mtaylor
Moderators
Posts posted by mtaylor
  1. 1 hour ago, dafi said:
    Chemical interaction with the vehicle or other paints? It is more than 200years now.
    But the most important question to me still is where is the provenance of the sample(s). And how this small sample gave reason to be applied to the whole outside of the ship?
    Always open for new finings and input, as long as they are explained properly and seem logical to me. Good research is one thing, judging the results the other.
    XXXDan
    Excellent point's Daniel.   If we look at the work on Vasa, they did small samples early on from here and there about the ship and determined she was basically blue at the bulwarks and the sculptures were gold.  Further research in detail showed that the bulwarks (external) were red and figures were multicolored and rather colorful.   I suspect this is still too early to say yes or no the Vic's colors.
  2. The red wasn't picked to hide the blood which is a myth.  The red (as well as white) was cheap and frequently re-applied.   The gundeck on French ships could be either red or white depending on level.  Gun carriages most usually were red but for modeling... wood works well.   The French model builders usually don't use paint at all but "paint with wood" such that the carriages and bulwarks on the gundeck would most likely be Swiss pear.
  3. 3 hours ago, SJSoane said:
    hi Mark,
    I must have missed it somewhere, I apologize; what laser cutter are you using?
    I have one of the "early" ModelExpo machines that's been heavily modified due to a tube breaking and water creating problems.   Instead of the original 40W (ok... 30W in reality) it's similar to the Chinese K40s,  but it now has a beefed up power supply, and the tube is now a true 50W with an extender on the laser case to allow for and protect the extra length.   It only has a 12X12 bed area but the machine is physically about as large as I can go in the current workshop.  The base cause was the water pump (an aquarium type is standard for these) died.   I replaced it with a refrigerated cooler from lightobject.com which has been goto source for all parts.
    Here's a link to rebuild, this was the major upgrade before the tube broke and the power supply blew.
  4. Heinrich,
    They did use sliding doors for the officers "facilities" later on but in the period of this ship, probably not.  That's why i think they may have paralagrams as such as the one I've sketched below.  I've seen that shape on some of the older ships with the massive stern balconies and also for the doors to the officier's facilities and the captain's or admiral's "office" in the galleries.   When it opens, the bottom clears the deck and the top clears the beams.   It may have to have flipped top to bottom depending the deck and beams camber along with the rise in the deck as it goes aft.
  5. Thanks for the likes and the comments.
    I love the smell of sawdust in the morning because it smells like something getting done.... Not quite the famous line, but it works for me. :P  Just realized I needed to order more Yellow Cedar from Chuck.  My stash of other species is a bit light in the small thickness so it's either mill what I have from somewhat bulk pieces or order.  I think I'm just going to need the cedar for now as I have the stock to finish the hull including the two weather decks.
    Pat, I do love the laser.  I really wish I had more to cut on the at this point.  But it looks like odds and ends from hear on out.   Next ship it'll get a workout.
    2 hours ago, Roger Pellett said:
    It’s good to see you “back in the saddle again!  Before you get to far along with your boat you might like to look at the ANCRE website.  French ships boats had some distinctive features.
    Roger
     No need to look at their website, Roger.  I'm well stocked with their books.  Yes, very distinctive features.  I have the plans for the Belle Poules boats and using them as a baseline.  Since this one is the low boat on the stack at midships, I'm having to sort through what I will be leaving off besides the thwarts and what I have to include like the 4 cannon posts, the rear roller, and the stern seat.  Some of these fittings will have to wait until the next boat is built to ensure proper fit of the "rack" inside to stack the next one up. With all 3 being stacked midships, the uppermost (the cutter) will get the full interior treatment.
    So, I'm trying stay a few steps ahead on things.
    I just realized I've messed up the terminology.  The largest is the "longboat", next size down is the "barge" and then the "cutter".   All similar too but not quite the same as other countries boats.  Even the best laid plans of mice and men run afoul of Mr. Murphy.
    Damn,  I forgot how much fun and work this is.  The fun and satisfaction make up for the work.
  6. Seems like it's been forever what with numerous personal issues that needed solving but it's time for an update.  And it feels great to be back in the shop and doing something again.
    The build jig has the main framing pieces installed, checked for fit and still needs a bit of tweeking to level out for the planking
    Today I grabbed the bull by the tail and stared the situation squarely in the face, in a manner of speaking.  I laid out and cut the planking for the boat.  There's still a couple pieces uncut but I'm holding off as those are the last ones installed and need to be trimmed to fit.
    Overall, I'm most impressed with the Yellow Cedar.  Hopefully, over time it will fade in color a bit.   It cut nicely and cleanly and minimal smoke except for some places on the "hidden" side (last photo) where the beam exits the wood there is some splotching which appears to be sap popping and discoloring the wood. I think a bit of sanding will take care of that.  Could also be that the table the wood sits on needs a good cleaning.
  7. Finally got around to cutting wood.   And I'm pretty darn happy with the Yellow Cedar on the laser.   Cut's clean, a bit of smoke here and there and after making some test cuts, Chuck's advice about low power and slow speed are spot on.  It just took some testing to find out low the power could go.
    Anyway, here's the pictures of 1/32" sheet cut for planking my "large" ship's boat.  First one is the topside of the sheet, and the second shows the bottom sides with some splotches where it appears that some sap "popped". I've seen this in other woods, so wasn't surprised by it.
    Edit:  Note to self, order more Cedar....
