and heat.
    Cutting:  Cut as close as possible.  Then after install, touch up by sanding.  I use sandings sticks from a beauty supply shop.  These the nail sanding sticks.
    Keel:  No input here as I've not build one like that.
    Finishing:  The problem with sheet rock filler is that it's more like plaster and thus, can crack.
    Deck planks:  Again, many different answers.   I tend to use white wood glue and wipe of any excess with a damp cloth before it drys.
    Don't take my methods as verbatim.  Everyone uses different methods.  For example clamps... some use specialty clamping, some pin, some use clothes pins and/or rubber bands while others use a mixture of clamps.  Depends on what the builder is comfortable with and the task at hand.
    I see 4 logs for the Norden.  You might read through them to see what they did.
  2. Budget, time, and tools are big three questions.   I've turned brass cannon using a Dremel and files.  Killed the Dremel in the process.   As for materials... wood, plastic, metal are all options as well as making masters and casting them out of various materials.  It all goes back the 3 questions and then add one more:  "what do you want to try or feel most comfortable doing?".
  3. On 1/10/2019 at 6:40 PM, popeye the sailor said:
    I was browsing around looking for pictures...........also checking out color charts.   I found this picture.......I wonder what the scale is on these models.
    these are Ford proto type models........my guess is either 1:16 or 1:8..........can you imagine building this many models!  mind boggling!  ;)
    Being prototypes I wonder how many were clay or wood?
  4. 1 hour ago, CDW said:
    Maybe since the 1:1 ship is a fictional movie prop, not an historical sailing vessel replica, certain artistic liberties are taken to simplify the construction of it yet still look authentic to a certain degree for the average person/movie enthusiast. In that case, functional gun ports would not be an issue that would warrant excessive spending to achieve.
    Let's face it, the average person is not well informed at all on early sailing vessels. A reasonable facsimile is good enough for a Disney pirate flick. Johnny Depp as Jack Sparrow is ample evidence of that.
    Indeed, there are several things that make us modelers scratch our heads... the capstan with the main mast coming out of the center of it comes to mind.   Ah... movie magic.... ;)
